| int | ProcessViewRequest (vtkInformationRequestKey *requestType, vtkInformation *inputInfo, vtkInformation *outputInfo) override |
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetVisibility (bool value) override |
| | Get/Set the visibility for this representation. More...
| virtual int | GetMoleculeRenderMode () |
| void | SetMoleculeRenderMode (int mode) |
| virtual bool | GetUseCustomRadii () |
| void | SetUseCustomRadii (bool val) |
| void | SetLookupTable (vtkScalarsToColors *lut) |
| void | SetMapScalars (bool map) |
| | Set if scalars are mapped through a color-map or are used directly as colors. More...
| void | SetRepresentation (const char *) |
| | No-op. More...
| vtkDataObject * | GetRenderedDataObject (int port) override |
| | Return the data object that is rendered from the given input port. More...
| virtual void | SetOpacity (double val) |
| | Forward corresponding actor property controls down. More...
| virtual void | SetSpecular (double val) |
| virtual void | SetSpecularPower (double val) |
| void | SetAtomicRadiusType (int type) |
| | Forward custom atom/bonds rendering parameters to the mapper. More...
| void | SetAtomicRadiusScaleFactor (double factor) |
| void | SetBondRadius (double factor) |
| void | SetBondColorMode (int mode) |
| void | SetBondColor (double color[3]) |
| void | SetBondColor (double r, double g, double b) |
| void | SetUseMultiCylindersForBonds (bool use) |
| void | SetRenderAtoms (bool render) |
| void | SetRenderBonds (bool render) |
| void | SetAtomicRadiusArray (const char *name) |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkMoleculeRepresentation () |
| | ~vtkMoleculeRepresentation () override |
| void | SyncMapper () |
| void | UpdateColoringParameters () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
