| void | SetConnectionInformation (unsigned int processNumber, int portNumber, const char *hostname) |
| | Set the port and host information for a specific process number. More...
| int | GetNumberOfConnections () |
| | Set/Get the number of connections. More...
| void | CopyFromObject (vtkObject *) override |
| | Transfer information about a single object into this object. More...
| void | AddInformation (vtkPVInformation *) override |
| | Merge another information object. More...
| int | GetProcessPort (unsigned int processNumber) |
| | Access information about a particular process. More...
| const char * | GetProcessHostName (unsigned int processNumber) |
| void | CopyToStream (vtkClientServerStream *) override |
| | Manage a serialized version of the information. More...
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| | Serialize/Deserialize the parameters that control how/what information is gathered. More...
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| | Set/get whether to gather information only from the root. More...
holds port and host name information.
and host information from a render server. This information is used by the data server to make the connections to the render server processes.
Definition at line 32 of file vtkMPIMToNSocketConnectionPortInformation.h.
