| void | SetVisibility (bool) override |
| | Set the visibility. More...
| void | SetInteractivity (bool) |
| | Set the interactivity. More...
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetLogoWidgetRepresentation (vtk3DWidgetRepresentation *widget) |
| | Set the Logo widget. More...
| virtual vtk3DWidgetRepresentation * | GetLogoWidgetRepresentation () |
| virtual void | SetOpacity (double) |
| | Set the opacity of the logo. More...
| virtual double | GetOpacity () |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkLogoSourceRepresentation () |
| | ~vtkLogoSourceRepresentation () override |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
