| virtual void | SetQuality (int) |
| | Set the quality measure. More...
| virtual int | GetQuality () |
| int | Compress () override |
| | Compress/Decompress data array on the objects input with results in the objects output. More...
| int | Decompress () override |
| void | SaveConfiguration (vtkMultiProcessStream *stream) override |
| | Serialize/Restore compressor configuration (but not the data) into the stream. More...
| bool | RestoreConfiguration (vtkMultiProcessStream *stream) override |
| const char * | SaveConfiguration () override |
| const char * | RestoreConfiguration (const char *stream) override |
| virtual void | SetImageResolution (int width, int height) |
| | Communicates the next expected image resolution. More...
| void | SetInput (vtkUnsignedCharArray *input) |
| | Get/Set the input to this compressor. More...
| virtual vtkUnsignedCharArray * | GetInput () |
| virtual vtkUnsignedCharArray * | GetOutput () |
| | Get/Set the output of the compressor. More...
| void | SetOutput (vtkUnsignedCharArray *) |
| virtual void | SetLossLessMode (int) |
| | When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More...
| virtual int | GetLossLessMode () |
Image compressor/decompressor that uses LZ4 for fast lossless compression.
vtkLZ4Compressor uses LZ4 for fast lossless compression and decompression on data.
Definition at line 33 of file vtkLZ4Compressor.h.
