| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetAmbient (double) |
| void | SetDiffuse (double) |
| void | SetSpecular (double) |
| void | SetSpecularPower (double) |
| void | SetShade (bool) |
| void | SetSliceFunction (vtkImplicitFunction *slice) |
| void | SetRequestedRenderMode (int) |
| void | SetBlendMode (int) |
| void | SetCropping (int) |
| void | SetIsosurfaceValue (int i, double value) |
| | Methods to set isosurface values. More...
| void | SetNumberOfIsosurfaces (int number) |
| virtual void | SetCroppingOrigin (double, double, double) |
| | Get/Set the cropping origin. More...
| virtual void | SetCroppingOrigin (double [3]) |
| virtual double * | GetCroppingOrigin () |
| virtual void | GetCroppingOrigin (double &, double &, double &) |
| virtual void | GetCroppingOrigin (double [3]) |
| virtual void | SetCroppingScale (double, double, double) |
| | Get/Set the cropping scale. More...
| virtual void | SetCroppingScale (double [3]) |
| virtual double * | GetCroppingScale () |
| virtual void | GetCroppingScale (double &, double &, double &) |
| virtual void | GetCroppingScale (double [3]) |
| void | SetVisibility (bool val) override |
| | Get/Set the visibility for this representation. More...
| void | SetOrientation (double, double, double) |
| void | SetOrigin (double, double, double) |
| void | SetPickable (int val) |
| void | SetPosition (double, double, double) |
| void | SetScale (double, double, double) |
| void | SetInterpolationType (int val) |
| void | SetColor (vtkColorTransferFunction *lut) |
| void | SetScalarOpacity (vtkPiecewiseFunction *pwf) |
| void | SetScalarOpacityUnitDistance (double val) |
| void | SetMapScalars (bool) |
| void | SetMultiComponentsMapping (bool) |
| void | SetUseSeparateOpacityArray (bool) |
| void | SelectOpacityArray (int, int, int, int, const char *name) |
| void | SelectOpacityArrayComponent (int component) |
| vtkPVLODVolume * | GetActor () |
| | Provides access to the actor used by this representation. More...
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkImageVolumeRepresentation () |
| | ~vtkImageVolumeRepresentation () override |
| virtual void | UpdateMapperParameters () |
| | Passes on parameters to the active volume mapper. More...
| virtual vtkPVLODVolume * | GetRenderedProp () |
| | Used in ConvertSelection to locate the rendered prop. More...
| | vtkVolumeRepresentation () |
| | ~vtkVolumeRepresentation () override |
| bool | AppendOpacityComponent (vtkDataSet *dataset) |
| | Appends a designated opacity component to a scalar array used for color/opacity mapping. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
