| virtual int | RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| vtkImageAlgorithm * | NewInstance () const |
| vtkImageData * | GetOutput () |
| vtkImageData * | GetOutput (int) |
| vtkImageData * | GetImageDataInput (int port) |
| virtual void | AddInputData (vtkDataObject *) |
| virtual void | AddInputData (int, vtkDataObject *) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkImageTransparencyFilter () |
| | ~vtkImageTransparencyFilter () |
| | vtkImageAlgorithm () |
| | ~vtkImageAlgorithm () |
| virtual void | CopyInputArrayAttributesToOutput (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| virtual void | ExecuteDataWithInformation (vtkDataObject *output, vtkInformation *outInfo) |
| virtual void | ExecuteData (vtkDataObject *output) |
| virtual void | Execute () |
| virtual void | AllocateOutputData (vtkImageData *out, vtkInformation *outInfo, int *uExtent) |
| virtual vtkImageData * | AllocateOutputData (vtkDataObject *out, vtkInformation *outInfo) |
| virtual void | CopyAttributeData (vtkImageData *in, vtkImageData *out, vtkInformationVector **inputVector) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Filter that creates a transparent image from two input images.
This filter takes two inputs, one of which is a scene rendered with a white background and the other is the same scene rendered with a black background. It looks at co-located pixels from each input image. If they are not the same color, the pixel must have been from a transparent object. At such pixel locations in the inputs, the transparency value in the output image is derived from the difference of the HSV colors from the white- and black- background images.
The first input must be the white-background image and the second input must be the black-background image.
Definition at line 37 of file vtkImageTransparencyFilter.h.
