| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetVisibility (bool val) override |
| | Get/Set the visibility for this representation. More...
| void | SetOrientation (double, double, double) |
| void | SetOrigin (double, double, double) |
| void | SetPickable (int val) |
| void | SetPosition (double, double, double) |
| void | SetScale (double, double, double) |
| void | SetOpacity (double val) |
| void | SetLookupTable (vtkScalarsToColors *val) |
| void | SetMapScalars (int val) |
| void | SetUseXYPlane (int val) |
| vtkPVLODActor * | GetActor () |
| | Provides access to the actor used by this representation. More...
| void | SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, const char *name) override |
| | Set the input data arrays that this algorithm will process. More...
| void | SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, int fieldAttributeType) override |
| void | SetInputArrayToProcess (int idx, vtkInformation *info) override |
| void | SetInputArrayToProcess (int idx, int port, int connection, const char *fieldAssociation, const char *attributeTypeorName) override |
| virtual void | SetSlice (unsigned int) |
| | Get set the slice number to extract. More...
| virtual unsigned int | GetSlice () |
| virtual void | SetSliceMode (int) |
| | Get/Set the direction in which to slice a 3D input data. More...
| virtual int | GetSliceMode () |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkImageSliceRepresentation () |
| | ~vtkImageSliceRepresentation () override |
| void | UpdateSliceData (vtkInformationVector **) |
| | Extract the slice. More...
| | Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
