| virtual int * | GetWholeExtent () |
| | Set/Get the extent of the whole output image. More...
| virtual void | GetWholeExtent (int &, int &, int &, int &, int &, int &) |
| virtual void | GetWholeExtent (int [6]) |
| void | SetWholeExtent (int xMinx, int xMax, int yMin, int yMax, int zMin, int zMax) |
| virtual bool | GetEnableDistanceSquaredData () |
| | Enable/Disable DistanceSquared data array. More...
| virtual void | SetEnableDistanceSquaredData (bool) |
| virtual void | EnableDistanceSquaredDataOn () |
| virtual void | EnableDistanceSquaredDataOff () |
| virtual bool | GetEnableSwirlData () |
| | Enable/Disable Swirl data array. More...
| virtual void | SetEnableSwirlData (bool) |
| virtual void | EnableSwirlDataOn () |
| virtual void | EnableSwirlDataOff () |
| vtkThreadedImageAlgorithm * | NewInstance () const |
| virtual void | ThreadedExecute (vtkImageData *inData, vtkImageData *outData, int extent[6], int threadId) |
| virtual bool | GetEnableSMP () |
| virtual void | SetEnableSMP (bool) |
| virtual void | SetMinimumPieceSize (int, int, int) |
| virtual void | SetMinimumPieceSize (int[3]) |
| virtual int * | GetMinimumPieceSize () |
| virtual void | GetMinimumPieceSize (int &, int &, int &) |
| virtual void | GetMinimumPieceSize (int[3]) |
| virtual void | SetDesiredBytesPerPiece (vtkIdType) |
| virtual vtkIdType | GetDesiredBytesPerPiece () |
| virtual void | SetSplitMode (int) |
| void | SetSplitModeToSlab () |
| void | SetSplitModeToBeam () |
| void | SetSplitModeToBlock () |
| virtual int | GetSplitMode () |
| virtual void | SetNumberOfThreads (int) |
| virtual int | GetNumberOfThreads () |
| virtual int | SplitExtent (int splitExt[6], int startExt[6], int num, int total) |
| vtkImageAlgorithm * | NewInstance () const |
| vtkImageData * | GetOutput () |
| vtkImageData * | GetOutput (int) |
| vtkImageData * | GetImageDataInput (int port) |
| virtual void | AddInputData (vtkDataObject *) |
| virtual void | AddInputData (int, vtkDataObject *) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkImageSimpleSource () |
| | ~vtkImageSimpleSource () override |
| void | PrepareImageData (vtkInformationVector **inputVector, vtkInformationVector *outputVector, vtkImageData ***inDataObjects=nullptr, vtkImageData **outDataObjects=nullptr) override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| void | ThreadedRequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector, vtkImageData ***inData, vtkImageData **outData, int extent[6], int threadId) override |
| | vtkThreadedImageAlgorithm () |
| | ~vtkThreadedImageAlgorithm () |
| virtual int | RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| virtual void | SMPRequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector, vtkImageData ***inData, vtkImageData **outData, vtkIdType begin, vtkIdType end, vtkIdType pieces, int extent[6]) |
| | vtkImageAlgorithm () |
| | ~vtkImageAlgorithm () |
| virtual void | CopyInputArrayAttributesToOutput (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| virtual void | ExecuteDataWithInformation (vtkDataObject *output, vtkInformation *outInfo) |
| virtual void | ExecuteData (vtkDataObject *output) |
| virtual void | Execute () |
| virtual void | AllocateOutputData (vtkImageData *out, vtkInformation *outInfo, int *uExtent) |
| virtual vtkImageData * | AllocateOutputData (vtkDataObject *out, vtkInformation *outInfo) |
| virtual void | CopyAttributeData (vtkImageData *in, vtkImageData *out, vtkInformationVector **inputVector) |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Create a 3-D image with simple-to-compute pixel values.
vtkImageSimpleSource produces images with pixel values that can be obtained with relatively low computational load. The output point data contains 1-3 arrays:
- "X": A scalar double array labeled "X" is always generated. Its values are set to the X coordinate at each point.
- "DistanceSquared": A scalar double array labeled "DistanceSquared" is generated by default, but can be omitted by setting EnableDistanceSquaredData false. The values are set to the Euclidean distance of each point from the origin (X*X + Y*Y + Z*Z).
- "Swirl": A vector double array labeled "Swirl" is generated by default, but can be omitted by setting EnableSwirlData false. The values at each point are set to the <Y, Z, X> coordinates.
Definition at line 40 of file vtkImageSimpleSource.h.
