| void | IntegrateCellVolume (vtkCell *cell, int fragmentId, vtkUnstructuredGrid *input, vtkIdType cellIndex) |
| vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
| vtkMultiBlockDataSet * | GetOutput () |
| vtkMultiBlockDataSet * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkGridConnectivity () |
| | ~vtkGridConnectivity () override |
| void | GenerateOutput (vtkPolyData *output, vtkUnstructuredGrid *inputs[]) |
| int | FillInputPortInformation (int, vtkInformation *) override |
| int | CheckInput (vtkUnstructuredGrid *grid) |
| void | InitializeFaceHash (vtkUnstructuredGrid **inputs, int numberOfInputs) |
| void | InitializeIntegrationArrays (vtkUnstructuredGrid **inputs, int numberOfInputs) |
| double | IntegrateTetrahedron (vtkCell *tetra, vtkUnstructuredGrid *input, int fragmentId) |
| double | IntegrateHex (vtkCell *hex, vtkUnstructuredGrid *input, int fragmentId) |
| double | IntegrateVoxel (vtkCell *voxel, vtkUnstructuredGrid *input, int fragmentId) |
| double | IntegrateGeneral3DCell (vtkCell *cell, vtkUnstructuredGrid *input, int fragmentId) |
| double | ComputeTetrahedronVolume (double *pts0, double *pts1, double *pts2, double *pts3) |
| void | ComputePointIntegration (vtkUnstructuredGrid *input, vtkIdType pt0Id, vtkIdType pt1Id, vtkIdType pt2Id, vtkIdType pt3Id, double volume, int fragmentId) |
| void | ResolveIntegrationArrays () |
| void | ResolveFaceFragmentIds () |
| void | ResolveEquivalentFragments () |
| void | ResolveProcessesFaces () |
| void | CollectFacesAndArraysToRootProcess (int *fragmentIdMap, int *fragmentNumFaces) |
| | vtkMultiBlockDataSetAlgorithm () |
| | ~vtkMultiBlockDataSetAlgorithm () |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Integrates lines, surfaces and volume.
Integrates all point and cell data attributes while computing length, area or volume. Works for 1D, 2D or 3D. Only one dimensionality at a time. For volume, this filter ignores all but 3D cells. It will not compute the volume contained in a closed surface. The output of this filter is a single point and vertex. The attributes for this point and cell will contain the integration results for the corresponding input attributes.
Definition at line 48 of file vtkGridConnectivity.h.
