| virtual void | SetArrayName (const char *) |
| | Set the name of the array used to compute the range. More...
| virtual char * | GetArrayName () |
| virtual void | SetFieldType (int) |
| | Set/Get the field type of the selection. More...
| virtual int | GetFieldType () |
| virtual void | SetComponent (int) |
| | Set/Get the component used to compute the range. More...
| virtual int | GetComponent () |
| virtual double * | GetRange () |
| | Get the output range. More...
| virtual void | GetRange (double &, double &) |
| virtual void | GetRange (double [2]) |
| vtkTableAlgorithm * | NewInstance () const |
| vtkTable * | GetOutput () |
| vtkTable * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkExtractSelectionRange () |
| | ~vtkExtractSelectionRange () override |
| | vtkTableAlgorithm () |
| | ~vtkTableAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
compute the range of the input selection.
vtkExtractSelectionRange is used to compute the range of an input selection. This is an internal filter designed to be used to "compute visible range" for a dataset.
Definition at line 30 of file vtkExtractSelectionRange.h.
