| virtual void | SetXComponent (int) |
| | Controls which input data component should be binned, for input arrays with more-than-one component. More...
| virtual int | GetXComponent () |
| virtual void | SetYComponent (int) |
| virtual int | GetYComponent () |
| virtual void | SetXBinCount (int) |
| | Controls the number of bins along the X axis in the output histogram data. More...
| virtual int | GetXBinCount () |
| virtual void | SetYBinCount (int) |
| | Controls the number of bins along the Y axis in the output histogram data. More...
| virtual int | GetYBinCount () |
| vtkPolyDataAlgorithm * | NewInstance () const |
| vtkPolyData * | GetPolyDataInput (int port) |
| vtkPolyData * | GetOutput () |
| vtkPolyData * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | SINGLE_PRECISION |
| | DOUBLE_PRECISION |
| | DEFAULT_PRECISION |
| int | AbortExecute |
| | vtkPolyDataAlgorithm () |
| | ~vtkPolyDataAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
| static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
| vtkInformation * | Information |
| double | Progress |
| char * | ProgressText |
| vtkProgressObserver * | ProgressObserver |
| unsigned long | ErrorCode |
| static vtkExecutive * | DefaultExecutivePrototype |
Extract a scatter plot (two-dimensional histogram) from any dataset.
vtkExtractScatterPlot accepts any vtkDataSet as input and produces a vtkPolyData containing two-dimensional histogram data as output. The output vtkPolyData will contain two vtkDoubleArray instances named "x_bin_extents" and "y_bin_extents", which contain the boundaries between bins along each dimension. It will also contain a vtkUnsignedLongArray named "bin_values" which contains the value for each bin.
Definition at line 35 of file vtkExtractScatterPlot.h.
