| std::string | GetFilePath (unsigned int rowIndex) const |
| | Get the file path associated with the specified row of the meta data. More...
| void | SetReader (unsigned int rowIndex, vtkAlgorithm *reader) |
| | Set the file reader for the specified row of data. More...
| void | ResetReaders () |
| | Removes all readers set using SetReader(). More...
| bool | UpdateMetaData () |
| | Use this method to update the meta data, if needed. More...
| virtual void | SetFileName (const char *) |
| | Set/Get the filename of the ensemble (.pve extension). More...
| virtual char * | GetFileName () |
| virtual void | SetCurrentMember (unsigned int) |
| | Set/Get the current ensemble member to process. More...
| virtual unsigned int | GetCurrentMember () |
| unsigned int | GetNumberOfMembers () const |
| | Returns the number of ensemble members. More...
| virtual unsigned int * | GetCurrentMemberRange () |
| virtual void | GetCurrentMemberRange (unsigned int &, unsigned int &) |
| virtual void | GetCurrentMemberRange (unsigned int [2]) |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkEnsembleDataReader () |
| | ~vtkEnsembleDataReader () override |
| int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| vtkAlgorithm * | GetCurrentReader () |
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| virtual int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
reader for ensemble data sets
vtkEnsembleDataReader reads a collection of data sources from a metadata file (of extension .pve). 'pve' a simply CSV file with the last column being the relative filename and other columns for each of the variables in the ensemble.
Definition at line 33 of file vtkEnsembleDataReader.h.
