| virtual void | SetOutputDataSetType (int) |
| | Get/Set the output type produced by this filter. More...
| virtual int | GetOutputDataSetType () |
| virtual void | SetSubTreeCompositeIndex (unsigned int) |
| | Get/Set the composite index of the subtree to be merged. More...
| virtual unsigned int | GetSubTreeCompositeIndex () |
| virtual void | SetMergePoints (bool) |
| | Turn on/off merging of coincidental points. More...
| virtual bool | GetMergePoints () |
| virtual void | MergePointsOn () |
| virtual void | MergePointsOff () |
| virtual void | SetTolerance (double) |
| | Get/Set the tolerance to use to find coincident points when MergePoints is true. More...
| virtual double | GetTolerance () |
| virtual void | SetToleranceIsAbsolute (bool) |
| | Get/Set whether Tolerance is treated as an absolute or relative tolerance. More...
| virtual bool | GetToleranceIsAbsolute () |
| virtual void | ToleranceIsAbsoluteOn () |
| virtual void | ToleranceIsAbsoluteOff () |
| vtkPointSetAlgorithm * | NewInstance () const |
| vtkPointSet * | GetOutput () |
| vtkPointSet * | GetOutput (int) |
| void | SetInputData (vtkPointSet *) |
| void | SetInputData (int, vtkPointSet *) |
| void | AddInputData (vtkPointSet *) |
| void | AddInputData (int, vtkPointSet *) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkDataObjectTreeToPointSetFilter () |
| | ~vtkDataObjectTreeToPointSetFilter () override |
| int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| void | RemovePartialArrays (vtkDataSet *data) |
| | Remove point/cell arrays not present on all processes. More...
| void | ExecuteSubTree (vtkDataObjectTree *dot, vtkAppendDataSets *appender) |
| | vtkPointSetAlgorithm () |
| | ~vtkPointSetAlgorithm () |
| virtual int | ExecuteInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| virtual int | ComputeInputUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Filter that merges blocks from a data object tree to a vtkPolyData of vtkUnstructuredGrid.
This filter takes a vtkDataObjectTree as input and merges the blocks in the tree into a single output vtkUnstructuredGrid if the ExtractSurfaces option is off. If the ExtractSurfaces option is on, surfaces of non-vtkPolyData datasets in the input tree will be extracted and merged to the output with vtkPolyData datasets.
- Deprecated:
- ParaView 5.9. Please use vtkMergeBlocks instead.
Definition at line 38 of file vtkDataObjectTreeToPointSetFilter.h.
