| void | SetPointLabelVisibility (int) |
| void | SetPointFieldDataArrayName (const char *) |
| void | SetPointLabelMode (int) |
| void | SetPointLabelColor (double r, double g, double b) |
| void | SetPointLabelOpacity (double) |
| void | SetPointLabelFontFamily (int) |
| void | SetPointLabelFontFile (char *) |
| void | SetPointLabelBold (int) |
| void | SetPointLabelItalic (int) |
| void | SetPointLabelShadow (int) |
| void | SetPointLabelJustification (int) |
| void | SetPointLabelFontSize (int) |
| void | SetPointLabelFormat (const char *) |
| void | SetCellLabelVisibility (int) |
| void | SetCellFieldDataArrayName (const char *) |
| void | SetCellLabelMode (int) |
| void | SetCellLabelColor (double r, double g, double b) |
| void | SetCellLabelOpacity (double) |
| void | SetCellLabelFontFamily (int) |
| void | SetCellLabelFontFile (char *) |
| void | SetCellLabelBold (int) |
| void | SetCellLabelItalic (int) |
| void | SetCellLabelShadow (int) |
| void | SetCellLabelJustification (int) |
| void | SetCellLabelFontSize (int) |
| void | SetCellLabelFormat (const char *) |
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetVisibility (bool val) override |
| | Get/Set the visibility for this representation. More...
| bool | GetVisibility () override |
| void | SetMaximumNumberOfLabels (int numLabels) |
| | Get/Set the maximum number of points/cells that will be labeled. More...
| int | GetMaximumNumberOfLabels () |
| void | SetOrientation (double, double, double) |
| | Used to build the internal transform. More...
| void | SetOrigin (double, double, double) |
| void | SetPosition (double, double, double) |
| void | SetScale (double, double, double) |
| void | SetUserTransform (const double[16]) |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkDataLabelRepresentation () |
| | ~vtkDataLabelRepresentation () override |
| | Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
| void | UpdateTransform () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
