helper to convert Conduit arrays to VTK arrays. More...
#include <vtkConduitArrayUtilities.h>
| static vtkConduitArrayUtilities * | New () |
| static vtkConduitArrayUtilities * | SafeDownCast (vtkObject *o) |
| static vtkSmartPointer< vtkCellArray > | MCArrayToVTKCellArray (vtkIdType cellSize, const conduit_node *mcarray) |
| Converts an mcarray to vtkCellArray. More... | |
| static vtkSmartPointer< vtkDataArray > | SetNumberOfComponents (vtkDataArray *array, int num_components) |
| If the number of components in the array does not match the target, a new array is created. More... | |
| static vtkSmartPointer< vtkDataArray > | MCArrayToVTKArray (const conduit_node *mcarray) |
| Returns a vtkDataArray from a conduit node in the conduit mcarray protocol. More... | |
| static vtkSmartPointer< vtkDataArray > | MCArrayToVTKArray (const conduit_node *mcarray, const std::string &arrayname) |
| vtkConduitArrayUtilities () | |
| ~vtkConduitArrayUtilities () | |
Static Protected Member Functions | |
| static vtkSmartPointer< vtkDataArray > | MCArrayToVTKArrayImpl (const conduit_node *mcarray, bool force_signed) |
| static vtkSmartPointer< vtkDataArray > | MCArrayToVTKAOSArray (const conduit_node *mcarray, bool force_signed) |
| static vtkSmartPointer< vtkDataArray > | MCArrayToVTKSOAArray (const conduit_node *mcarray, bool force_signed) |
vtkConduitArrayUtilities is intended to convert Conduit nodes satisfying the mcarray protocol to VTK arrays. It uses zero-copy, as much as possible. Currently implementation fails if zero-copy is not possible. In future, that may be changed to do a deep-copy (with appropriate warnings) if necessary.
This is primarily designed for use by vtkConduitSource.
Definition at line 43 of file vtkConduitArrayUtilities.h.
Definition at line 47 of file vtkConduitArrayUtilities.h.
This may reinterpret unsigned array as signed arrays to avoid deep-copying of data to match data type expected by vtkCellArray API.
staticprotected |
staticprotected |
staticprotected |
