combine multiple representations into one with only 1 representation active at a time.
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetVisibility (bool val) override |
| | Methods overridden to propagate to the active representation. More...
| vtkPVDataRepresentation * | GetActiveRepresentation () |
| | Returns the active representation if valid. More...
| void | SetSelectionConnection (vtkAlgorithmOutput *input) |
| | Set the selection connection. More...
| | Propagate the modification to all internal representations. More...
| vtkDataObject * | GetRenderedDataObject (int port) override |
| vtkStringArray * | GetRepresentationTypes () |
| | Returns the list of available representation types as a string array. More...
| virtual void | AddRepresentation (const char *key, vtkPVDataRepresentation *repr) |
| | Add/Remove representations. More...
| virtual void | RemoveRepresentation (vtkPVDataRepresentation *repr) |
| virtual void | RemoveRepresentation (const char *key) |
| void | SetActiveRepresentation (const char *key) |
| | Set the active key. More...
| const char * | GetActiveRepresentationKey () |
| | Overridden to simply pass the input to the internal representations. More...
| void | SetInputConnection (vtkAlgorithmOutput *input) override |
| void | AddInputConnection (vtkAlgorithmOutput *input) override |
| void | RemoveInputConnection (int port, vtkAlgorithmOutput *input) override |
| void | RemoveInputConnection (int port, int idx) override |
| void | SetUpdateTime (double time) override |
| | Passed on to internal representations as well. More...
| void | SetForceUseCache (bool val) override |
| void | SetForcedCacheKey (double val) override |
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkCompositeRepresentation () |
| | ~vtkCompositeRepresentation () override |
| int | FillInputPortInformation (int, vtkInformation *info) override |
| void | TriggerUpdateDataEvent () |
| | Fires UpdateDataEvent. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
