| virtual void | SetSubTreeCompositeIndex (unsigned int) |
| | Get/Set the composite index of the subtree to be merged. More...
| virtual unsigned int | GetSubTreeCompositeIndex () |
| virtual void | SetMergePoints (bool) |
| | Turn on/off merging of coincidental points. More...
| virtual bool | GetMergePoints () |
| virtual void | MergePointsOn () |
| virtual void | MergePointsOff () |
| virtual void | SetTolerance (double) |
| | Get/Set the tolerance to use to find coincident points when MergePoints is true. More...
| virtual double | GetTolerance () |
| vtkUnstructuredGridAlgorithm * | NewInstance () const |
| vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
| vtkUnstructuredGrid * | GetOutput () |
| vtkUnstructuredGrid * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkCompositeDataToUnstructuredGridFilter () |
| | ~vtkCompositeDataToUnstructuredGridFilter () override |
| | This is called by the superclass. More...
| void | RemovePartialArrays (vtkUnstructuredGrid *data) |
| | Remove point/cell arrays not present on all processes. More...
| void | AddDataSet (vtkDataSet *ds, vtkAppendFilter *appender) |
| void | ExecuteSubTree (vtkCompositeDataSet *cd, vtkAppendFilter *output) |
| | vtkUnstructuredGridAlgorithm () |
| | ~vtkUnstructuredGridAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
appends all vtkUnstructuredGrid leaves of the input composite dataset to a single vtkUnstructuredGrid.
vtkCompositeDataToUnstructuredGridFilter appends all vtkUnstructuredGrid leaves of the input composite dataset to a single unstructure grid. The subtree to be combined can be chosen using the SubTreeCompositeIndex. If the SubTreeCompositeIndex is a leaf node, then no appending is required.
- Deprecated:
- ParaView 5.9. Please use vtkMergeBlocks instead.
Definition at line 41 of file vtkCompositeDataToUnstructuredGridFilter.h.
