This is composite animation player that can me made to play an animation using the active player.
| void | SetNumberOfFrames (int val) |
| | Forwarded to vtkSequenceAnimationPlayer. More...
| void | SetDuration (int val) |
| | Forwarded to vtkRealtimeAnimationPlayer. More...
| virtual void | SetPlayMode (int) |
| | Get/Set the play mode. More...
| virtual int | GetPlayMode () |
| void | AddTimeStep (double val) |
| | Forwarded to vtkTimestepsAnimationPlayer. More...
| void | RemoveAllTimeSteps () |
| void | SetFramesPerTimestep (int val) |
| void | Play () |
| | Start playing the animation. More...
| void | Stop () |
| | Stop playing the animation. More...
| int | IsInPlay () |
| | Returns if the animation is currently playing. More...
| virtual bool | GetInPlay () |
| void | GoToNext () |
| | Take the animation scene to next frame. More...
| void | GoToPrevious () |
| | Take animation scene to previous frame. More...
| void | GoToFirst () |
| | Take animation scene to first frame. More...
| void | GoToLast () |
| | Take animation scene to last frame. More...
| virtual void | SetAnimationScene (vtkSMAnimationScene *) |
| | Set the animation scene that is to be played by this player. More...
| vtkSMAnimationScene * | GetAnimationScene () |
| virtual void | SetLoop (bool) |
| | Set to true to play the animation in a loop. More...
| virtual bool | GetLoop () |
| | vtkCompositeAnimationPlayer () |
| | ~vtkCompositeAnimationPlayer () override |
| double | GoToNext (double start, double end, double currenttime) override |
| double | GoToPrevious (double start, double end, double currenttime) override |
| vtkAnimationPlayer * | GetActivePlayer () |
| void | StartLoop (double starttime, double endtime, double curtime, double *playbackWindow) override |
| | Delegated to the active animation player. More...
| void | EndLoop () override |
| double | GetNextTime (double currentime) override |
| | vtkAnimationPlayer () |
| | ~vtkAnimationPlayer () override |
| | vtkObject () |
| | vtkObjectBase () |
It provides API to add animation players and then set one of them as the active one.
Definition at line 33 of file vtkCompositeAnimationPlayer.h.
