| void | SetController (vtkMultiProcessController *controller) |
| | The user can set the controller used for inter-process communication. More...
| virtual vtkMultiProcessController * | GetController () |
| vtkDataSetAlgorithm * | NewInstance () const |
| vtkDataSet * | GetOutput () |
| vtkDataSet * | GetOutput (int) |
| void | SetInputData (vtkDataSet *) |
| void | SetInputData (int, vtkDataSet *) |
| void | AddInputData (vtkDataSet *) |
| void | AddInputData (int, vtkDataSet *) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkCompleteArrays () |
| | ~vtkCompleteArrays () override |
| | Set the input type of the algorithm to vtkDataSet and vtkTable. More...
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| | Set the output type of the algorithm to vtkDataObject. More...
| int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | Generate an output of the same type as the input. More...
| void | CompleteArraysOnBlock (vtkDataSet *inputDS, vtkDataSet *&outputDS) |
| | Complete the arrays on one block. More...
| | vtkDataSetAlgorithm () |
| | ~vtkDataSetAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Filter adds arrays to empty partitions.
This is a temporary solution for fixing a writer bug. When partition 0 has no cells or points, it does not have arrays either. The writers get confused. This filter creates empty arrays on node zero if there are no cells or points in that partition. This filter can also handle vtkTable by letting them pass through it without modification.
Definition at line 35 of file vtkCompleteArrays.h.
