vtkCPUniformGridBuilder Class Reference
Class for creating uniform grids. More...
#include <vtkCPUniformGridBuilder.h>
Inheritance diagram for vtkCPUniformGridBuilder:
Collaboration diagram for vtkCPUniformGridBuilder:
typedef vtkCPGridBuilder Superclass
- Public Types inherited from vtkCPGridBuilder
typedef vtkCPBaseGridBuilder Superclass
- Public Types inherited from vtkCPBaseGridBuilder
virtual vtkDataObjectGetGrid (unsigned long timeStep, double time, int &builtNewGrid) override
 Return a grid. More...
vtkUniformGridGetUniformGrid ()
 Get the UniformGrid. More...
bool CreateUniformGrid ()
 Create UniformGrid with the current parameters. More...
virtual void SetDimensions (int, int, int)
 Set/get the Dimensions of the uniform grid. More...
virtual void SetDimensions (int [3])
intGetDimensions ()
virtual void SetSpacing (double, double, double)
virtual void SetSpacing (double [3])
doubleGetSpacing ()
virtual void SetOrigin (double, double, double)
virtual void SetOrigin (double [3])
doubleGetOrigin ()
- Public Member Functions inherited from vtkCPGridBuilder
void SetFieldBuilder (vtkCPBaseFieldBuilder *fieldBuilder)
 Set/get the FieldBuilder. More...
vtkCPBaseFieldBuilderGetFieldBuilder ()
static vtkCPUniformGridBuilderNew ()
static vtkCPUniformGridBuilderSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPGridBuilder
static vtkCPGridBuilderSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPBaseGridBuilder
static vtkCPBaseGridBuilderSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkCPUniformGridBuilder ()
 ~vtkCPUniformGridBuilder ()
- Protected Member Functions inherited from vtkCPGridBuilder
 vtkCPGridBuilder ()
 ~vtkCPGridBuilder ()
- Protected Member Functions inherited from vtkCPBaseGridBuilder
 vtkCPBaseGridBuilder ()
 ~vtkCPBaseGridBuilder ()
Class for creating vtkUniformGrids for a test driver.
Definition at line 31 of file vtkCPUniformGridBuilder.h.
Definition at line 35 of file vtkCPUniformGridBuilder.h.
◆ vtkCPUniformGridBuilder()
vtkCPUniformGridBuilder::vtkCPUniformGridBuilder ( )
◆ ~vtkCPUniformGridBuilder()
vtkCPUniformGridBuilder::~vtkCPUniformGridBuilder ( )
static vtkCPUniformGridBuilder* vtkCPUniformGridBuilder::New ( )
virtual const char* vtkCPUniformGridBuilder::GetClassName ( )
Reimplemented from vtkCPGridBuilder.
static int vtkCPUniformGridBuilder::IsTypeOf ( const char *  type)
virtual int vtkCPUniformGridBuilder::IsA ( const char *  type)
static vtkCPUniformGridBuilder* vtkCPUniformGridBuilder::SafeDownCast ( vtkObject o)
void vtkCPUniformGridBuilder::PrintSelf ( ostream &  os,
◆ GetGrid()
virtual vtkDataObject* vtkCPUniformGridBuilder::GetGrid ( unsigned long  timeStep,
double  time,
int builtNewGrid
Return a grid.
BuiltNewGrid is set to 0 if the grids that were returned were already built before. vtkCPUniformGridBuilder will also delete the grid.
Implements vtkCPGridBuilder.
◆ SetDimensions() [1/2]
virtual void vtkCPUniformGridBuilder::SetDimensions ( int  ,
int  ,
int
◆ SetDimensions() [2/2]
virtual void vtkCPUniformGridBuilder::SetDimensions ( int  [3])
◆ GetDimensions()
int* vtkCPUniformGridBuilder::GetDimensions ( )
◆ SetSpacing() [1/2]
virtual void vtkCPUniformGridBuilder::SetSpacing ( double  ,
double  ,
double
◆ SetSpacing() [2/2]
virtual void vtkCPUniformGridBuilder::SetSpacing ( double  [3])
◆ GetSpacing()
double* vtkCPUniformGridBuilder::GetSpacing ( )
◆ SetOrigin() [1/2]
virtual void vtkCPUniformGridBuilder::SetOrigin ( double  ,
double  ,
double
◆ SetOrigin() [2/2]
virtual void vtkCPUniformGridBuilder::SetOrigin ( double  [3])
◆ GetOrigin()
double* vtkCPUniformGridBuilder::GetOrigin ( )
◆ GetUniformGrid()
vtkUniformGrid* vtkCPUniformGridBuilder::GetUniformGrid ( )
◆ CreateUniformGrid()
bool vtkCPUniformGridBuilder::CreateUniformGrid ( )
Returns true if a new grid was created and false otherwise.
