vtkCPTestDriver Class Reference
Class for creating a co-processor test driver. More...
#include <vtkCPTestDriver.h>
Inheritance diagram for vtkCPTestDriver:
Collaboration diagram for vtkCPTestDriver:
virtual int Run ()
 Run the test driver. More...
virtual double GetTime (unsigned long timeStep)
 Given a TimeStep, return the simulation time corresponding to that time step. More...
virtual void SetNumberOfTimeSteps (unsigned long)
 Set/get NumberOfTimeSteps. More...
virtual unsigned long GetNumberOfTimeSteps ()
void SetGridBuilder (vtkCPBaseGridBuilder *gridBuilder)
 Set/get GridBuilder. More...
vtkCPBaseGridBuilderGetGridBuilder ()
virtual void SetStartTime (double)
 Set/get the start and end times of the simulation. More...
virtual double GetStartTime ()
virtual void SetEndTime (double)
virtual double GetEndTime ()
static vtkCPTestDriverNew ()
static vtkCPTestDriverSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkCPTestDriver ()
 ~vtkCPTestDriver ()
Class for creating a co-processor test driver. It is intended as a framework for creating custom inputs replicating a simulation for the co-processing library.
Definition at line 32 of file vtkCPTestDriver.h.
Definition at line 36 of file vtkCPTestDriver.h.
◆ vtkCPTestDriver()
vtkCPTestDriver::vtkCPTestDriver ( )
◆ ~vtkCPTestDriver()
vtkCPTestDriver::~vtkCPTestDriver ( )
static vtkCPTestDriver* vtkCPTestDriver::New ( )
virtual const char* vtkCPTestDriver::GetClassName ( )
static int vtkCPTestDriver::IsTypeOf ( const char *  type)
virtual int vtkCPTestDriver::IsA ( const char *  type)
static vtkCPTestDriver* vtkCPTestDriver::SafeDownCast ( vtkObject o)
void vtkCPTestDriver::PrintSelf ( ostream &  os,
◆ Run()
virtual int vtkCPTestDriver::Run ( )
Returns 0 if there were no errors.
◆ SetNumberOfTimeSteps()
virtual void vtkCPTestDriver::SetNumberOfTimeSteps ( unsigned  long)
◆ GetNumberOfTimeSteps()
virtual unsigned long vtkCPTestDriver::GetNumberOfTimeSteps ( )
◆ GetTime()
virtual double vtkCPTestDriver::GetTime ( unsigned long  timeStep)
This implementation has constant time steps between StartTime and EndTime.
◆ SetGridBuilder()
void vtkCPTestDriver::SetGridBuilder ( vtkCPBaseGridBuilder gridBuilder)
◆ GetGridBuilder()
vtkCPBaseGridBuilder* vtkCPTestDriver::GetGridBuilder ( )
◆ SetStartTime()
virtual void vtkCPTestDriver::SetStartTime ( double  )
◆ GetStartTime()
virtual double vtkCPTestDriver::GetStartTime ( )
◆ SetEndTime()
virtual void vtkCPTestDriver::SetEndTime ( double  )
◆ GetEndTime()
virtual double vtkCPTestDriver::GetEndTime ( )
