vtkCPMultiBlockGridBuilder Class Reference
Class for creating multiblock grids. More...
#include <vtkCPMultiBlockGridBuilder.h>
Inheritance diagram for vtkCPMultiBlockGridBuilder:
Collaboration diagram for vtkCPMultiBlockGridBuilder:
typedef vtkCPBaseGridBuilder Superclass
- Public Types inherited from vtkCPBaseGridBuilder
virtual vtkDataObjectGetGrid (unsigned long timeStep, double time, int &builtNewGrid) override
 Return a grid. More...
vtkMultiBlockDataSetGetGrid ()
 Get the Grid. More...
void AddGridBuilder (vtkCPGridBuilder *gridBuilder)
 Add a vtkCPGridBuilder. More...
void RemoveGridBuilder (vtkCPGridBuilder *gridBuilder)
 Remove a vtkCPGridBuilder. More...
void RemoveAllGridBuilders ()
 Clear out all of the current vtkCPGridBuilders. More...
unsigned int GetNumberOfGridBuilders ()
 Get the number of vtkCPGridBuilders. More...
vtkCPGridBuilderGetGridBuilder (unsigned int which)
 Get a specific vtkCPGridBuilder. More...
static vtkCPMultiBlockGridBuilderNew ()
static vtkCPMultiBlockGridBuilderSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPBaseGridBuilder
static vtkCPBaseGridBuilderSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkCPMultiBlockGridBuilder ()
 ~vtkCPMultiBlockGridBuilder ()
void SetGrid (vtkMultiBlockDataSet *multiBlock)
 Set the Grid. More...
- Protected Member Functions inherited from vtkCPBaseGridBuilder
 vtkCPBaseGridBuilder ()
 ~vtkCPBaseGridBuilder ()
Class for creating vtkMultiBlockDataSet grids for a test driver.
Definition at line 33 of file vtkCPMultiBlockGridBuilder.h.
Definition at line 37 of file vtkCPMultiBlockGridBuilder.h.
◆ vtkCPMultiBlockGridBuilder()
vtkCPMultiBlockGridBuilder::vtkCPMultiBlockGridBuilder ( )
◆ ~vtkCPMultiBlockGridBuilder()
vtkCPMultiBlockGridBuilder::~vtkCPMultiBlockGridBuilder ( )
static vtkCPMultiBlockGridBuilder* vtkCPMultiBlockGridBuilder::New ( )
virtual const char* vtkCPMultiBlockGridBuilder::GetClassName ( )
Reimplemented from vtkCPBaseGridBuilder.
static int vtkCPMultiBlockGridBuilder::IsTypeOf ( const char *  type)
virtual int vtkCPMultiBlockGridBuilder::IsA ( const char *  type)
static vtkCPMultiBlockGridBuilder* vtkCPMultiBlockGridBuilder::SafeDownCast ( vtkObject o)
void vtkCPMultiBlockGridBuilder::PrintSelf ( ostream &  os,
◆ GetGrid() [1/2]
virtual vtkDataObject* vtkCPMultiBlockGridBuilder::GetGrid ( unsigned long  timeStep,
double  time,
int builtNewGrid
Return a grid.
BuiltNewGrid is 0 if the grid is the same as the last time step.
Implements vtkCPBaseGridBuilder.
◆ GetGrid() [2/2]
vtkMultiBlockDataSet* vtkCPMultiBlockGridBuilder::GetGrid ( )
Get the Grid.
◆ AddGridBuilder()
void vtkCPMultiBlockGridBuilder::AddGridBuilder ( vtkCPGridBuilder gridBuilder)
◆ RemoveGridBuilder()
void vtkCPMultiBlockGridBuilder::RemoveGridBuilder ( vtkCPGridBuilder gridBuilder)
◆ RemoveAllGridBuilders()
void vtkCPMultiBlockGridBuilder::RemoveAllGridBuilders ( )
◆ GetNumberOfGridBuilders()
unsigned int vtkCPMultiBlockGridBuilder::GetNumberOfGridBuilders ( )
◆ GetGridBuilder()
vtkCPGridBuilder* vtkCPMultiBlockGridBuilder::GetGridBuilder ( unsigned int  which)
◆ SetGrid()
void vtkCPMultiBlockGridBuilder::SetGrid ( vtkMultiBlockDataSet multiBlock)
Set the Grid.
