Reduces cell/point attribute data with different modes to combine cell/point data.
| virtual void | SetAttributeType (int) |
| virtual int | GetAttributeType () |
| virtual void | SetReductionType (int) |
| virtual int | GetReductionType () |
| const char * | GetReductionTypeAsString () |
| void | SetReductionTypeToAdd () |
| void | SetReductionTypeToMax () |
| void | SetReductionTypeToMin () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkAttributeDataReductionFilter () |
| | ~vtkAttributeDataReductionFilter () override |
| int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | This is called by the superclass. More...
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Filter that takes data with same structure on multiple input connections to produce a reduced dataset with cell/point data summed/maxed/minned for all cells/points. Data arrays not available in all inputs are discarded. The attribute to reduce can be set to point or cell or field or all. Only selected attributes will be reduced according to the type chosen, all other attributes are those at the first input.
Definition at line 34 of file vtkAttributeDataReductionFilter.h.
