| virtual void | SetFieldArrayName (const char *) |
| | Name of the field to display. More...
| virtual char * | GetFieldArrayName () |
| virtual void | SetPrefix (const char *) |
| | Set the text prefix to display in front of the Field value. More...
| virtual char * | GetPrefix () |
| virtual void | SetPostfix (const char *) |
| virtual char * | GetPostfix () |
| virtual void | SetFormat (const char *) |
| | Set the format to use when displaying the field value. More...
| virtual char * | GetFormat () |
| void | SetController (vtkMultiProcessController *) |
| | Get/Set the controller to use. More...
| virtual vtkMultiProcessController * | GetController () |
| vtkTableAlgorithm * | NewInstance () const |
| vtkTable * | GetOutput () |
| vtkTable * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkAnnotateGlobalDataFilter () |
| | ~vtkAnnotateGlobalDataFilter () override |
| | vtkTableAlgorithm () |
| | ~vtkTableAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
filter for annotating with global / field data
vtkAnnotateGlobalDataFilter is a filter that can be used to generate a vtkTable with a string that contains the contents of a global / field data array. It also supports extracting temporal field data arrays that vtkExodusIIReader produces for "global-data". These are simply arrays that have as many tuples are number of timesteps. The filter then extracts only the tuple associated with the current time-step.
Definition at line 35 of file vtkAnnotateGlobalDataFilter.h.
