pqTransferFunctionWidget provides a widget that can edit the control points in a vtkPiecewiseFunction or a vtkScalarsToColors (or subclass) or both.
#include <pqTransferFunctionWidget.h>
Inherits QWidget.
It is used by pqColorOpacityEditorWidget, for example, to show transfer function editors for color and opacity for a PVLookupTable proxy.
Definition at line 49 of file pqTransferFunctionWidget.h.
◆ pqTransferFunctionWidget()
| pqTransferFunctionWidget::pqTransferFunctionWidget |
QWidget * |
parent = 0 | ) |
◆ ~pqTransferFunctionWidget()
| pqTransferFunctionWidget::~pqTransferFunctionWidget |
◆ initialize()
Initialize the pqTransferFunctionWidget with the given color-transfer-function and piecewise-function (either of which can be null).
The editable flags are used to control if the users should be allowed to edit/change the particular transfer function.
◆ currentPoint()
| vtkIdType pqTransferFunctionWidget::currentPoint |
const |
Returns the current point index.
-1 is none is selected.
◆ numberOfControlPoints()
| vtkIdType pqTransferFunctionWidget::numberOfControlPoints |
const |
Returns the number of control points in the editor widget.
◆ SetLogScaleXAxis()
| void pqTransferFunctionWidget::SetLogScaleXAxis |
bool |
logScale | ) |
Switches the chart to use a log scaled X axis.
◆ GetLogScaleXAxis()
| bool pqTransferFunctionWidget::GetLogScaleXAxis |
const |
◆ scalarsToColors()
◆ piecewiseFunction()
◆ SetControlPointsFreehandDrawing()
| void pqTransferFunctionWidget::SetControlPointsFreehandDrawing |
bool |
use | ) |
Set/Get the use of freehand drawing for the control points.
◆ GetControlPointsFreehandDrawing()
| bool pqTransferFunctionWidget::GetControlPointsFreehandDrawing |
const |
◆ setCurrentPoint
| void pqTransferFunctionWidget::setCurrentPoint |
vtkIdType |
index | ) |
slot |
Set the current point.
Set to -1 clear the current point.
◆ setCurrentPointPosition
| void pqTransferFunctionWidget::setCurrentPointPosition |
double |
xpos | ) |
slot |
Set the X-position for the current point (without changing the Y position, if applicable.
We ensure that the point doesn't move past neighbouring points. Note this will not change the end points i.e. start and end points.
◆ render
| void pqTransferFunctionWidget::render |
slot |
re-renders the transfer function view.
This doesn't render immediately, schedules a render.
◆ setHistogramTable
| void pqTransferFunctionWidget::setHistogramTable |
vtkTable * |
table | ) |
slot |
Set the histogram table to display as a plot bar.
If set to nullptr, a simple color texture is used, the default.
◆ currentPointChanged
| void pqTransferFunctionWidget::currentPointChanged |
vtkIdType |
index | ) |
signal |
signal fired when the current selected control point changes.
◆ controlPointsModified
| void pqTransferFunctionWidget::controlPointsModified |
signal |
signal fired to indicate that the control points changed i.e.
either they were moved, orone was added/deleted, or edited to change color, etc.
◆ chartRangeModified
| void pqTransferFunctionWidget::chartRangeModified |
signal |
signal fired when the chart range is modified.
◆ rangeHandlesRangeChanged
| void pqTransferFunctionWidget::rangeHandlesRangeChanged |
double |
rangeMin, |
double |
rangeMax |
signal |
signal fired when the range handles changed the range.
◆ rangeHandlesDoubleClicked
| void pqTransferFunctionWidget::rangeHandlesDoubleClicked |
signal |
signal fired when the range handles are double clicked.
◆ onCurrentChangedEvent
| void pqTransferFunctionWidget::onCurrentChangedEvent |
protectedslot |
◆ onRangeHandlesRangeChanged
| void pqTransferFunctionWidget::onRangeHandlesRangeChanged |
protectedslot |
slot called when the internal vtkRangeHandlesItem fires a vtkRangeHandlesItem::RangeHandlesRangeChanged
◆ showUsageStatus
| void pqTransferFunctionWidget::showUsageStatus |
protectedslot |
Show usage info in the application status bar.
◆ onCurrentPointEditEvent()
| void pqTransferFunctionWidget::onCurrentPointEditEvent |
