pqSpreadSheetViewWidget is a QTableView subclass that is used by pqSpreadSheetView as the widget showing the data.
#include <pqSpreadSheetViewWidget.h>
Inherits QTableView.
Although it's called a 'Widget' it's not a QTableWidget but a QTableView subclass. It works with a pqSpreadSheetViewModel to show raw data delivered by the vtkSMSpreadSheetRepresentationProxy.
pqSpreadSheetViewWidget uses an internal QItemDelegate subclass to handle determining of the active viewport as well as showing multi-component arrays. Users are advised not to change the item delegate on the view.
Definition at line 51 of file pqSpreadSheetViewWidget.h.
◆ pqSpreadSheetViewWidget()
| pqSpreadSheetViewWidget::pqSpreadSheetViewWidget |
QWidget * |
parent = 0 | ) |
◆ ~pqSpreadSheetViewWidget()
| pqSpreadSheetViewWidget::~pqSpreadSheetViewWidget |
◆ setModel()
| void pqSpreadSheetViewWidget::setModel |
QAbstractItemModel * |
model | ) |
◆ spreadSheetViewModel()
Returns the spread sheetview model for this view.
◆ onSortIndicatorChanged
| void pqSpreadSheetViewWidget::onSortIndicatorChanged |
int |
section, |
Qt::SortOrder |
order |
protectedslot |
called when a header section is clicked in order to be sorted.
It results in that column being sorted if possible.
◆ onHeaderDataChanged
| void pqSpreadSheetViewWidget::onHeaderDataChanged |
protectedslot |
called when header data changes.
We ensure that internal columns stay hidden.
◆ paintEvent()
| void pqSpreadSheetViewWidget::paintEvent |
QPaintEvent * |
event | ) |
