pqProxySILModel is a proxy model for pqSILModel.
#include <pqProxySILModel.h>
Inherits QAbstractProxyModel.
| | pqProxySILModel (const QString &hierarchyName, QObject *parent=0) |
| | ~pqProxySILModel () override |
| QModelIndex | mapFromSource (const QModelIndex &sourceIndex) const override |
| | Methods from QAbstractProxyModel. More...
| QModelIndex | mapToSource (const QModelIndex &proxyIndex) const override |
| void | setSourceModel (QAbstractItemModel *sourceModel) override |
| QVariant | headerData (int, Qt::Orientation, int role=Qt::DisplayRole) const override |
| | Overridden to return the same name as the hierarchy. More...
| bool | setHeaderData (int section, Qt::Orientation orientation, const QVariant &value, int role=Qt::EditRole) override |
| | overridden to handle toggling of check state. More...
| QVariant | data (const QModelIndex &proxyIndex, int role=Qt::DisplayRole) const override |
| | Overridden to provide a means of turning off checkboxes. More...
| Qt::ItemFlags | flags (const QModelIndex &index) const override |
| | overridden to allow us to turn off checkboxes in the flags returned from the model More...
| QList< QVariant > | values () const |
| | Get the status values for the hierarchy. More...
| void | setNoCheckBoxes (bool val) |
| | Checkboxes for each item can be disabled by setting this flag. More...
| void | setHeaderTitle (QString &title) |
| | Override the display of the title in the header with this string. More...
| int | rowCount (const QModelIndex &theParent=QModelIndex()) const override |
| | Gets the number of rows for a given index. More...
| int | columnCount (const QModelIndex &theParent=QModelIndex()) const override |
| | Gets the number of columns for a given index. More...
| bool | hasChildren (const QModelIndex &theParent=QModelIndex()) const override |
| | Gets whether or not the given index has child items. More...
| QModelIndex | index (int row, int column, const QModelIndex &theParent=QModelIndex()) const override |
| | Gets a model index for a given location. More...
| QModelIndex | parent (const QModelIndex &theIndex) const override |
| | Gets the parent for a given index. More...
| bool | setData (const QModelIndex &theIndex, const QVariant &value, int role=Qt::EditRole) override |
| | Sets the role data for the item at index to value. More...
This makes it possible for tree views to show only a sub-tree in the SIL. This provides API to get/set status values which is useful for property linking using pqPropertyManager or pqPropertyLinks.
Definition at line 47 of file pqProxySILModel.h.
◆ pqProxySILModel()
| pqProxySILModel::pqProxySILModel |
const QString & |
hierarchyName, |
QObject * |
parent = 0 |
◆ ~pqProxySILModel()
| pqProxySILModel::~pqProxySILModel |
◆ rowCount()
| int pqProxySILModel::rowCount |
const QModelIndex & |
theParent = QModelIndex() | ) |
const |
inlineoverride |
- Parameters
| theParent | The parent index. |
- Returns
- The number of rows for the given index.
Definition at line 68 of file pqProxySILModel.h.
◆ columnCount()
| int pqProxySILModel::columnCount |
const |
inlineoverride |
- Parameters
- Returns
- The number of columns for the given index.
Definition at line 80 of file pqProxySILModel.h.
◆ hasChildren()
| bool pqProxySILModel::hasChildren |
const |
inlineoverride |
- Parameters
- Returns
- True if the given index has child items.
Definition at line 92 of file pqProxySILModel.h.
◆ index()
| QModelIndex pqProxySILModel::index |
int |
row, |
int |
column, |
| const |
inlineoverride |
- Parameters
| row | The row number. |
| column | The column number. |
- Returns
- A model index for the given location.
Definition at line 106 of file pqProxySILModel.h.
◆ parent()
| QModelIndex pqProxySILModel::parent |
theIndex | ) |
const |
inlineoverride |
- Parameters
- Returns
- A model index for the parent of the given index.
Definition at line 120 of file pqProxySILModel.h.
◆ setData()
| bool pqProxySILModel::setData |
theIndex, |
const QVariant & |
value, |
int |
role = Qt::EditRole |
inlineoverride |
Returns true if successful; otherwise returns false.
Definition at line 131 of file pqProxySILModel.h.
◆ mapFromSource()
| QModelIndex pqProxySILModel::mapFromSource |
sourceIndex | ) |
const |
◆ mapToSource()
| QModelIndex pqProxySILModel::mapToSource |
proxyIndex | ) |
const |
◆ setSourceModel()
| void pqProxySILModel::setSourceModel |
QAbstractItemModel * |
sourceModel | ) |
◆ headerData()
| QVariant pqProxySILModel::headerData |
int |
Qt::Orientation |
int |
role = Qt::DisplayRole |
| const |
Also overridden to handle Qt::CheckStateRole for pqHeaderView to support toggling column checkstate from the header.
◆ setHeaderData()
| bool pqProxySILModel::setHeaderData |
int |
section, |
Qt::Orientation |
orientation, |
const QVariant & |
value, |
int |
◆ data()
| QVariant pqProxySILModel::data |
proxyIndex, |
int |
| const |
◆ flags()
| Qt::ItemFlags pqProxySILModel::flags |
index | ) |
const |
◆ values()
| QList<QVariant> pqProxySILModel::values |
const |
◆ setNoCheckBoxes()
| void pqProxySILModel::setNoCheckBoxes |
bool |
val | ) |
◆ setHeaderTitle()
| void pqProxySILModel::setHeaderTitle |
QString & |
title | ) |
◆ setValues
| void pqProxySILModel::setValues |
const QList< QVariant > & |
slot |
Set the status values for the hierarchy.
◆ valuesChanged
| void pqProxySILModel::valuesChanged |
signal |
◆ sourceDataChanged
| void pqProxySILModel::sourceDataChanged |
idx1, |
idx2 |
inlineprotectedslot |
◆ onCheckStatusChanged
| void pqProxySILModel::onCheckStatusChanged |
protectedslot |
◆ values
readwrite |
