pqPipelineBrowserWidget is the widget for the pipeline browser. More...
#include <pqPipelineBrowserWidget.h>
Public Slots | |
| void | setActiveView (pqView *) |
| Set the active view. More... | |
Public Slots inherited from pqFlatTreeView | |
| void | reset () |
| void | selectAll () |
| void | setCurrentIndex (const QModelIndex &index) |
| void | expandAll () |
| void | expand (const QModelIndex &index) |
| void | collapse (const QModelIndex &index) |
| void | scrollTo (const QModelIndex &index) |
Signals | |
| void | deleteKey () |
| Fired when the delete key is pressed. More... | |
Signals inherited from pqFlatTreeView | |
| void | activated (const QModelIndex &index) |
| void | clicked (const QModelIndex &index) |
| pqPipelineBrowserWidget (QWidget *parent=0) | |
| ~pqPipelineBrowserWidget () override | |
| bool | eventFilter (QObject *object, QEvent *e) override |
| Used to monitor the key press events in the tree view. More... | |
| void | setSelectionVisibility (bool visible) |
| Set the visibility of selected items. More... | |
| void | enableAnnotationFilter (const QString &annotationKey) |
| Set Annotation filter to use. More... | |
| void | disableAnnotationFilter () |
| Disable any Annotation filter. More... | |
| void | setAnnotationFilterMatching (bool matching) |
| Choose wether Annotation filter should display matching or non-matching sources. More... | |
| void | enableSessionFilter (vtkSession *session) |
| Set Session filter to use. More... | |
| void | disableSessionFilter () |
| Disable any Session filter. More... | |
| void | setModel (pqPipelineModel *model) |
| Overload of pqFlatTreeView::setModel. More... | |
| const QModelIndex | pipelineModelIndex (const QModelIndex &index) const |
| TODO document. More... | |
| const pqPipelineModel * | getPipelineModel (const QModelIndex &index) const |
| QMenu * | contextMenu () const |
| Provides access to the context menu. More... | |
Public Member Functions inherited from pqFlatTreeView | |
| pqFlatTreeView (QWidget *parent=0) | |
| Creates a flat tree view. More... | |
| ~pqFlatTreeView () override | |
| Used to monitor the header view. More... | |
| QAbstractItemModel * | getModel () const |
| void | setModel (QAbstractItemModel *model) |
| QModelIndex | getRootIndex () const |
| void | setRootIndex (const QModelIndex &index) |
| QItemSelectionModel * | getSelectionModel () const |
| void | setSelectionModel (QItemSelectionModel *selectionModel) |
| SelectionBehavior | getSelectionBehavior () const |
| void | setSelectionBehavior (SelectionBehavior behavior) |
| SelectionMode | getSelectionMode () const |
| void | setSelectionMode (SelectionMode mode) |
| QHeaderView * | getHeader () const |
| Gets whether or not the column size is managed by the view. More... | |
| void | setHeader (QHeaderView *headerView) |
| bool | isColumnSizeManaged () const |
| void | setColumnSizeManaged (bool managed) |
| Sets whether or not the column size is managed by the view. More... | |
| int | getIconSize () const |
| void | setIconSize (int iconSize) |
| bool | isIndexHidden (const QModelIndex &index) const |
| void | getVisibleRect (const QModelIndex &index, QRect &area) const |
| QModelIndex | getIndexVisibleAt (const QPoint &point) const |
| QModelIndex | getIndexCellAt (const QPoint &point) const |
| void | getSelectionIn (const QRect &rect, QItemSelection &items) const |
| bool | isIndexExpanded (const QModelIndex &index) const |
| QModelIndex | getNextVisibleIndex (const QModelIndex &index, const QModelIndex &root=QModelIndex()) const |
| QModelIndex | getRelativeIndex (const QString &id, const QModelIndex &root=QModelIndex()) const |
| void | getRelativeIndexId (const QModelIndex &index, QString &id, const QModelIndex &root=QModelIndex()) const |
| bool | startEditing (const QModelIndex &index) |
| void | finishEditing () |
| void | cancelEditing () |
| static void | setVisibility (bool visible, pqOutputPort *port) |
| static method to sets the visibility of a pqOutputPort More... | |
Protected Slots | |
| void | handleIndexClicked (const QModelIndex &index) |
| void | expandWithModelIndexTranslation (const QModelIndex &) |
Protected Slots inherited from pqFlatTreeView | |
| void | insertRows (const QModelIndex &parent, int start, int end) |
| void | startRowRemoval (const QModelIndex &parent, int start, int end) |
| void | finishRowRemoval (const QModelIndex &parent, int start, int end) |
| void | insertColumns (const QModelIndex &parent, int start, int end) |
| void | startColumnRemoval (const QModelIndex &parent, int start, int end) |
| void | finishColumnRemoval (const QModelIndex &parent, int start, int end) |
| void | updateData (const QModelIndex &topLeft, const QModelIndex &bottomRight) |
| void | setVisibility (bool visible, const QModelIndexList &indices) |
| sets the visibility for items in the indices list. More... | |
| void | contextMenuEvent (QContextMenuEvent *e) override |
| bool | viewportEvent (QEvent *e) override |
| Overridden to pass changed font to pqPipelineModel. More... | |
Protected Member Functions inherited from pqFlatTreeView | |
| int | horizontalOffset () const |
| int | verticalOffset () const |
| void | resizeEvent (QResizeEvent *e) override |
| void | paintEvent (QPaintEvent *e) override |
| QStyleOptionViewItem | getViewOptions () const |
| void | keyPressEvent (QKeyEvent *e) override |
| void | keyboardSearch (const QString &search) |
| void | mousePressEvent (QMouseEvent *e) override |
| void | mouseMoveEvent (QMouseEvent *e) override |
| void | mouseReleaseEvent (QMouseEvent *e) override |
| void | mouseDoubleClickEvent (QMouseEvent *e) override |
| bool | event (QEvent *e) override |
Protected Attributes | |
| pqPipelineModel * | PipelineModel |
| pqPipelineAnnotationFilterModel * | FilteredPipelineModel |
| QPointer< QMenu > | ContextMenu |
Public Types inherited from pqFlatTreeView | |
| enum | SelectionBehavior { SelectItems, SelectRows, SelectColumns } |
| enum | SelectionMode { NoSelection, SingleSelection, ExtendedSelection } |
This is a replacement for pqPipelineBrowser.
Definition at line 52 of file pqPipelineBrowserWidget.h.
| pqPipelineBrowserWidget::pqPipelineBrowserWidget | ( | QWidget * | parent = 0 | ) |
Returns True if the event should not be sent to the object.
| void pqPipelineBrowserWidget::setSelectionVisibility | ( | bool | visible | ) |
| void pqPipelineBrowserWidget::enableAnnotationFilter | ( | const QString & | annotationKey | ) |
| void pqPipelineBrowserWidget::disableAnnotationFilter | ( | ) |
| void pqPipelineBrowserWidget::setAnnotationFilterMatching | ( | bool | matching | ) |
Default is matching.
| void pqPipelineBrowserWidget::enableSessionFilter | ( | vtkSession * | session | ) |
| void pqPipelineBrowserWidget::disableSessionFilter | ( | ) |
| void pqPipelineBrowserWidget::setModel | ( | pqPipelineModel * | model | ) |
TODO document.
| const pqPipelineModel* pqPipelineBrowserWidget::getPipelineModel | ( | const QModelIndex & | index | ) | const |
| QMenu* pqPipelineBrowserWidget::contextMenu | ( | ) | const |
signal |
Typically implies that the selected items need to be deleted.
slot |
By default connected to pqActiveObjects::viewChanged() so it keeps track of the active view.
protectedslot |
protectedslot |
Definition at line 151 of file pqPipelineBrowserWidget.h.
Definition at line 152 of file pqPipelineBrowserWidget.h.
Definition at line 153 of file pqPipelineBrowserWidget.h.
