#include <pqLoadStateReaction.h>
Definition at line 44 of file pqLoadStateReaction.h.
◆ pqLoadStateReaction()
| pqLoadStateReaction::pqLoadStateReaction |
QAction * |
parent | ) |
Constructor.
Parent cannot be NULL.
◆ loadState() [1/2]
| static void pqLoadStateReaction::loadState |
const QString & |
filename, |
bool |
dialogBlocked = false, |
pqServer * |
server = NULL |
Loads the state file.
Note that this method is static. Applications can simply use this without having to create a reaction instance. If no server is specified, active server is used.
◆ loadState() [2/2]
◆ activateView()
| static void pqLoadStateReaction::activateView |
Set default active view after state is loaded.
Make the first view active.
◆ updateEnableState
| void pqLoadStateReaction::updateEnableState |
overrideslot |
Updates the enabled state.
◆ onTriggered()
| void pqLoadStateReaction::onTriggered |
inlineoverrideprotectedvirtual |
