pqFileDialogModel allows remote browsing of a connected ParaView server's filesystem, as well as browsing of the local file system. More...
#include <pqFileDialogModel.h>
Inherits QAbstractItemModel.
| pqFileDialogModel (pqServer *server, QObject *Parent=NULL) | |
| server is the server for which we need the listing. More... | |
| ~pqFileDialogModel () override | |
| void | setCurrentPath (const QString &) |
| Sets the path that the file dialog will display. More... | |
| QString | getCurrentPath () |
| Returns the path the the file dialog will display. More... | |
| bool | isHidden (const QModelIndex &) |
| Return true if the file at the index is hidden. More... | |
| bool | isDir (const QModelIndex &) |
| Return true if the given row is a directory. More... | |
| bool | mkdir (const QString &dirname) |
| bool | rmdir (const QString &dirname) |
| bool | rename (const QString &oldname, const QString &newname) |
| bool | fileExists (const QString &file, QString &fullpath) |
| Returns whether the file exists also returns the full path, which could be a resolved shortcut. More... | |
| bool | dirExists (const QString &dir, QString &fullpath) |
| Returns whether a directory exists also returns the full path, which could be a resolved shortcut. More... | |
| QChar | separator () const |
| returns the path delimiter, could be \ or / depending on the platform this model is browsing More... | |
| QString | absoluteFilePath (const QString &) |
| return the absolute path for this file More... | |
| QStringList | getFilePaths (const QModelIndex &) |
| Returns the set of file paths associated with the given row (a row may represent one-to-many paths if grouping is implemented) this also resolved symlinks if necessary. More... | |
| pqServer * | server () const |
| Returns the server that this model is browsing. More... | |
| bool | setData (const QModelIndex &idx, const QVariant &value, int role) override |
| sets data (used by the view when editing names of folders) More... | |
| int | columnCount (const QModelIndex &) const override |
| return the number of columns in the model More... | |
| QVariant | data (const QModelIndex &idx, int role) const override |
| return the data for an item More... | |
| QModelIndex | index (int row, int column, const QModelIndex &) const override |
| return an index from another index More... | |
| QModelIndex | parent (const QModelIndex &) const override |
| return the parent index of an index More... | |
| int | rowCount (const QModelIndex &) const override |
| return the number of rows under a given index More... | |
| bool | hasChildren (const QModelIndex &p) const override |
| return whether a given index has children More... | |
| QVariant | headerData (int section, Qt::Orientation, int role) const override |
| returns header data More... | |
| Qt::ItemFlags | flags (const QModelIndex &idx) const override |
| returns flags for item More... | |
| void | setShowDetailedInfo (bool show) |
| Get/Sets whether the dialog shows additional information about the files like modification time and file size. More... | |
| bool | isShowingDetailedInfo () |
To use, pass a new instance of pqServerFileDialogModel to pqFileDialog object.
Definition at line 54 of file pqFileDialogModel.h.
| pqFileDialogModel::pqFileDialogModel | ( | pqServer * | server, |
| QObject * | Parent = NULL |
if the server is NULL, we get file listings locally
| void pqFileDialogModel::setShowDetailedInfo | ( | bool | show | ) |
This information can be time consuming to display if the server has many files in one directory so it is not displayed by default.
| bool pqFileDialogModel::isShowingDetailedInfo | ( | ) |
| void pqFileDialogModel::setCurrentPath | ( | const QString & | ) |
| QString pqFileDialogModel::getCurrentPath | ( | ) |
| bool pqFileDialogModel::isHidden | ( | const QModelIndex & | ) |
| bool pqFileDialogModel::isDir | ( | const QModelIndex & | ) |
| bool pqFileDialogModel::mkdir | ( | const QString & | dirname | ) |
| bool pqFileDialogModel::rmdir | ( | const QString & | dirname | ) |
| bool pqFileDialogModel::fileExists | ( | const QString & | file, |
| QString & | fullpath | ||
| bool pqFileDialogModel::dirExists | ( | const QString & | dir, |
| QChar pqFileDialogModel::separator | ( | ) | const |
| QString pqFileDialogModel::absoluteFilePath | ( | const QString & | ) |
| QStringList pqFileDialogModel::getFilePaths | ( | const QModelIndex & | ) |
| pqServer* pqFileDialogModel::server | ( | ) | const |
returns header data
