pqExpandableTableView extends pqTableView to add support for the following features:
#include <pqExpandableTableView.h>
| QModelIndex | moveCursor (CursorAction cursorAction, Qt::KeyboardModifiers modifiers) override |
| | Working together with logic in closeEditor(). More...
| void | closeEditor (QWidget *editor, QAbstractItemDelegate::EndEditHint hint) override |
| | Overridden to set MoveToNextEditableItem so that moveCursor() can skip non-editable items. More...
| void | keyPressEvent (QKeyEvent *event) override |
| | Overridden to capture Ctrl-V for pasting table data into the table. More...
- Expand/Grow table: If the user edits past the last item the view will fire a signal (editPastLastRow()) enabling observer to add new row to the table.
- Skip non-editable items: When editing, in a QTableView one can hit tab to edit the next item. However, if the next item is not editable, the editing is stopped. pqExpandableTableView makes it possible to skip non-editable items and continue with the editing.
Definition at line 49 of file pqExpandableTableView.h.
◆ pqExpandableTableView()
| pqExpandableTableView::pqExpandableTableView |
QWidget * |
parent = 0 | ) |
◆ ~pqExpandableTableView()
| pqExpandableTableView::~pqExpandableTableView |
◆ editPastLastRow
| void pqExpandableTableView::editPastLastRow |
signal |
signal fired when the user edits past the last row.
Handlers can add a new row to the table, if needed, to allow used to edit expandable tables with ease.
◆ moveCursor()
| QModelIndex pqExpandableTableView::moveCursor |
CursorAction |
cursorAction, |
Qt::KeyboardModifiers |
modifiers |
This methods makes it possible to skip past non-editable items.
◆ closeEditor()
| void pqExpandableTableView::closeEditor |
QWidget * |
editor, |
QAbstractItemDelegate::EndEditHint |
hint |
Also if moved past the last rows/last column, this will fire the editPastLastRow() signal.
◆ keyPressEvent()
| void pqExpandableTableView::keyPressEvent |
QKeyEvent * |
event | ) |
