QAbstractItemModel implementation for vtkDataAssembly.
#include <pqDataAssemblyTreeModel.h>
Inherits QAbstractItemModel.
pqDataAssemblyTreeModel builds a tree-model from a vtkDataAssembly. The vtkDataAssembly to shown is set using setDataAssembly. To allow user-settable check-states, use setUserCheckable(true). The model doesn't support any additional custom properties. One is expected to use a proxy model to store additional meta-data associated with nodes.
Definition at line 51 of file pqDataAssemblyTreeModel.h.
◆ pqDataAssemblyTreeModel()
| pqDataAssemblyTreeModel::pqDataAssemblyTreeModel |
QObject * |
parent = nullptr | ) |
◆ ~pqDataAssemblyTreeModel()
| pqDataAssemblyTreeModel::~pqDataAssemblyTreeModel |
◆ setDataAssembly()
| void pqDataAssemblyTreeModel::setDataAssembly |
vtkDataAssembly * |
assembly | ) |
Get/Set the vtkDataAssembly to represent in this model.
◆ dataAssembly()
| vtkDataAssembly* pqDataAssemblyTreeModel::dataAssembly |
const |
◆ setUserCheckable()
| void pqDataAssemblyTreeModel::setUserCheckable |
bool |
Get whether the model is user-checkable.
◆ userCheckable()
| bool pqDataAssemblyTreeModel::userCheckable |
const |
◆ setCheckedNodes()
| void pqDataAssemblyTreeModel::setCheckedNodes |
const QStringList & |
paths | ) |
Get/Set the check state for Qt::Checked for nodes selected using the path names specified.
- Note
- checking a node causes all it child nodes to be checked as well.
checkedNodes() may not returns exactly the same paths passed to setCheckedNodes even if the check-states were not changed in between the two calls.
- See also
- vtkDataAssembly::SelectNodes
◆ checkedNodes()
| QStringList pqDataAssemblyTreeModel::checkedNodes |
const |
- Note
- See also
◆ columnCount()
| int pqDataAssemblyTreeModel::columnCount |
const QModelIndex & |
parent = QModelIndex() | ) |
const |
QAbstractItemModel interface implementation.
◆ rowCount()
| int pqDataAssemblyTreeModel::rowCount |
const |
◆ index()
| QModelIndex pqDataAssemblyTreeModel::index |
int |
row, |
int |
column, |
| const |
◆ parent()
| QModelIndex pqDataAssemblyTreeModel::parent |
index = QModelIndex() | ) |
const |
◆ data()
| QVariant pqDataAssemblyTreeModel::data |
index, |
int |
role |
| const |
◆ flags()
| Qt::ItemFlags pqDataAssemblyTreeModel::flags |
index | ) |
const |
◆ setData()
| bool pqDataAssemblyTreeModel::setData |
index, |
const QVariant & |
value, |
int |
role |
◆ modelDataChanged
| void pqDataAssemblyTreeModel::modelDataChanged |
int |
role | ) |
signal |
This signal is fired in setData if the data is changed.
setData can result in multiple calls to dataChanged signal as the data is updated on nodes in the hierarchy. This signal is fired only once for setData call irrespective of how many internal nodes are updated.
