The pqCustomFilterManagerModel class stores the list of registered pipeline custom filter definitions.
#include <pqCustomFilterManagerModel.h>
Inherits QAbstractListModel.
The list is modified using the addCustomFilter and removeCustomFilter methods. When a new custom filter is added to the model a signal is emitted. This signal can be used to highlight the new custom filter.
Definition at line 58 of file pqCustomFilterManagerModel.h.
◆ pqCustomFilterManagerModel()
| pqCustomFilterManagerModel::pqCustomFilterManagerModel |
QObject * |
parent = 0 | ) |
◆ ~pqCustomFilterManagerModel()
| pqCustomFilterManagerModel::~pqCustomFilterManagerModel |
◆ rowCount()
| int pqCustomFilterManagerModel::rowCount |
const QModelIndex & |
parent = QModelIndex() | ) |
const |
Gets the number of rows for a given index.
- Parameters
- Returns
- The number of rows for the given index.
◆ index()
| QModelIndex pqCustomFilterManagerModel::index |
int |
row, |
int |
column, |
| const |
Gets a model index for a given location.
- Parameters
| row | The row number. |
| column | The column number. |
| parent | The parent index. |
- Returns
- A model index for the given location.
◆ data()
| QVariant pqCustomFilterManagerModel::data |
index, |
int |
role = Qt::DisplayRole |
| const |
Gets the data for a given model index.
- Parameters
| index | The model index. |
| role | The role to get data for. |
- Returns
- The data for the given model index.
◆ flags()
| Qt::ItemFlags pqCustomFilterManagerModel::flags |
index | ) |
const |
Gets the flags for a given model index.
The flags for an item indicate if it is enabled, editable, etc.
- Parameters
- Returns
- The flags for the given model index.
◆ getCustomFilterName()
| QString pqCustomFilterManagerModel::getCustomFilterName |
index | ) |
const |
Gets the custom filter name for the given model index.
- Parameters
| index | The model index to look up. |
- Returns
- The custom filter definition name or an empty string.
◆ getIndexFor()
| QModelIndex pqCustomFilterManagerModel::getIndexFor |
const QString & |
filter | ) |
const |
Gets the model index for the given custom filter name.
- Parameters
| filter | The custom filter definition name to look up. |
- Returns
- The model index for the given name.
◆ addCustomFilter
| void pqCustomFilterManagerModel::addCustomFilter |
QString |
name | ) |
slot |
Adds a new custom filter definition to the model.
- Parameters
| name | The name of the new custom filter definition. |
◆ removeCustomFilter
| void pqCustomFilterManagerModel::removeCustomFilter |
QString |
name | ) |
slot |
Removes a custom filter definition from the model.
- Parameters
| name | The name of the custom filter definition. |
◆ importCustomFiltersFromSettings
| void pqCustomFilterManagerModel::importCustomFiltersFromSettings |
slot |
◆ exportCustomFiltersToSettings
| void pqCustomFilterManagerModel::exportCustomFiltersToSettings |
slot |
◆ customFilterAdded
| void pqCustomFilterManagerModel::customFilterAdded |
const QString & |
name | ) |
signal |
Emitted when a new custom filter definition is added to the model.
- Parameters
