pqCoreUtilities is a collection of arbitrary utility functions that can be used by the application.
#include <pqCoreUtilities.h>
| static void | setMainWidget (QWidget *widget) |
| | When popuping up dialogs, it's generally better if we set the parent widget for those dialogs to be the QMainWindow so that the dialogs show up centered correctly in the application. More...
| static QWidget * | mainWidget () |
| static void | processEvents (QEventLoop::ProcessEventsFlags flags=QEventLoop::AllEvents) |
| | Call QApplication::processEvents plus make sure the testing framework is. More...
| static QString | getParaViewUserDirectory () |
| | Return the path of the root ParaView user specific configuration directory. More...
| static QString | getParaViewApplicationDirectory () |
| | Return the path of the launched application. More...
| static QStringList | findParaviewPaths (QString directoryOrFileName, bool lookupInAppDir, bool lookupInUserDir) |
| | Return the list of full available path that exists inside the shared application path and the user specific one. More...
| static QString | getNoneExistingFileName (QString expectedFilePath) |
| static unsigned long | connect (vtkObject *vtk_object, int vtk_event_id, QObject *qobject, const char *signal_or_slot, Qt::ConnectionType type=Qt::AutoConnection) |
| | Method used to connect VTK events to Qt slots (or signals). More...
| static bool | promptUser (const QString &settingsKey, QMessageBox::Icon icon, const QString &title, const QString &message, QMessageBox::StandardButtons buttons, QWidget *parentWdg=NULL) |
| | This provides a mechanism to prompt the user to make a choice or to show them some information. More...
| static QString | number (double value) |
| | Converts a double value to a full precision QString. More...
Definition at line 79 of file pqCoreUtilities.h.
◆ setMainWidget()
| static void pqCoreUtilities::setMainWidget |
QWidget * |
widget | ) |
inlinestatic |
For that purpose this convenience method is provided. It locates a QMainWindow and returns it.
Definition at line 88 of file pqCoreUtilities.h.
◆ mainWidget()
| static QWidget* pqCoreUtilities::mainWidget |
inlinestatic |
◆ processEvents()
| static void pqCoreUtilities::processEvents |
QEventLoop::ProcessEventsFlags |
flags = QEventLoop::AllEvents | ) |
inlinestatic |
Definition at line 102 of file pqCoreUtilities.h.
◆ getParaViewUserDirectory()
| static QString pqCoreUtilities::getParaViewUserDirectory |
◆ getParaViewApplicationDirectory()
| static QString pqCoreUtilities::getParaViewApplicationDirectory |
◆ findParaviewPaths()
| static QStringList pqCoreUtilities::findParaviewPaths |
QString |
directoryOrFileName, |
bool |
lookupInAppDir, |
bool |
lookupInUserDir |
◆ getNoneExistingFileName()
| static QString pqCoreUtilities::getNoneExistingFileName |
QString |
expectedFilePath | ) |
◆ connect()
| static unsigned long pqCoreUtilities::connect |
vtkObject * |
vtk_object, |
int |
vtk_event_id, |
QObject * |
qobject, |
const char * |
signal_or_slot, |
Qt::ConnectionType |
type = Qt::AutoConnection |
This is an alternative to using vtkEventQtSlotConnect. This method gives a cleaner API to connect vtk-events to Qt slots. It manages cleanup correctly i.e. either vtk-object or the qt-object can be deleted and the observers will be cleaned up correctly. One can disconnect the connection made explicitly by vtk_object->RemoveObserver(eventId) where eventId is the returned value.
◆ promptUser()
| static bool pqCoreUtilities::promptUser |
const QString & |
settingsKey, |
QMessageBox::Icon |
icon, |
const QString & |
title, |
const QString & |
message, |
QMessageBox::StandardButtons |
buttons, |
QWidget * |
parentWdg = NULL |
The user can decide to make their choice persistent. Two configurations are supported:
- The method prompts the user with a "Yes", "No", and "Yes,
and don't ask again" message box. Returns true for "Yes" and false for "No". If "Yes, and don't ask again" was clicked, the selection is remembered in pqSettings and next time this method is called with the same settingsKey it will simply return true.
- The method shows a message box with a "Ok" and "Ok and don't show again" If "Ok, and don't show again" was clicked, the next time this method is called with the same settingsKey it will simply return. The 'don't ask/show again' button is created by or-ing 'buttons' with QMessageBox::Save. NOTE: due to issues with test recording and playback, currently, this dialog is not prompted (instead always returning true) when DASHBOARD_TEST_FROM_CTEST environment variable is set. This may change in future.
◆ number()
| static QString pqCoreUtilities::number |
double |
value | ) |
Internally uses vtkNumberToString for lossless conversion from double to string.
