pqCollaborationPanel is a properties page for the collaborative session.
#include <pqCollaborationPanel.h>
Inherits QWidget.
| void | triggerChatMessage (pqServer *server, int userId, QString &msgContent) |
| | Emitting this signal will result by adding the message into the UI and if the user is the local one, the message will be broadcasted to the other clients. More...
| void | shareLocalMousePointer (bool) |
| | Emitting this signal when user has allowed its mouse position to be shared and send to the other clients. More...
| void | disableFurtherConnections (bool) |
| | This signal is triggered when user has allowed/disallowed further connections to the server. More...
| void | delayUpdateCamera (vtkSMMessage *msg) |
| | This get triggered internally when it's not a good time to update the camera so the request get pushed to QueuedConnection. More...
| void | connectIDChanged (int) |
| | This signal is triggered when user changes the connect-id. More...
It allows the user to change its name and manage leadership of the session.
Definition at line 49 of file pqCollaborationPanel.h.
◆ pqCollaborationPanel()
| pqCollaborationPanel::pqCollaborationPanel |
QWidget * |
parent = 0 | ) |
◆ ~pqCollaborationPanel()
| pqCollaborationPanel::~pqCollaborationPanel |
◆ triggerChatMessage
| void pqCollaborationPanel::triggerChatMessage |
pqServer * |
server, |
int |
userId, |
QString & |
msgContent |
signal |
◆ shareLocalMousePointer
| void pqCollaborationPanel::shareLocalMousePointer |
bool |
signal |
◆ disableFurtherConnections
| void pqCollaborationPanel::disableFurtherConnections |
bool |
signal |
◆ delayUpdateCamera
| void pqCollaborationPanel::delayUpdateCamera |
vtkSMMessage * |
msg | ) |
signal |
◆ connectIDChanged
| void pqCollaborationPanel::connectIDChanged |
int |
signal |
◆ writeChatMessage
| void pqCollaborationPanel::writeChatMessage |
pqServer * |
server, |
int |
userId, |
QString & |
txt |
slot |
◆ onUserUpdate
| void pqCollaborationPanel::onUserUpdate |
slot |
◆ onNewMaster
| void pqCollaborationPanel::onNewMaster |
int |
slot |
Called when a new master has been promoted.
◆ onUserMessage
| void pqCollaborationPanel::onUserMessage |
protectedslot |
Called when user hit enter in the input line of chat message.
◆ connectViewLocalSlots
| void pqCollaborationPanel::connectViewLocalSlots |
pqView * |
protectedslot |
Called when pqView are added/removed so we can listen user interaction.
◆ disconnectViewLocalSlots
| void pqCollaborationPanel::disconnectViewLocalSlots |
pqView * |
protectedslot |
◆ stopFollowingCamera
| void pqCollaborationPanel::stopFollowingCamera |
protectedslot |
◆ itemChanged
| void pqCollaborationPanel::itemChanged |
QTableWidgetItem * |
item | ) |
protectedslot |
Called when the user change its name (double click in the table on his name)
◆ cellDoubleClicked
| void pqCollaborationPanel::cellDoubleClicked |
int |
int |
protectedslot |
Called when the user double click on any cell.
◆ followUserCamera
| void pqCollaborationPanel::followUserCamera |
int |
userId | ) |
protectedslot |
Called when to follow a given user camera.
◆ onServerChanged
| void pqCollaborationPanel::onServerChanged |
protectedslot |
◆ onConnectIDChanged
| void pqCollaborationPanel::onConnectIDChanged |
protectedslot |
Called when the user changes the connect-id.
Emit signal with new value.
◆ promoteToMaster()
| void pqCollaborationPanel::promoteToMaster |
int |
masterId | ) |
◆ getCollaborationManager()
◆ getSMCollaborationManager()
◆ Internal
| pqInternal* pqCollaborationPanel::Internal |
