Functions
catalyst-macros.cmake File Reference
Functions
function catalyst_library ()
 Mark a target as the Catalyst API implementation. More...
macro c_set_if_not_set (variable)
function c_install_targets ()
function c_install_headers ()
Function Documentation
◆ catalyst_library()
function catalyst_library ( )
TARGET <target>
[LIBRARY_DESTINATION <destination>]
[INSTALL_EXPORT_DEFAULT]
The TARGET identifies the target added using an add_library call. This function ensures that properties on the target are set up appropriately so that the generated library is ABI compatible with the Catalyst stub implementation.
LIBRARY_DESTINATION if specified, is used to determine the install destination. If not specified, no install rule is added.
INSTALL_EXPORT_DEFAULT is useful in projects that include Catalyst as a sub-project (instead of using it externally) to build Catalyst implementations. For such projects, the Catalyst library is often built as a part of the project. Providing INSTALL_EXPORT_DEFAULT ensures that the Catalyst implementation is added as a part of the export set for the Catalyst targets so that find_package(catalyst ... ) can work seamlessly. If LIBRARY_DESTINATION must be specified if INSTALL_EXPORT_DEFAULT specified.
Definition at line 34 of file catalyst-macros.cmake.
◆ c_set_if_not_set()
macro c_set_if_not_set ( variable  )
Definition at line 80 of file catalyst-macros.cmake.
◆ c_install_targets()
function c_install_targets ( )
Definition at line 86 of file catalyst-macros.cmake.
◆ c_install_headers()
function c_install_headers ( )
Definition at line 110 of file catalyst-macros.cmake.
