Functions
PagosaAdaptor.h File Reference
#include "vtkPVAdaptorsPagosaModule.h"
Include dependency graph for PagosaAdaptor.h:
Functions
void VTKPVADAPTORSPAGOSA_EXPORT setcoprocessorgeometry_ (int *mx, int *my, int *mz, double *x0, double *y0, double *z0, double *dx, double *dy, double *dz, int *my_id, const int *tot_pes, char *nframe, int *nframelen, char *version, int *versionlen)
 Simulation code. More...
void VTKPVADAPTORSPAGOSA_EXPORT setgridgeometry_ (char *nframe, int *nframelen, char *version, int *versionlen, int *cycleNum, double *simTime)
 Update the vtkNonOverlappingAMR headers for every frame (time step) This holds ImageData which does not change size, but frame, version, cycle and simulation time change with each frame. More...
void VTKPVADAPTORSPAGOSA_EXPORT addgridfield_ (char *fname, int *len, int *mx, int *my, int *mz, int *my_id, float *data, bool *down_convert)
 Add field data in the first grid of nonoverlapping AMR. More...
void VTKPVADAPTORSPAGOSA_EXPORT setmarkergeometry_ (int *nvp, char *nframe, int *nframelen, char *version, int *versionlen, int *cycleNum, double *simTime)
 Initialize unstructured grid for ALL markers and allocate total size. More...
void VTKPVADAPTORSPAGOSA_EXPORT addmarkergeometry_ (int *numberAdded, float *xloc, float *yloc, float *zloc)
 Add a field to the unstructured grid of markers. More...
void VTKPVADAPTORSPAGOSA_EXPORT addmarkerscalarfield_ (char *fname, int *len, int *numberAdded, float *data)
void VTKPVADAPTORSPAGOSA_EXPORT addmarkervectorfield_ (char *fname, int *len, int *numberAdded, float *data0, float *data1, float *data2)
 Set a 3 element vector field in the unstructured grid of markers. More...
void VTKPVADAPTORSPAGOSA_EXPORT addmarkertensorfield_ (char *fname, int *len, int *numberAdded, float *data0, float *data1, float *data2, float *data3, float *data4, float *data5)
 Set a 6 element tensor field in the unstructured grid of markers. More...
Function Documentation
◆ setcoprocessorgeometry_()
void VTKPVADAPTORSPAGOSA_EXPORT setcoprocessorgeometry_ ( int mx,
int my,
int mz,
double x0,
double y0,
double z0,
double dx,
double dy,
double dz,
int my_id,
const int tot_pes,
char *  nframe,
int nframelen,
char *  version,
int versionlen
Simulation code.
Pagosa is a simulation code. It is a closed source code. A copy of the Physics Manual is at http://permalink.lanl.gov/object/tr?what=info:lanl-repo/lareport/LA-14425-M Define the data structures to hold the in situ output VTK data vtkNonOverlappingAMR is required for using the MaterialInterface filter vtkUnstructuredGrid will hold the data currently written to .cosmo files.
Parameters
mx,my,mxnumber of grid cells in each logical direction
x0,y0,z0origin on this Processor Element (PE)
dx,dy,dzgrid cell size
my_idthis PE number
tot_pestotal number of PEs
nframe,nframelenstring and stringlength
version,versionlenstring and stringlength
◆ setgridgeometry_()
void VTKPVADAPTORSPAGOSA_EXPORT setgridgeometry_ ( char *  nframe,
int nframelen,
char *  version,
int versionlen,
int cycleNum,
double simTime
Parameters
cycleNumsimulation cycle number
simTimesimulation time
◆ addgridfield_()
void VTKPVADAPTORSPAGOSA_EXPORT addgridfield_ ( char *  fname,
int len,
int mx,
int my,
int mz,
int my_id,
float data,
bool *  down_convert
Parameters
fname,lenname, namelength
mx,my,mznumber of grid cells in each logical direction
my_idthis PE number
datadata
down_convertif .true. convert data to unsigned character
◆ setmarkergeometry_()
void VTKPVADAPTORSPAGOSA_EXPORT setmarkergeometry_ ( int nvp,
char *  nframe,
int nframelen,
char *  version,
int versionlen,
int cycleNum,
double simTime
Parameters
nvpTotal number of markers in simulation
◆ addmarkergeometry_()
void VTKPVADAPTORSPAGOSA_EXPORT addmarkergeometry_ ( int numberAdded,
float xloc,
float yloc,
float zloc
Parameters
numberAddednumber of markers added on this PE
xloc,yloc,zloccoordinates for each marker added
◆ addmarkerscalarfield_()
void VTKPVADAPTORSPAGOSA_EXPORT addmarkerscalarfield_ ( char *  fname,
int len,
int numberAdded,
float data
◆ addmarkervectorfield_()
void VTKPVADAPTORSPAGOSA_EXPORT addmarkervectorfield_ ( char *  fname,
int len,
int numberAdded,
float data0,
float data1,
float data2
Parameters
fname,lenName of data, len(fname)
data0,1,2Data by marker
◆ addmarkertensorfield_()
void VTKPVADAPTORSPAGOSA_EXPORT addmarkertensorfield_ ( char *  fname,
int len,
int numberAdded,
float data0,
float data1,
float data2,
float data3,
float data4,
float data5
Parameters
data0,..,5Data by marker
