1 # Distributed under the OSI-approved BSD 3-Clause License. See accompanying 2 # file Copyright.txt or https://cmake.org/licensing for details. 4 #[=======================================================================[.rst: 8 Find the PostgreSQL installation.
13 This module defines :prop_tgt:`IMPORTED`
target ``PostgreSQL::PostgreSQL``
14 if PostgreSQL has been found.
19 This module will
set the following variables in your project:
22 True
if PostgreSQL is found.
23 ``PostgreSQL_LIBRARIES``
24 the PostgreSQL libraries needed
for linking
25 ``PostgreSQL_INCLUDE_DIRS``
26 the directories of the PostgreSQL headers
27 ``PostgreSQL_LIBRARY_DIRS``
28 the link directories
for PostgreSQL libraries
29 ``PostgreSQL_VERSION_STRING``
31 #]=======================================================================] 33 # ---------------------------------------------------------------------------- 35 # This module is derived from the module originally found in the VTK source tree. 37 # ---------------------------------------------------------------------------- 39 # PostgreSQL_ADDITIONAL_VERSIONS is a variable that can be used to set the 40 # version number of the implementation of PostgreSQL. 41 # In Windows the default installation of PostgreSQL uses that as part of the path. 42 # E.g C:\Program Files\PostgreSQL\8.4. 43 # Currently, the following version numbers are known to this module: 44 # "11" "10" "9.6" "9.5" "9.4" "9.3" "9.2" "9.1" "9.0" "8.4" "8.3" "8.2" "8.1" "8.0" 46 # To use this variable just do something like this: 47 # set(PostgreSQL_ADDITIONAL_VERSIONS "9.2" "8.4.4") 48 # before calling find_package(PostgreSQL) in your CMakeLists.txt file. 49 # This will mean that the versions you set here will be found first in the order 50 # specified before the default ones are searched. 52 # ---------------------------------------------------------------------------- 53 # You may need to manually set: 54 # PostgreSQL_INCLUDE_DIR - the path to where the PostgreSQL include files are. 55 # PostgreSQL_LIBRARY_DIR - The path to where the PostgreSQL library files are. 56 # If FindPostgreSQL.cmake cannot find the include files or the library files. 58 # ---------------------------------------------------------------------------- 59 # The following variables are set if PostgreSQL is found: 60 # PostgreSQL_FOUND - Set to true when PostgreSQL is found. 61 # PostgreSQL_INCLUDE_DIRS - Include directories for PostgreSQL 62 # PostgreSQL_LIBRARY_DIRS - Link directories for PostgreSQL libraries 63 # PostgreSQL_LIBRARIES - The PostgreSQL libraries. 65 # The ``PostgreSQL::PostgreSQL`` imported target is also created. 67 # ---------------------------------------------------------------------------- 68 # If you have installed PostgreSQL in a non-standard location. 69 # (Please note that in the following comments, it is assumed that <Your Path> 70 # points to the root directory of the include directory of PostgreSQL.) 71 # Then you have three options. 72 # 1) After CMake runs, set PostgreSQL_INCLUDE_DIR to <Your Path>/include and 73 # PostgreSQL_LIBRARY_DIR to wherever the library pq (or libpq in windows) is 74 # 2) Use CMAKE_INCLUDE_PATH to set a path to <Your Path>/PostgreSQL<-version>. This will allow find_path() 75 # to locate PostgreSQL_INCLUDE_DIR by utilizing the PATH_SUFFIXES option. e.g. In your CMakeLists.txt file 76 # set(CMAKE_INCLUDE_PATH ${CMAKE_INCLUDE_PATH} "<Your Path>/include") 77 # 3) Set an environment variable called ${PostgreSQL_ROOT} that points to the root of where you have 78 # installed PostgreSQL, e.g. <Your Path>. 80 # ---------------------------------------------------------------------------- 82 set(PostgreSQL_INCLUDE_PATH_DESCRIPTION
"top-level directory containing the PostgreSQL include directories. E.g /usr/local/include/PostgreSQL/8.4 or C:/Program Files/PostgreSQL/8.4/include")
83 set(PostgreSQL_INCLUDE_DIR_MESSAGE
"Set the PostgreSQL_INCLUDE_DIR cmake cache entry to the ${PostgreSQL_INCLUDE_PATH_DESCRIPTION}")
84 set(PostgreSQL_LIBRARY_PATH_DESCRIPTION
"top-level directory containing the PostgreSQL libraries.")
85 set(PostgreSQL_LIBRARY_DIR_MESSAGE
"Set the PostgreSQL_LIBRARY_DIR cmake cache entry to the ${PostgreSQL_LIBRARY_PATH_DESCRIPTION}")
86 set(PostgreSQL_ROOT_DIR_MESSAGE
"Set the PostgreSQL_ROOT system variable to where PostgreSQL is found on the machine E.g C:/Program Files/PostgreSQL/8.4")
89 set(PostgreSQL_KNOWN_VERSIONS ${PostgreSQL_ADDITIONAL_VERSIONS}
90 "12" "11" "10" "9.6" "9.5" "9.4" "9.3" "9.2" "9.1" "9.0" "8.4" "8.3" "8.2" "8.1" "8.0")
92 # Define additional search paths
for root directories.
93 set( PostgreSQL_ROOT_DIRECTORIES
97 foreach(suffix ${PostgreSQL_KNOWN_VERSIONS})
99 list(APPEND PostgreSQL_LIBRARY_ADDITIONAL_SEARCH_SUFFIXES
100 "PostgreSQL/${suffix}/lib")
101 list(APPEND PostgreSQL_INCLUDE_ADDITIONAL_SEARCH_SUFFIXES
102 "PostgreSQL/${suffix}/include")
103 list(APPEND PostgreSQL_TYPE_ADDITIONAL_SEARCH_SUFFIXES
104 "PostgreSQL/${suffix}/include/server")
107 list(APPEND PostgreSQL_LIBRARY_ADDITIONAL_SEARCH_SUFFIXES
108 "postgresql${suffix}
" 109 "pgsql-${suffix}/lib
") 110 list(APPEND PostgreSQL_INCLUDE_ADDITIONAL_SEARCH_SUFFIXES 111 "postgresql${suffix}
" 112 "postgresql/${suffix}
" 113 "pgsql-${suffix}/include
") 114 list(APPEND PostgreSQL_TYPE_ADDITIONAL_SEARCH_SUFFIXES 115 "postgresql${suffix}/server
" 116 "postgresql/${suffix}/server
" 117 "pgsql-${suffix}/include/server
") 122 # Look for an installation. 124 find_path(PostgreSQL_INCLUDE_DIR 127 # Look in other places. 128 ${PostgreSQL_ROOT_DIRECTORIES} 133 ${PostgreSQL_INCLUDE_ADDITIONAL_SEARCH_SUFFIXES} 134 # Help the user find it if we cannot. 135 DOC "The ${PostgreSQL_INCLUDE_DIR_MESSAGE}
" 138 find_path(PostgreSQL_TYPE_INCLUDE_DIR 139 NAMES catalog/pg_type.h 141 # Look in other places. 142 ${PostgreSQL_ROOT_DIRECTORIES} 148 ${PostgreSQL_TYPE_ADDITIONAL_SEARCH_SUFFIXES} 149 # Help the user find it if we cannot. 150 DOC "The ${PostgreSQL_INCLUDE_DIR_MESSAGE}
" 153 # The PostgreSQL library. 154 set (PostgreSQL_LIBRARY_TO_FIND pq) 155 # Setting some more prefixes for the library 156 set (PostgreSQL_LIB_PREFIX "") 158 set (PostgreSQL_LIB_PREFIX ${PostgreSQL_LIB_PREFIX} "lib
") 159 set (PostgreSQL_LIBRARY_TO_FIND ${PostgreSQL_LIB_PREFIX}${PostgreSQL_LIBRARY_TO_FIND}) 162 function(__postgresql_find_library _name) 163 find_library(${_name} 166 ${PostgreSQL_ROOT_DIRECTORIES} 169 ${PostgreSQL_LIBRARY_ADDITIONAL_SEARCH_SUFFIXES} 170 # Help the user find it if we cannot. 171 DOC "The ${PostgreSQL_LIBRARY_DIR_MESSAGE}
" 175 # For compatibility with versions prior to this multi-config search, honor 176 # any PostgreSQL_LIBRARY that is already specified and skip the search. 177 if(PostgreSQL_LIBRARY) 178 set(PostgreSQL_LIBRARIES "${PostgreSQL_LIBRARY}
") 179 get_filename_component(PostgreSQL_LIBRARY_DIR "${PostgreSQL_LIBRARY}
" PATH) 181 __postgresql_find_library(PostgreSQL_LIBRARY_RELEASE ${PostgreSQL_LIBRARY_TO_FIND}) 182 __postgresql_find_library(PostgreSQL_LIBRARY_DEBUG ${PostgreSQL_LIBRARY_TO_FIND}d) 183 include(SelectLibraryConfigurations) 184 select_library_configurations(PostgreSQL) 185 mark_as_advanced(PostgreSQL_LIBRARY_RELEASE PostgreSQL_LIBRARY_DEBUG) 186 if(PostgreSQL_LIBRARY_RELEASE) 187 get_filename_component(PostgreSQL_LIBRARY_DIR "${PostgreSQL_LIBRARY_RELEASE}
" PATH) 188 elseif(PostgreSQL_LIBRARY_DEBUG) 189 get_filename_component(PostgreSQL_LIBRARY_DIR "${PostgreSQL_LIBRARY_DEBUG}
" PATH) 191 set(PostgreSQL_LIBRARY_DIR "") 195 if (PostgreSQL_INCLUDE_DIR) 196 # Some platforms include multiple pg_config.hs for multi-lib configurations 197 # This is a temporary workaround. A better solution would be to compile 198 # a dummy c file and extract the value of the symbol. 199 file(GLOB _PG_CONFIG_HEADERS "${PostgreSQL_INCLUDE_DIR}/pg_config*.h
") 200 foreach(_PG_CONFIG_HEADER ${_PG_CONFIG_HEADERS}) 201 if(EXISTS "${_PG_CONFIG_HEADER}
") 202 file(STRINGS "${_PG_CONFIG_HEADER}
" pgsql_version_str 203 REGEX "^#define[\t ]+PG_VERSION_NUM[\t ]+.*
") 204 if(pgsql_version_str) 205 string(REGEX REPLACE "^#define[\t ]+PG_VERSION_NUM[\t ]+([0-9]*).*
" 206 "\\1
" _PostgreSQL_VERSION_NUM "${pgsql_version_str}
") 211 if (_PostgreSQL_VERSION_NUM) 212 # 9.x and older encoding 213 if (_PostgreSQL_VERSION_NUM LESS 100000) 214 math(EXPR _PostgreSQL_major_version "${_PostgreSQL_VERSION_NUM} / 10000
") 215 math(EXPR _PostgreSQL_minor_version "${_PostgreSQL_VERSION_NUM} % 10000 / 100
") 216 math(EXPR _PostgreSQL_patch_version "${_PostgreSQL_VERSION_NUM} % 100
") 217 set(PostgreSQL_VERSION_STRING "${_PostgreSQL_major_version}.${_PostgreSQL_minor_version}.${_PostgreSQL_patch_version}
") 218 unset(_PostgreSQL_major_version) 219 unset(_PostgreSQL_minor_version) 220 unset(_PostgreSQL_patch_version) 222 math(EXPR _PostgreSQL_major_version "${_PostgreSQL_VERSION_NUM} / 10000
") 223 math(EXPR _PostgreSQL_minor_version "${_PostgreSQL_VERSION_NUM} % 10000
") 224 set(PostgreSQL_VERSION_STRING "${_PostgreSQL_major_version}.${_PostgreSQL_minor_version}
") 225 unset(_PostgreSQL_major_version) 226 unset(_PostgreSQL_minor_version) 229 foreach(_PG_CONFIG_HEADER ${_PG_CONFIG_HEADERS}) 230 if(EXISTS "${_PG_CONFIG_HEADER}
") 231 file(STRINGS "${_PG_CONFIG_HEADER}
" pgsql_version_str 232 REGEX "^#define[\t ]+PG_VERSION[\t ]+\
233 if(pgsql_version_str)
234 string(REGEX REPLACE
"^#define[\t ]+PG_VERSION[\t ]+\"([^\"]*)\".*" 235 "\\1" PostgreSQL_VERSION_STRING
"${pgsql_version_str}")
241 unset(_PostgreSQL_VERSION_NUM)
242 unset(pgsql_version_str)
245 # Did we find anything? 246 include(FindPackageHandleStandardArgs)
247 find_package_handle_standard_args(PostgreSQL
248 REQUIRED_VARS PostgreSQL_LIBRARY PostgreSQL_INCLUDE_DIR PostgreSQL_TYPE_INCLUDE_DIR
249 VERSION_VAR PostgreSQL_VERSION_STRING)
250 set(PostgreSQL_FOUND ${POSTGRESQL_FOUND})
254 set(_config_suffix
"_${_config}")
256 set(_config_suffix
259 set(_lib
"${${_var}${_config_suffix}}")
262 set_property(TARGET ${_target} APPEND PROPERTY
263 IMPORTED_CONFIGURATIONS ${_config})
265 set_target_properties(${_target} PROPERTIES
266 IMPORTED_LOCATION${_config_suffix}
"${_lib}")
270 # Now try to get the include and library path. 272 if (NOT TARGET PostgreSQL::PostgreSQL)
273 add_library(PostgreSQL::PostgreSQL UNKNOWN IMPORTED)
274 set_target_properties(PostgreSQL::PostgreSQL PROPERTIES
275 INTERFACE_INCLUDE_DIRECTORIES
"${PostgreSQL_INCLUDE_DIR};${PostgreSQL_TYPE_INCLUDE_DIR}")
280 set(PostgreSQL_INCLUDE_DIRS ${PostgreSQL_INCLUDE_DIR} ${PostgreSQL_TYPE_INCLUDE_DIR} )
281 set(PostgreSQL_LIBRARY_DIRS ${PostgreSQL_LIBRARY_DIR} )
284 mark_as_advanced(PostgreSQL_INCLUDE_DIR PostgreSQL_TYPE_INCLUDE_DIR)
function __postgresql_import_library(_target, _var, _config)
