FindEXPAT.cmake
1 # Distributed under the OSI-approved BSD 3-Clause License. See accompanying
2 # file Copyright.txt or https://cmake.org/licensing for details.
3
4 # XXX: Copied from CMake, but includes vtkDetectLibraryType.
5 # See https://gitlab.kitware.com/cmake/cmake/-/issues/18564
6
7 #[=======================================================================[.rst:
8 FindEXPAT
9 ---------
10
11 Find the native Expat headers and library.
12
13 Imported Targets
14 ^^^^^^^^^^^^^^^^
15
16 This module defines the following :prop_tgt:`IMPORTED` targets:
17
18 ``EXPAT::EXPAT``
19  The Expat ``expat`` library, if found.
20
21 Result Variables
22 ^^^^^^^^^^^^^^^^
23
24 This module will set the following variables in your project:
25
26 ``EXPAT_INCLUDE_DIRS``
27  where to find expat.h, etc.
28 ``EXPAT_LIBRARIES``
29  the libraries to link against to use Expat.
30 ``EXPAT_FOUND``
31  true if the Expat headers and libraries were found.
32
33 #]=======================================================================]
35 find_package(PkgConfig QUIET)
36
37 pkg_check_modules(PC_EXPAT QUIET expat)
38
39 # Look for the header file.
40 find_path(EXPAT_INCLUDE_DIR NAMES expat.h HINTS ${PC_EXPAT_INCLUDE_DIRS})
41
42 # Look for the library.
43 find_library(EXPAT_LIBRARY NAMES expat libexpat HINTS ${PC_EXPAT_LIBRARY_DIRS})
45 if (EXPAT_INCLUDE_DIR AND EXISTS "${EXPAT_INCLUDE_DIR}/expat.h")
46  file(STRINGS "${EXPAT_INCLUDE_DIR}/expat.h" expat_version_str
47  REGEX "^#[\t ]*define[\t ]+XML_(MAJOR|MINOR|MICRO)_VERSION[\t ]+[0-9]+$")
48
49  unset(EXPAT_VERSION_STRING)
50  foreach(VPART MAJOR MINOR MICRO)
51  foreach(VLINE ${expat_version_str})
52  if(VLINE MATCHES "^#[\t ]*define[\t ]+XML_${VPART}_VERSION[\t ]+([0-9]+)$")
53  set(EXPAT_VERSION_PART "${CMAKE_MATCH_1}")
54  if(EXPAT_VERSION_STRING)
55  string(APPEND EXPAT_VERSION_STRING ".${EXPAT_VERSION_PART}")
56  else()
57  set(EXPAT_VERSION_STRING "${EXPAT_VERSION_PART}")
58  endif()
59  endif()
60  endforeach()
61  endforeach()
62 endif ()
63
64 include(FindPackageHandleStandardArgs)
65 FIND_PACKAGE_HANDLE_STANDARD_ARGS(EXPAT
66  REQUIRED_VARS EXPAT_LIBRARY EXPAT_INCLUDE_DIR
67  VERSION_VAR EXPAT_VERSION_STRING)
68
69 # Copy the results to the output variables and target.
70 if(EXPAT_FOUND)
71  set(EXPAT_LIBRARIES ${EXPAT_LIBRARY})
72  set(EXPAT_INCLUDE_DIRS ${EXPAT_INCLUDE_DIR})
73
74  if(NOT TARGET EXPAT::EXPAT)
75  include(vtkDetectLibraryType)
76  vtk_detect_library_type(expat_library_type
77  PATH "${EXPAT_LIBRARY}")
78  add_library(EXPAT::EXPAT "${expat_library_type}" IMPORTED)
79  unset(expat_library_type)
80  set_target_properties(EXPAT::EXPAT PROPERTIES
81  IMPORTED_LINK_INTERFACE_LANGUAGES "C"
82  IMPORTED_LOCATION "${EXPAT_LIBRARY}"
83  IMPORTED_IMPLIB "${EXPAT_LIBRARY}"
84  INTERFACE_INCLUDE_DIRECTORIES "${EXPAT_INCLUDE_DIRS}")
85  endif()
86 endif()
87
88 mark_as_advanced(EXPAT_INCLUDE_DIR EXPAT_LIBRARY)
function vtk_detect_library_type(output)
Detect library type of a library.
