provides meta data about a vtkDataObject subclass. More...
#include <vtkPVDataInformation.h>
| typedef vtkPVInformation | Superclass |
Public Types inherited from vtkPVInformation | |
| void | CopyFromObject (vtkObject *object) override |
Populate vtkPVDataInformation using object. More... | |
| void | Initialize () |
Initializes and clears all values updated in CopyFromObject. More... | |
| void | DeepCopy (vtkPVDataInformation *info) |
| Simply copies from another vtkPVDataInformation. More... | |
| vtkPVArrayInformation * | GetArrayInformation (const char *arrayname, int fieldAssociation) const |
| Finds and returns array information associated with the chosen array. More... | |
| virtual int | GetDataSetType () |
| Returns the data set type. More... | |
| virtual int | GetCompositeDataSetType () |
| Returns the type flag for composite datasets. More... | |
| bool | IsCompositeDataSet () const |
| Returns true if the data information corresponds to a composite dataset. More... | |
| bool | IsNull () const |
| Returns true if the data information is empty or invalid. More... | |
| vtkTypeInt64 | GetNumberOfElements (int elementType) const |
| Returns number of elements of the chosen type in the data. More... | |
| virtual vtkTypeInt64 | GetNumberOfAMRLevels () |
| For vtkUniformGridAMR and subclasses, this returns the number of levels. More... | |
| vtkTypeInt64 | GetNumberOfAMRDataSets (vtkTypeInt64 level) const |
| For vtkUniformGridAMR and subclasses, this returns the number of datasets at each level. More... | |
| virtual vtkTypeInt64 | GetNumberOfDataSets () |
| This is count of non-null non-composite datasets. More... | |
| virtual vtkTypeInt64 | GetMemorySize () |
Returns the memory size as reported by vtkDataObject::GetActualMemorySize. More... | |
| virtual double * | GetBounds () |
| Returns bounds for the dataset. More... | |
| virtual void | GetBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetBounds (double [6]) |
| virtual vtkPVArrayInformation * | GetPointArrayInformation () |
For a vtkPointSet and subclasses, this provides information about the vtkPoints array. More... | |
| bool | IsDataStructured () const |
| Returns true if the data is structured i.e. More... | |
| bool | HasStructuredData () const |
| Returns true if the data has structured data. More... | |
| bool | HasUnstructuredData () const |
| Returns true if the data has unstructured data. More... | |
| bool | IsAttributeValid (int fieldAssociation) const |
| Returns true if provided fieldAssociation is valid for this dataset, false otherwise. More... | |
| virtual vtkTypeUInt64 | GetFirstLeafCompositeIndex () |
| Until multiblock dataset is deprecated, applications often want to locate the composite-index for the first leaf node. More... | |
| std::string | GetBlockName (vtkTypeUInt64 cid) const |
| Given a composite index, return the blockname, if any. More... | |
| std::vector< std::string > | GetBlockNames (const std::vector< std::string > &selectors, const char *assemblyName) const |
| Given a collection of selectors, returns all block names for chosen blocks. More... | |
| unsigned int | ComputeCompositeIndexForAMR (unsigned int level, unsigned int index) const |
| A helper method to convert an AMR level-index to a flat index. More... | |
| virtual void | SetPortNumber (int) |
| Indicates which output port of an algorithm this data should information should be / has been collected from. More... | |
| virtual int | GetPortNumber () |
| virtual void | SetRank (int) |
| Indicates which rank to gather the information from. More... | |
| virtual int | GetRank () |
| virtual char * | GetSubsetSelector () |
| Path if non-null, used to limit blocks from a composite dataset. More... | |
| virtual void | SetSubsetSelector (const char *) |
| virtual void | SetSubsetAssemblyName (const char *) |
| Get/Set the assembly to use for subsetting. More... | |
| virtual char * | GetSubsetAssemblyName () |
| void | SetSubsetAssemblyNameToHierarchy () |
| void | AddInformation (vtkPVInformation *info) override |
| vtkPVInformation API implementation. More... | |
| void | CopyToStream (vtkClientServerStream *) override |
| void | CopyFromStream (const vtkClientServerStream *) override |
| void | CopyParametersToStream (vtkMultiProcessStream &) override |
| void | CopyParametersFromStream (vtkMultiProcessStream &) override |
| const std::vector< int > & | GetUniqueBlockTypes () const |
| For a composite dataset, returns a list of unique data set types for all non-null leaf nodes. More... | |
| unsigned int | GetNumberOfUniqueBlockTypes () const |
| int | GetUniqueBlockType (unsigned int index) const |
| bool | DataSetTypeIsA (const char *classname) const |
Returns true if the type is of the requested classname (or typeId). More... | |
| bool | DataSetTypeIsA (int typeId) const |
| bool | HasDataSetType (const char *classname) const |
Similar to DataSetTypeIsA except, in case of composite datasets, returns true if any of the leaf nodes match the requested type. More... | |
| bool | HasDataSetType (int typeId) const |
| vtkTypeInt64 | GetNumberOfPoints () const |
Convenience methods that simply call GetNumberOfElements with appropriate element type. More... | |
| vtkTypeInt64 | GetNumberOfCells () const |
| vtkTypeInt64 | GetNumberOfVertices () const |
| vtkTypeInt64 | GetNumberOfEdges () const |
| vtkTypeInt64 | GetNumberOfRows () const |
| virtual vtkTypeInt64 | GetNumberOfTrees () |
| vtkHyperTreeGrid / vtkUniformHyperTreeGrid specific properties. More... | |
| virtual vtkTypeInt64 | GetNumberOfLeaves () |
| virtual int * | GetExtent () |
| Returns structured extents for the data. More... | |
| virtual void | GetExtent (int &, int &, int &, int &, int &, int &) |
| virtual void | GetExtent (int [6]) |
| vtkPVDataSetAttributesInformation * | GetAttributeInformation (int fieldAssociation) const |
| Get vtkPVDataSetAttributesInformation information for the given association. More... | |
| vtkPVDataSetAttributesInformation * | GetPointDataInformation () const |
| Convenience methods to get vtkPVDataSetAttributesInformation for specific field type. More... | |
| vtkPVDataSetAttributesInformation * | GetCellDataInformation () const |
| vtkPVDataSetAttributesInformation * | GetVertexDataInformation () const |
| vtkPVDataSetAttributesInformation * | GetEdgeDataInformation () const |
| vtkPVDataSetAttributesInformation * | GetRowDataInformation () const |
| vtkPVDataSetAttributesInformation * | GetFieldDataInformation () const |
| virtual bool | GetHasTime () |
Returns DATA_TIME_STEP, if any, provided by the information object associated with data. More... | |
| virtual double | GetTime () |
| virtual double * | GetTimeRange () |
| Strictly speaking, these are not data information since these cannot be obtained from the data but from the pipeline producing the data. More... | |
| virtual void | GetTimeRange (double &, double &) |
| virtual void | GetTimeRange (double [2]) |
| virtual std::string | GetTimeLabel () |
| const std::set< double > & | GetTimeSteps () const |
| vtkTypeInt64 | GetNumberOfTimeSteps () const |
| vtkDataAssembly * | GetHierarchy () const |
| For composite datasets, this provides access to the information about the dataset hierarchy and any data assembly associated with it. More... | |
| vtkDataAssembly * | GetDataAssembly () const |
| vtkDataAssembly * | GetDataAssembly (const char *assemblyName) const |
Public Member Functions inherited from vtkPVInformation | |
| virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More... | |
| static vtkPVDataInformation * | New () |
| static vtkPVDataInformation * | SafeDownCast (vtkObject *o) |
| static int | GetExtentType (int dataType) |
| Returns the extent type for a given data-object type. More... | |
Static Public Member Functions inherited from vtkPVInformation | |
| static vtkPVInformation * | SafeDownCast (vtkObject *o) |
| vtkPVDataInformation () | |
| ~vtkPVDataInformation () override | |
| void | CopyFromPipelineInformation (vtkInformation *pipelineInfo) |
| Populate information object with contents from producer pipeline's output port information. More... | |
| void | CopyFromDataObject (vtkDataObject *dobj) |
| virtual vtkSmartPointer< vtkCompositeDataSet > | SimplifyCompositeDataSet (vtkCompositeDataSet *cd) |
| Simplifies a composite dataset for faster processing when accumulating data-information. More... | |
| vtkSmartPointer< vtkDataObject > | GetSubset (vtkDataObject *dobj) const |
| Extracts selected blocks. More... | |
Protected Member Functions inherited from vtkPVInformation | |
| vtkPVInformation () | |
| ~vtkPVInformation () override | |
| virtual void | SetRootOnly (int) |
| vtkPVInformation (const vtkPVInformation &)=delete | |
| void | operator= (const vtkPVInformation &)=delete |
Friends | |
| class | vtkPVDataInformationHelper |
| class | vtkPVDataInformationAccumulator |
| static const char * | GetDataSetTypeAsString (int type) |
| Returns a string for the given type. More... | |
| const char * | GetDataSetTypeAsString () const |
| const char * | GetDataClassName () const |
| const char * | GetCompositeDataClassName () const |
| static const char * | GetPrettyDataTypeString (int dtype) |
| Returns a user-friendly string describing the datatype. More... | |
| const char * | GetPrettyDataTypeString () const |
Protected Attributes inherited from vtkPVInformation | |
| int | RootOnly |
vtkPVDataInformation is a vtkPVInformation subclass intended to collect information from vtkDataObject and subclasses. It designed to be used by application in lieu of actual data to glean insight into the data e.g. data type, number of points, number of cells, arrays, ranges etc.
Definition at line 42 of file vtkPVDataInformation.h.
Definition at line 46 of file vtkPVDataInformation.h.
Reimplemented from vtkPVInformation.
Reimplemented in vtkPVTemporalDataInformation, and vtkPVRepresentedDataInformation.
Default is 0.
Default is 0.
Default is -1 which means all ranks.
For details on support form of selector expressions see vtkDataAssembly::SelectNodes.
To use hierarchy, set this to vtkDataAssembly::HierarchyName() or simply use SetSubsetAssemblyNameToHierarchy().
| void vtkPVDataInformation::SetSubsetAssemblyNameToHierarchy | ( | ) |
The object can be a vtkDataObject, vtkAlgorithm or vtkAlgorithmOutput.
Implements vtkPVInformation.
| void vtkPVDataInformation::Initialize | ( | ) |
| void vtkPVDataInformation::DeepCopy | ( | vtkPVDataInformation * | info | ) |
| vtkPVArrayInformation* vtkPVDataInformation::GetArrayInformation | ( | const char * | arrayname, |
| int | fieldAssociation | ||
| ) | const |
fieldAssociation must be one of vtkDataObject::FieldAssociations or vtkDataObject::AttributeTypes.
Returned values are defined in vtkType.h. For composite datasets, this returns the common superclass for all non-null leaf nodes in the composite dataset.
-1 indicates that the information has not be collected yet, was collected from nullptr data object, or from a composite dataset with no non-null leaf nodes.
For non-composite datasets, this is set to -1.
Definition at line 146 of file vtkPVDataInformation.h.
Definition at line 151 of file vtkPVDataInformation.h.
May be empty if there are non-null leaf nodes are the dataset is not a composite dataset.
Definition at line 161 of file vtkPVDataInformation.h.
Definition at line 162 of file vtkPVDataInformation.h.
This directly returns the classname and hence may not be user-friendly.
Definition at line 177 of file vtkPVDataInformation.h.
Definition at line 181 of file vtkPVDataInformation.h.
Definition at line 185 of file vtkPVDataInformation.h.
| const char* vtkPVDataInformation::GetPrettyDataTypeString | ( | ) | const |
| bool vtkPVDataInformation::DataSetTypeIsA | ( | const char * | classname | ) | const |
If this->CompositeDataSetType is valid i.e. the information represents a composite dataset, the composite dataset type is first checked. If not, this->DataSetType is checked. Since this->DataSetType is set to the most common data type among all the leaf nodes in the composite dataset, true implies all datasets in the composite dataset match the type.
HasDataSetType | bool vtkPVDataInformation::DataSetTypeIsA | ( | int | typeId | ) | const |
HasDataSetType | bool vtkPVDataInformation::HasDataSetType | ( | const char * | classname | ) | const |
For non-composite datasets, this is same as DataSetTypeIsA.
| bool vtkPVDataInformation::HasDataSetType | ( | int | typeId | ) | const |
| vtkTypeInt64 vtkPVDataInformation::GetNumberOfElements | ( | int | elementType | ) | const |
For a composite dataset, this is a sum of the element count across all leaf nodes.
elementType must be vtkDataObject::AttributeTypes. For vtkDataObject::FIELD, and vtkDataObject::POINT_THEN_CELL returns 0.
Definition at line 241 of file vtkPVDataInformation.h.
Definition at line 242 of file vtkPVDataInformation.h.
Definition at line 243 of file vtkPVDataInformation.h.
Definition at line 247 of file vtkPVDataInformation.h.
Definition at line 248 of file vtkPVDataInformation.h.
Will return 0 for all other data types.
| vtkTypeInt64 vtkPVDataInformation::GetNumberOfAMRDataSets | ( | vtkTypeInt64 | level | ) | const |
A count of 0 may mean:
For composite datasets, this is simply a sum of the values returned by vtkDataObject::GetActualMemorySize per non-null leaf node. For datasets that share internal arrays, this will overestimate the size.
May return an invalid bounding box for data types where bounds don't make sense. For composite datasets, this is a bounding box of all valid bounding boxes.
These are only valid for structured data types like vtkStructuredGrid, vtkImageData etc. For composite dataset, these represent the combined extents for structured datasets in the collection.
| vtkPVDataSetAttributesInformation* vtkPVDataInformation::GetAttributeInformation | ( | int | fieldAssociation | ) | const |
vtkPVDataSetAttributesInformation can be used to determine available arrays and get meta-data about each of the available arrays.
fieldAssociation must be vtkDataObject::FieldAssociations (or vtkDataObject::AttributeTypes). vtkDataObject::FIELD_ASSOCIATION_POINTS_THEN_CELLS (or vtkDataObject::POINT_THEN_CELL) is not supported.
Same as calling GetAttributeInformation with appropriate type.
Definition at line 328 of file vtkPVDataInformation.h.
Definition at line 332 of file vtkPVDataInformation.h.
Definition at line 336 of file vtkPVDataInformation.h.
Definition at line 340 of file vtkPVDataInformation.h.
Definition at line 344 of file vtkPVDataInformation.h.
Definition at line 348 of file vtkPVDataInformation.h.
For composite datasets, this is the obtained by accumulating information from all point-sets in the collection.
However, they are provided as part data information for simplicity.
Definition at line 378 of file vtkPVDataInformation.h.
Definition at line 379 of file vtkPVDataInformation.h.
| bool vtkPVDataInformation::IsDataStructured | ( | ) | const |
supports i-j-k indexing. For composite datasets, this returns true if all leaf nodes are structured.
| bool vtkPVDataInformation::HasStructuredData | ( | ) | const |
For composite datasets, this returns true if any of the datasets are structured.
| bool vtkPVDataInformation::HasUnstructuredData | ( | ) | const |
For composite datasets, this returns true if any of the datasets are unstructured.
| bool vtkPVDataInformation::IsAttributeValid | ( | int | fieldAssociation | ) | const |
For composite datasets, this returns true if the attribute type if valid for any of the datasets in the collection.
| vtkDataAssembly* vtkPVDataInformation::GetHierarchy | ( | ) | const |
Hierarchy represents the hierarchy of the datatype while assembly provides access to logical grouping and organization, if any.
| vtkDataAssembly* vtkPVDataInformation::GetDataAssembly | ( | ) | const |
| vtkDataAssembly* vtkPVDataInformation::GetDataAssembly | ( | const char * | assemblyName | ) | const |
Returns 0 if not applicable.
| std::string vtkPVDataInformation::GetBlockName | ( | vtkTypeUInt64 | cid | ) | const |
Note, this is not reliable if executed on partitioned-dataset collection since partitioned-dataset collection may have different composite indices across ranks. Thus, this must only be used in code that is currently only slated for migration from using composite-ids to selectors and hence does not encounter partitioned-dataset collections.
This uses Hierarchy and hence it only supported when hierarchy is defined/available.
Returns empty string if no name available or cannot be determined.
| std::vector<std::string> vtkPVDataInformation::GetBlockNames | ( | const std::vector< std::string > & | selectors, |
| const char * | assemblyName | ||
| ) | const |
| unsigned int vtkPVDataInformation::ComputeCompositeIndexForAMR | ( | unsigned int | level, |
| unsigned int | index | ||
| ) | const |
This uses the hierarchy to compute the flat index.
Calling this on a non-AMR dataset will simply return 0.
protectedvirtual |
Reimplemented in vtkPVRepresentedDataInformation.
Use SubsetSelector and SubsetAssemblyName to extract chosen part of the composite dataset and returns that.
friend |
Definition at line 475 of file vtkPVDataInformation.h.
friend |
Definition at line 525 of file vtkPVDataInformation.h.
