pqScalarValueListPropertyWidget provides a table widget to which users are add values e.g. More...
#include <pqScalarValueListPropertyWidget.h>
Signals | |
| void | scalarsChanged () |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| pqScalarValueListPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr) | |
| ~pqScalarValueListPropertyWidget () override | |
| void | setScalars (const QVariantList &scalars) |
| QVariantList | scalars () const |
| void | setShowLabels (bool) |
| void | setLabels (const std::vector< std::string > &labels) |
| void | setRangeDomain (vtkSMDoubleRangeDomain *smRangeDomain) |
| Sets range domain that will be used to initialize the scalar range. More... | |
| void | setRangeDomain (vtkSMIntRangeDomain *smRangeDomain) |
| void | setRangeDomain (vtkSMTimeStepsDomain *timestepsDomain) |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Properties | |
| QVariantList | scalars |
| template<class T > | |
for IsoValues for the Contour filter.
This widget supports the AllowRestoreDefaults hints, which adds a button that allow users to restore the default value of the property.
Definition at line 26 of file pqScalarValueListPropertyWidget.h.
| pqScalarValueListPropertyWidget::pqScalarValueListPropertyWidget | ( | vtkSMProperty * | property, |
| vtkSMProxy * | proxy, | ||
| void pqScalarValueListPropertyWidget::setScalars | ( | const QVariantList & | scalars | ) |
| QVariantList pqScalarValueListPropertyWidget::scalars | ( | ) | const |
| void pqScalarValueListPropertyWidget::setRangeDomain | ( | vtkSMDoubleRangeDomain * | smRangeDomain | ) |
vtkSMTimeStepsDomain does have a concept of min and max that can be used as a range.
| void pqScalarValueListPropertyWidget::setRangeDomain | ( | vtkSMIntRangeDomain * | smRangeDomain | ) |
| void pqScalarValueListPropertyWidget::setRangeDomain | ( | vtkSMTimeStepsDomain * | timestepsDomain | ) |
| void pqScalarValueListPropertyWidget::setShowLabels | ( | bool | ) |
| void pqScalarValueListPropertyWidget::setLabels | ( | const std::vector< std::string > & | labels | ) |
signal |
readwrite |
Definition at line 29 of file pqScalarValueListPropertyWidget.h.
