Classes | Enumerations | Functions | Variables
paraview_protobuf Namespace Reference
class  PROTOBUF_FINAL
Enumerations
enum  Variant_Type : int {
  Variant_Type_INT = 0, Variant_Type_FLOAT64 = 1, Variant_Type_IDTYPE = 2, Variant_Type_STRING = 3,
  Variant_Type_PROXY = 4, Variant_Type_INPUT = 5, Variant_Type_BYTES = 6, Variant_Type_MAP = 7
enum  LinkState_LinkDescription_Direction : int { LinkState_LinkDescription_Direction_NONE = 0, LinkState_LinkDescription_Direction_INPUT = 1, LinkState_LinkDescription_Direction_OUTPUT = 2 }
enum  MousePointer_Ratio : int { MousePointer_Ratio_BOTH = 0, MousePointer_Ratio_HEIGHT = 1, MousePointer_Ratio_WIDTH = 2 }
enum  QtEvent_QtEventType : int { QtEvent_QtEventType_CHAT = 1, QtEvent_QtEventType_OTHER = 3 }
Functions
VTKREMOTINGSERVERMANAGER_EXPORT bool Variant_Type_IsValid (int value)
VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * Variant_Type_descriptor ()
template<typename T >
const std::string & Variant_Type_Name (T enum_t_value)
bool Variant_Type_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, Variant_Type *value)
VTKREMOTINGSERVERMANAGER_EXPORT bool LinkState_LinkDescription_Direction_IsValid (int value)
VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * LinkState_LinkDescription_Direction_descriptor ()
const std::string & LinkState_LinkDescription_Direction_Name (T enum_t_value)
bool LinkState_LinkDescription_Direction_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, LinkState_LinkDescription_Direction *value)
VTKREMOTINGSERVERMANAGER_EXPORT bool MousePointer_Ratio_IsValid (int value)
VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * MousePointer_Ratio_descriptor ()
const std::string & MousePointer_Ratio_Name (T enum_t_value)
bool MousePointer_Ratio_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, MousePointer_Ratio *value)
VTKREMOTINGSERVERMANAGER_EXPORT bool QtEvent_QtEventType_IsValid (int value)
VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * QtEvent_QtEventType_descriptor ()
const std::string & QtEvent_QtEventType_Name (T enum_t_value)
bool QtEvent_QtEventType_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, QtEvent_QtEventType *value)
Variables
VTKREMOTINGSERVERMANAGER_EXPORT ChartViewBoundsDefaultTypeInternal _ChartViewBounds_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ChatMessageDefaultTypeInternal _ChatMessage_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ClientsInformationDefaultTypeInternal _ClientsInformation_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ClientsInformation_ClientInfoDefaultTypeInternal _ClientsInformation_ClientInfo_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT DefinitionHeaderDefaultTypeInternal _DefinitionHeader_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT LinkStateDefaultTypeInternal _LinkState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT LinkState_LinkDescriptionDefaultTypeInternal _LinkState_LinkDescription_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT MessageDefaultTypeInternal _Message_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT MessageCollectionDefaultTypeInternal _MessageCollection_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT MousePointerDefaultTypeInternal _MousePointer_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT PXMRegistrationStateDefaultTypeInternal _PXMRegistrationState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT PXMRegistrationState_EntryDefaultTypeInternal _PXMRegistrationState_Entry_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyDefinitionStateDefaultTypeInternal _ProxyDefinitionState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyDefinitionState_ProxyXMLDefinitionDefaultTypeInternal _ProxyDefinitionState_ProxyXMLDefinition_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxySelectionModelStateDefaultTypeInternal _ProxySelectionModelState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyStateDefaultTypeInternal _ProxyState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_AnnotationDefaultTypeInternal _ProxyState_Annotation_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_PropertyDefaultTypeInternal _ProxyState_Property_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_SubProxyDefaultTypeInternal _ProxyState_SubProxy_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_UserDataDefaultTypeInternal _ProxyState_UserData_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT PullRequestDefaultTypeInternal _PullRequest_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT QtEventDefaultTypeInternal _QtEvent_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT VariantDefaultTypeInternal _Variant_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT VariantListDefaultTypeInternal _VariantList_default_instance_
constexpr Variant_Type Variant_Type_Type_MIN = Variant_Type_INT
constexpr Variant_Type Variant_Type_Type_MAX = Variant_Type_MAP
constexpr int Variant_Type_Type_ARRAYSIZE = Variant_Type_Type_MAX + 1
constexpr LinkState_LinkDescription_Direction LinkState_LinkDescription_Direction_Direction_MIN = LinkState_LinkDescription_Direction_NONE
constexpr LinkState_LinkDescription_Direction LinkState_LinkDescription_Direction_Direction_MAX = LinkState_LinkDescription_Direction_OUTPUT
constexpr int LinkState_LinkDescription_Direction_Direction_ARRAYSIZE = LinkState_LinkDescription_Direction_Direction_MAX + 1
constexpr MousePointer_Ratio MousePointer_Ratio_Ratio_MIN = MousePointer_Ratio_BOTH
constexpr MousePointer_Ratio MousePointer_Ratio_Ratio_MAX = MousePointer_Ratio_WIDTH
constexpr int MousePointer_Ratio_Ratio_ARRAYSIZE = MousePointer_Ratio_Ratio_MAX + 1
constexpr QtEvent_QtEventType QtEvent_QtEventType_QtEventType_MIN = QtEvent_QtEventType_CHAT
constexpr QtEvent_QtEventType QtEvent_QtEventType_QtEventType_MAX = QtEvent_QtEventType_OTHER
constexpr int QtEvent_QtEventType_QtEventType_ARRAYSIZE = QtEvent_QtEventType_QtEventType_MAX + 1
Enumeration Type Documentation
◆ Variant_Type
Enumerator
Variant_Type_INT
Variant_Type_IDTYPE
Variant_Type_STRING
Variant_Type_PROXY
Variant_Type_INPUT
Variant_Type_BYTES
Variant_Type_MAP
Definition at line 160 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription_Direction
Enumerator
Definition at line 189 of file vtkPVMessage.pb.h.
◆ MousePointer_Ratio
Enumerator
Definition at line 213 of file vtkPVMessage.pb.h.
◆ QtEvent_QtEventType
Enumerator
Definition at line 237 of file vtkPVMessage.pb.h.
Function Documentation
◆ Variant_Type_IsValid()
VTKREMOTINGSERVERMANAGER_EXPORT bool paraview_protobuf::Variant_Type_IsValid ( int  value)
◆ Variant_Type_descriptor()
VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::Variant_Type_descriptor ( )
◆ Variant_Type_Name()
const std::string& paraview_protobuf::Variant_Type_Name ( T  enum_t_value)
inline
Definition at line 177 of file vtkPVMessage.pb.h.
◆ Variant_Type_Parse()
bool paraview_protobuf::Variant_Type_Parse ( ::PROTOBUF_NAMESPACE_ID::ConstStringParam  name,
Variant_Type *  value
inline
Definition at line 184 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription_Direction_IsValid()
VTKREMOTINGSERVERMANAGER_EXPORT bool paraview_protobuf::LinkState_LinkDescription_Direction_IsValid ( int  value)
◆ LinkState_LinkDescription_Direction_descriptor()
VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::LinkState_LinkDescription_Direction_descriptor ( )
◆ LinkState_LinkDescription_Direction_Name()
const std::string& paraview_protobuf::LinkState_LinkDescription_Direction_Name ( T  enum_t_value)
inline
Definition at line 201 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription_Direction_Parse()
bool paraview_protobuf::LinkState_LinkDescription_Direction_Parse ( ::PROTOBUF_NAMESPACE_ID::ConstStringParam  name,
LinkState_LinkDescription_Direction *  value
inline
Definition at line 208 of file vtkPVMessage.pb.h.
◆ MousePointer_Ratio_IsValid()
VTKREMOTINGSERVERMANAGER_EXPORT bool paraview_protobuf::MousePointer_Ratio_IsValid ( int  value)
◆ MousePointer_Ratio_descriptor()
VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::MousePointer_Ratio_descriptor ( )
◆ MousePointer_Ratio_Name()
const std::string& paraview_protobuf::MousePointer_Ratio_Name ( T  enum_t_value)
inline
Definition at line 225 of file vtkPVMessage.pb.h.
◆ MousePointer_Ratio_Parse()
bool paraview_protobuf::MousePointer_Ratio_Parse ( ::PROTOBUF_NAMESPACE_ID::ConstStringParam  name,
MousePointer_Ratio *  value
inline
Definition at line 232 of file vtkPVMessage.pb.h.
◆ QtEvent_QtEventType_IsValid()
VTKREMOTINGSERVERMANAGER_EXPORT bool paraview_protobuf::QtEvent_QtEventType_IsValid ( int  value)
◆ QtEvent_QtEventType_descriptor()
VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::QtEvent_QtEventType_descriptor ( )
◆ QtEvent_QtEventType_Name()
const std::string& paraview_protobuf::QtEvent_QtEventType_Name ( T  enum_t_value)
inline
Definition at line 248 of file vtkPVMessage.pb.h.
◆ QtEvent_QtEventType_Parse()
bool paraview_protobuf::QtEvent_QtEventType_Parse ( ::PROTOBUF_NAMESPACE_ID::ConstStringParam  name,
QtEvent_QtEventType *  value
inline
Definition at line 255 of file vtkPVMessage.pb.h.
Variable Documentation
◆ _ChartViewBounds_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ChartViewBoundsDefaultTypeInternal paraview_protobuf::_ChartViewBounds_default_instance_
◆ _ChatMessage_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ChatMessageDefaultTypeInternal paraview_protobuf::_ChatMessage_default_instance_
◆ _ClientsInformation_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ClientsInformationDefaultTypeInternal paraview_protobuf::_ClientsInformation_default_instance_
◆ _ClientsInformation_ClientInfo_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ClientsInformation_ClientInfoDefaultTypeInternal paraview_protobuf::_ClientsInformation_ClientInfo_default_instance_
◆ _DefinitionHeader_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT DefinitionHeaderDefaultTypeInternal paraview_protobuf::_DefinitionHeader_default_instance_
◆ _LinkState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT LinkStateDefaultTypeInternal paraview_protobuf::_LinkState_default_instance_
◆ _LinkState_LinkDescription_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT LinkState_LinkDescriptionDefaultTypeInternal paraview_protobuf::_LinkState_LinkDescription_default_instance_
◆ _Message_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT MessageDefaultTypeInternal paraview_protobuf::_Message_default_instance_
◆ _MessageCollection_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT MessageCollectionDefaultTypeInternal paraview_protobuf::_MessageCollection_default_instance_
◆ _MousePointer_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT MousePointerDefaultTypeInternal paraview_protobuf::_MousePointer_default_instance_
◆ _PXMRegistrationState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT PXMRegistrationStateDefaultTypeInternal paraview_protobuf::_PXMRegistrationState_default_instance_
◆ _PXMRegistrationState_Entry_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT PXMRegistrationState_EntryDefaultTypeInternal paraview_protobuf::_PXMRegistrationState_Entry_default_instance_
◆ _ProxyDefinitionState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyDefinitionStateDefaultTypeInternal paraview_protobuf::_ProxyDefinitionState_default_instance_
◆ _ProxyDefinitionState_ProxyXMLDefinition_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyDefinitionState_ProxyXMLDefinitionDefaultTypeInternal paraview_protobuf::_ProxyDefinitionState_ProxyXMLDefinition_default_instance_
◆ _ProxySelectionModelState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxySelectionModelStateDefaultTypeInternal paraview_protobuf::_ProxySelectionModelState_default_instance_
◆ _ProxyState_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyStateDefaultTypeInternal paraview_protobuf::_ProxyState_default_instance_
◆ _ProxyState_Annotation_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_AnnotationDefaultTypeInternal paraview_protobuf::_ProxyState_Annotation_default_instance_
◆ _ProxyState_Property_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_PropertyDefaultTypeInternal paraview_protobuf::_ProxyState_Property_default_instance_
◆ _ProxyState_SubProxy_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_SubProxyDefaultTypeInternal paraview_protobuf::_ProxyState_SubProxy_default_instance_
◆ _ProxyState_UserData_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_UserDataDefaultTypeInternal paraview_protobuf::_ProxyState_UserData_default_instance_
◆ _PullRequest_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT PullRequestDefaultTypeInternal paraview_protobuf::_PullRequest_default_instance_
◆ _QtEvent_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT QtEventDefaultTypeInternal paraview_protobuf::_QtEvent_default_instance_
◆ _Variant_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT VariantDefaultTypeInternal paraview_protobuf::_Variant_default_instance_
◆ _VariantList_default_instance_
VTKREMOTINGSERVERMANAGER_EXPORT VariantListDefaultTypeInternal paraview_protobuf::_VariantList_default_instance_
◆ Variant_Type_Type_MIN
constexpr Variant_Type paraview_protobuf::Variant_Type_Type_MIN = Variant_Type_INT
Definition at line 171 of file vtkPVMessage.pb.h.
◆ Variant_Type_Type_MAX
constexpr Variant_Type paraview_protobuf::Variant_Type_Type_MAX = Variant_Type_MAP
Definition at line 172 of file vtkPVMessage.pb.h.
◆ Variant_Type_Type_ARRAYSIZE
constexpr int paraview_protobuf::Variant_Type_Type_ARRAYSIZE = Variant_Type_Type_MAX + 1
Definition at line 173 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription_Direction_Direction_MIN
constexpr LinkState_LinkDescription_Direction paraview_protobuf::LinkState_LinkDescription_Direction_Direction_MIN = LinkState_LinkDescription_Direction_NONE
Definition at line 195 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription_Direction_Direction_MAX
constexpr LinkState_LinkDescription_Direction paraview_protobuf::LinkState_LinkDescription_Direction_Direction_MAX = LinkState_LinkDescription_Direction_OUTPUT
Definition at line 196 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription_Direction_Direction_ARRAYSIZE
constexpr int paraview_protobuf::LinkState_LinkDescription_Direction_Direction_ARRAYSIZE = LinkState_LinkDescription_Direction_Direction_MAX + 1
Definition at line 197 of file vtkPVMessage.pb.h.
◆ MousePointer_Ratio_Ratio_MIN
constexpr MousePointer_Ratio paraview_protobuf::MousePointer_Ratio_Ratio_MIN = MousePointer_Ratio_BOTH
Definition at line 219 of file vtkPVMessage.pb.h.
◆ MousePointer_Ratio_Ratio_MAX
constexpr MousePointer_Ratio paraview_protobuf::MousePointer_Ratio_Ratio_MAX = MousePointer_Ratio_WIDTH
Definition at line 220 of file vtkPVMessage.pb.h.
◆ MousePointer_Ratio_Ratio_ARRAYSIZE
constexpr int paraview_protobuf::MousePointer_Ratio_Ratio_ARRAYSIZE = MousePointer_Ratio_Ratio_MAX + 1
Definition at line 221 of file vtkPVMessage.pb.h.
◆ QtEvent_QtEventType_QtEventType_MIN
constexpr QtEvent_QtEventType paraview_protobuf::QtEvent_QtEventType_QtEventType_MIN = QtEvent_QtEventType_CHAT
Definition at line 242 of file vtkPVMessage.pb.h.
◆ QtEvent_QtEventType_QtEventType_MAX
constexpr QtEvent_QtEventType paraview_protobuf::QtEvent_QtEventType_QtEventType_MAX = QtEvent_QtEventType_OTHER
Definition at line 243 of file vtkPVMessage.pb.h.
◆ QtEvent_QtEventType_QtEventType_ARRAYSIZE
constexpr int paraview_protobuf::QtEvent_QtEventType_QtEventType_ARRAYSIZE = QtEvent_QtEventType_QtEventType_MAX + 1
Definition at line 244 of file vtkPVMessage.pb.h.
