vtkSpyPlotReader Class Reference
Read SPCTH Spy Plot file format. More...
#include <vtkSpyPlotReader.h>
Inheritance diagram for vtkSpyPlotReader:
Collaboration diagram for vtkSpyPlotReader:
typedef vtkCompositeDataSetAlgorithm Superclass
- Public Types inherited from vtkCompositeDataSetAlgorithm
enum  DesiredOutputPrecision
void PrintBlockList (vtkNonOverlappingAMR *hbds, int myProcId)
void SetGlobalController (vtkMultiProcessController *controller)
 Set the controller used to coordinate parallel reading. More...
virtual int CanReadFile (const char *fname)
 Determine if the file can be read with this reader. More...
virtual void SetFileName (const char *filename)
 Get and set the file name. More...
virtual char * GetFileName ()
virtual void SetTimeStep (int)
 Set and get the time step. More...
virtual int GetTimeStep ()
virtual void SetDistributeFiles (int)
 If true, the reader distributes files over processors. More...
virtual int GetDistributeFiles ()
virtual void DistributeFilesOn ()
virtual void DistributeFilesOff ()
virtual void SetGenerateLevelArray (int)
 If true, the reader generate a cell array in each block that stores the level in the hierarchy, starting from 0. More...
virtual int GetGenerateLevelArray ()
virtual void GenerateLevelArrayOn ()
virtual void GenerateLevelArrayOff ()
virtual void SetGenerateBlockIdArray (int)
 If true, the reader generate a cell array in each block that stores a unique but not necessarily contiguous id. More...
virtual int GetGenerateBlockIdArray ()
virtual void GenerateBlockIdArrayOn ()
virtual void GenerateBlockIdArrayOff ()
virtual void SetGenerateActiveBlockArray (int)
 If true, the reader generate a cell array in each block that corresponds to the Active field in the file. More...
virtual int GetGenerateActiveBlockArray ()
virtual void GenerateActiveBlockArrayOn ()
virtual void GenerateActiveBlockArrayOff ()
virtual void SetGenerateTracerArray (int)
 If true, the reader will extract tracer data at each time step and include a field data array for the tracers at that time. More...
virtual int GetGenerateTracerArray ()
virtual void GenerateTracerArrayOn ()
virtual void GenerateTracerArrayOff ()
void SetGenerateMarkers (int gm)
 if true, the reader will extract the marker data at each time step and create a set of vtkPoints in the second output port. More...
virtual int GetGenerateMarkers ()
virtual void GenerateMarkersOn ()
virtual void GenerateMarkersOff ()
void SetDownConvertVolumeFraction (int vf)
 If true, the reader will convert volume fraction arrays to unsigned char. More...
virtual int GetDownConvertVolumeFraction ()
virtual void DownConvertVolumeFractionOn ()
virtual void DownConvertVolumeFractionOff ()
virtual void SetComputeDerivedVariables (int)
 If true, the reader will calculate all derived variables it can given which properties the user has selected True by default. More...
virtual int GetComputeDerivedVariables ()
virtual void ComputeDerivedVariablesOn ()
virtual void ComputeDerivedVariablesOff ()
void SetMergeXYZComponents (int merge)
 If true, the reader will merge scalar arrays named, for example, "X velocity" "Y velocity" and "Z velocity" into a vector array named "velocity" with scalar components X, Y and Z. More...
virtual int GetMergeXYZComponents ()
virtual void MergeXYZComponentsOn ()
virtual void MergeXYZComponentsOff ()
virtual int * GetTimeStepRange ()
 Get the time step range. More...
virtual void GetTimeStepRange (int &, int &)
virtual void GetTimeStepRange (int [2])
int GetNumberOfCellArrays ()
 Cell array selection. More...
const char * GetCellArrayName (int idx)
int GetCellArrayStatus (const char *name)
void SetCellArrayStatus (const char *name, int status)
- Public Member Functions inherited from vtkCompositeDataSetAlgorithm
vtkCompositeDataSetAlgorithm * NewInstance () const
vtkCompositeDataSet * GetOutput ()
vtkCompositeDataSet * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkSpyPlotReader * New ()
static vtkSpyPlotReader * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCompositeDataSetAlgorithm
static vtkCompositeDataSetAlgorithm * New ()
static vtkCompositeDataSetAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkSpyPlotReader ()
 ~vtkSpyPlotReader () override
void GetLocalBounds (vtkSpyPlotBlockIterator *biter, int nBlocks, int progressInterval)
void SetGlobalBounds (vtkSpyPlotBlockIterator *biter, int total_num_of_block, int progressInterval, int *rightHasBounds, int *leftHasBounds)
bool GetLocalBoxSize (vtkSpyPlotBlockIterator *biter, int *localBoxSize) const
void SetGlobalBoxSize (vtkSpyPlotBlockIterator *biter)
void GetLocalMinLevelAndSpacing (vtkSpyPlotBlockIterator *biter, int *localMinLevel, double spacing[3]) const
void SetGlobalMinLevelAndSpacing (vtkSpyPlotBlockIterator *biter)
int PrepareAMRData (vtkNonOverlappingAMR *hb, vtkSpyPlotBlock *block, int *level, int *blockId, int extents[6], int realExtents[6], int realDims[3], vtkCellData **cd)
int PrepareData (vtkMultiBlockDataSet *hb, vtkSpyPlotBlock *block, vtkRectilinearGrid **rg, int extents[6], int realExtents[6], int realDims[3], vtkCellData **cd)
void UpdateFieldData (int numFields, int dims[3], int level, int blockID, vtkSpyPlotUniReader *uniReader, vtkCellData *cd)
void UpdateBadGhostFieldData (int numFields, int dims[3], int realDims[3], int realExtents[6], int level, int blockID, vtkSpyPlotUniReader *uniReader, vtkCellData *cd)
void PrepareBlocks (vtkMultiBlockDataSet *poly, int numMat)
int PrepareMarkers (vtkMultiBlockDataSet *poly, vtkSpyPlotUniReader *reader)
int RequestDataObject (vtkInformation *req, vtkInformationVector **inV, vtkInformationVector *outV) override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
int UpdateMetaData (vtkInformation *request, vtkInformationVector *outputVector)
 This does the updating of meta data of the dataset from the first binary file registered in the map: More...
int UpdateFile (vtkInformation *request, vtkInformationVector *outputVector)
void AddGhostLevelArray (int numLevels)
int AddBlockIdArray (vtkCompositeDataSet *cds)
int AddAttributes (vtkNonOverlappingAMR *hbds)
int AddActiveBlockArray (vtkCellData *cd, vtkIdType nCells, unsigned char status)
void SetGlobalLevels (vtkCompositeDataSet *cds)
int UpdateTimeStep (vtkInformation *requestInfo, vtkInformationVector *outputInfo, vtkCompositeDataSet *hb)
 Set the current time step. More...
int UpdateTimeStep (double time, int piece=-1, int numPieces=1, int ghostLevels=0, const int extents[6]=nullptr) override
 Overwritten to avoid hiding. More...
void MergeVectors (vtkDataSetAttributes *da)
int MergeVectors (vtkDataSetAttributes *da, vtkDataArray *a1, vtkDataArray *a2)
int MergeVectors (vtkDataSetAttributes *da, vtkDataArray *a1, vtkDataArray *a2, vtkDataArray *a3)
int ComputeDerivedVars (vtkCellData *data, vtkSpyPlotBlock *block, vtkSpyPlotUniReader *reader, const int &blockID)
virtual vtkDataArraySelection * GetCellDataArraySelection ()
 Get the data array selection tables used to configure which data arrays are loaded by the reader. More...
- Protected Member Functions inherited from vtkCompositeDataSetAlgorithm
 vtkCompositeDataSetAlgorithm ()
 ~vtkCompositeDataSetAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkDataArraySelection * CellDataArraySelection
char * FileName
int TimeStep
int TimeStepRange [2]
int CurrentTimeStep
int IsAMR
vtkMultiProcessController * GlobalController
int ComputeDerivedVariables
vtkSpyPlotReaderMap * Map
int DistributeFiles
vtkBoundingBox * Bounds
int BoxSize [3]
int MinLevel
double MinLevelSpacing [3]
int GenerateLevelArray
int GenerateBlockIdArray
int GenerateActiveBlockArray
int GenerateTracerArray
int GenerateMarkers
int DownConvertVolumeFraction
bool TimeRequestedFromPipeline
int MergeXYZComponents
bool FileNameChanged
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
Friends
class vtkSpyPlotReaderMap
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkSpyPlotReader is a reader that reads SPCTH Spy Plot file format through an ascii meta file called the "case" file (extension .spcth). This case file lists all the actual binary files that describe a dataset. Each binary file describes a part of the dataset. However, if only a single binary file describes the whole dataset, it is possible to load it directly without using a case file.
The reader supports both Spy dataset types: flat mesh and AMR (Adaptive Mesh Refinement).
It has parallel capabilities. Each processor is supposed to have access to the case file and to all the binary files. All the binary files have to be coherent: they describe the same fields of data. Each binary file may content multiple time stamp. The time stamp to read is specified with SetTimestamp().
In parallel mode, there are two ways to distribute data over processors (controlled by SetDistributeFiles() ):
Implementation Details:
  • All processors read the first binary file listed in the case file to get information about the fields.
  • Each block of data is already surrounded by ghost cells in the file, even on part of the block that don't have actual neighbor cells. The reader removes those wrong ghost cells.
  • Each time step contains all the cell array name variables
Definition at line 63 of file vtkSpyPlotReader.h.
Definition at line 67 of file vtkSpyPlotReader.h.
◆ vtkSpyPlotReader()
vtkSpyPlotReader::vtkSpyPlotReader ( )
◆ ~vtkSpyPlotReader()
vtkSpyPlotReader::~vtkSpyPlotReader ( )
static vtkSpyPlotReader* vtkSpyPlotReader::New ( )
virtual const char* vtkSpyPlotReader::GetClassName ( )
static int vtkSpyPlotReader::IsTypeOf ( const char *  type)
virtual int vtkSpyPlotReader::IsA ( const char *  type)
Reimplemented from vtkCompositeDataSetAlgorithm.
static vtkSpyPlotReader* vtkSpyPlotReader::SafeDownCast ( vtkObject *  o)
void vtkSpyPlotReader::PrintSelf ( ostream &  os,
◆ PrintBlockList()
void vtkSpyPlotReader::PrintBlockList ( vtkNonOverlappingAMR *  hbds,
int  myProcId
◆ SetFileName()
virtual void vtkSpyPlotReader::SetFileName ( const char *  filename)
It is either the name of the case file or the name of the single binary file.
◆ GetFileName()
virtual char* vtkSpyPlotReader::GetFileName ( )
◆ SetTimeStep()
virtual void vtkSpyPlotReader::SetTimeStep ( int  )
The time step is an index, NOT a time given in seconds.
◆ GetTimeStep()
virtual int vtkSpyPlotReader::GetTimeStep ( )
◆ SetDistributeFiles()
virtual void vtkSpyPlotReader::SetDistributeFiles ( int  )
If false, the reader distributes blocks over processors. Default is false. Distributing blocks should provide a better load balancing: if there is only one file and several processors, only the first processor is used in the case of the file-distributed method.
◆ GetDistributeFiles()
virtual int vtkSpyPlotReader::GetDistributeFiles ( )
◆ DistributeFilesOn()
virtual void vtkSpyPlotReader::DistributeFilesOn ( )
◆ DistributeFilesOff()
virtual void vtkSpyPlotReader::DistributeFilesOff ( )
◆ SetGenerateLevelArray()
virtual void vtkSpyPlotReader::SetGenerateLevelArray ( int  )
False by default.
◆ GetGenerateLevelArray()
virtual int vtkSpyPlotReader::GetGenerateLevelArray ( )
False by default.
◆ GenerateLevelArrayOn()
virtual void vtkSpyPlotReader::GenerateLevelArrayOn ( )
False by default.
◆ GenerateLevelArrayOff()
virtual void vtkSpyPlotReader::GenerateLevelArrayOff ( )
False by default.
◆ SetGenerateBlockIdArray()
virtual void vtkSpyPlotReader::SetGenerateBlockIdArray ( int  )
False by default.
◆ GetGenerateBlockIdArray()
virtual int vtkSpyPlotReader::GetGenerateBlockIdArray ( )
False by default.
◆ GenerateBlockIdArrayOn()
virtual void vtkSpyPlotReader::GenerateBlockIdArrayOn ( )
False by default.
◆ GenerateBlockIdArrayOff()
virtual void vtkSpyPlotReader::GenerateBlockIdArrayOff ( )
False by default.
◆ SetGenerateActiveBlockArray()
virtual void vtkSpyPlotReader::SetGenerateActiveBlockArray ( int  )
False by default.
◆ GetGenerateActiveBlockArray()
virtual int vtkSpyPlotReader::GetGenerateActiveBlockArray ( )
False by default.
◆ GenerateActiveBlockArrayOn()
virtual void vtkSpyPlotReader::GenerateActiveBlockArrayOn ( )
False by default.
◆ GenerateActiveBlockArrayOff()
virtual void vtkSpyPlotReader::GenerateActiveBlockArrayOff ( )
False by default.
◆ SetGenerateTracerArray()
virtual void vtkSpyPlotReader::SetGenerateTracerArray ( int  )
◆ GetGenerateTracerArray()
virtual int vtkSpyPlotReader::GetGenerateTracerArray ( )
◆ GenerateTracerArrayOn()
virtual void vtkSpyPlotReader::GenerateTracerArrayOn ( )
◆ GenerateTracerArrayOff()
virtual void vtkSpyPlotReader::GenerateTracerArrayOff ( )
◆ SetGenerateMarkers()
void vtkSpyPlotReader::SetGenerateMarkers ( int  gm)
◆ GetGenerateMarkers()
virtual int vtkSpyPlotReader::GetGenerateMarkers ( )
◆ GenerateMarkersOn()
virtual void vtkSpyPlotReader::GenerateMarkersOn ( )
◆ GenerateMarkersOff()
virtual void vtkSpyPlotReader::GenerateMarkersOff ( )
◆ SetDownConvertVolumeFraction()
void vtkSpyPlotReader::SetDownConvertVolumeFraction ( int  vf)
True by default.
◆ GetDownConvertVolumeFraction()
virtual int vtkSpyPlotReader::GetDownConvertVolumeFraction ( )
True by default.
◆ DownConvertVolumeFractionOn()
virtual void vtkSpyPlotReader::DownConvertVolumeFractionOn ( )
True by default.
◆ DownConvertVolumeFractionOff()
virtual void vtkSpyPlotReader::DownConvertVolumeFractionOff ( )
True by default.
◆ SetComputeDerivedVariables()
virtual void vtkSpyPlotReader::SetComputeDerivedVariables ( int  )
◆ GetComputeDerivedVariables()
virtual int vtkSpyPlotReader::GetComputeDerivedVariables ( )
◆ ComputeDerivedVariablesOn()
virtual void vtkSpyPlotReader::ComputeDerivedVariablesOn ( )
◆ ComputeDerivedVariablesOff()
virtual void vtkSpyPlotReader::ComputeDerivedVariablesOff ( )
◆ SetMergeXYZComponents()
void vtkSpyPlotReader::SetMergeXYZComponents ( int  merge)
It will also merge X and Y scalar arrays (with no Z component) into a vector with scalar components X, Y and 0. True by default.
◆ GetMergeXYZComponents()
virtual int vtkSpyPlotReader::GetMergeXYZComponents ( )
◆ MergeXYZComponentsOn()
virtual void vtkSpyPlotReader::MergeXYZComponentsOn ( )
◆ MergeXYZComponentsOff()
virtual void vtkSpyPlotReader::MergeXYZComponentsOff ( )
◆ GetTimeStepRange() [1/3]
virtual int* vtkSpyPlotReader::GetTimeStepRange ( )
◆ GetTimeStepRange() [2/3]
virtual void vtkSpyPlotReader::GetTimeStepRange ( int &  ,
int &
◆ GetTimeStepRange() [3/3]
virtual void vtkSpyPlotReader::GetTimeStepRange ( int  [2])
◆ GetNumberOfCellArrays()
int vtkSpyPlotReader::GetNumberOfCellArrays ( )
◆ GetCellArrayName()
const char* vtkSpyPlotReader::GetCellArrayName ( int  idx)
◆ GetCellArrayStatus()
int vtkSpyPlotReader::GetCellArrayStatus ( const char *  name)
◆ SetCellArrayStatus()
void vtkSpyPlotReader::SetCellArrayStatus ( const char *  name,
int  status
◆ SetGlobalController()
void vtkSpyPlotReader::SetGlobalController ( vtkMultiProcessController *  controller)
The "global controller" has all processes while the "controller" has only those who have blocks.
◆ CanReadFile()
virtual int vtkSpyPlotReader::CanReadFile ( const char *  fname)
◆ GetLocalBounds()
void vtkSpyPlotReader::GetLocalBounds ( vtkSpyPlotBlockIterator *  biter,
int  nBlocks,
◆ SetGlobalBounds()
void vtkSpyPlotReader::SetGlobalBounds ( vtkSpyPlotBlockIterator *  biter,
int *  rightHasBounds,
int *  leftHasBounds
◆ GetLocalBoxSize()
bool vtkSpyPlotReader::GetLocalBoxSize ( vtkSpyPlotBlockIterator *  biter,
int *  localBoxSize
) const
◆ SetGlobalBoxSize()
void vtkSpyPlotReader::SetGlobalBoxSize ( vtkSpyPlotBlockIterator *  biter)
◆ GetLocalMinLevelAndSpacing()
void vtkSpyPlotReader::GetLocalMinLevelAndSpacing ( vtkSpyPlotBlockIterator *  biter,
int *  localMinLevel,
double  spacing[3]
) const
◆ SetGlobalMinLevelAndSpacing()
void vtkSpyPlotReader::SetGlobalMinLevelAndSpacing ( vtkSpyPlotBlockIterator *  biter)
◆ PrepareAMRData()
int vtkSpyPlotReader::PrepareAMRData ( vtkNonOverlappingAMR *  hb,
vtkSpyPlotBlock *  block,
int *  level,
int *  blockId,
int  extents[6],
int  realExtents[6],
int  realDims[3],
vtkCellData **  cd
◆ PrepareData()
int vtkSpyPlotReader::PrepareData ( vtkMultiBlockDataSet *  hb,
vtkRectilinearGrid **  rg,
int  extents[6],
int  realExtents[6],
int  realDims[3],
vtkCellData **  cd
◆ UpdateFieldData()
void vtkSpyPlotReader::UpdateFieldData ( int  numFields,
int  dims[3],
int  level,
int  blockID,
vtkSpyPlotUniReader *  uniReader,
vtkCellData *  cd
◆ UpdateBadGhostFieldData()
void vtkSpyPlotReader::UpdateBadGhostFieldData ( int  numFields,
int  dims[3],
int  realDims[3],
int  realExtents[6],
int  level,
int  blockID,
vtkCellData *  cd
◆ PrepareBlocks()
void vtkSpyPlotReader::PrepareBlocks ( vtkMultiBlockDataSet *  poly,
int  numMat
◆ PrepareMarkers()
int vtkSpyPlotReader::PrepareMarkers ( vtkMultiBlockDataSet *  poly,
vtkSpyPlotUniReader *  reader
◆ FillOutputPortInformation()
int vtkSpyPlotReader::FillOutputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ RequestDataObject()
int vtkSpyPlotReader::RequestDataObject ( vtkInformation *  req,
vtkInformationVector **  inV,
vtkInformationVector *  outV
◆ RequestInformation()
int vtkSpyPlotReader::RequestInformation ( vtkInformation *  request,
◆ RequestData()
int vtkSpyPlotReader::RequestData ( vtkInformation *  request,
◆ UpdateMetaData()
int vtkSpyPlotReader::UpdateMetaData ( vtkInformation *  request,
  • number of time steps
  • number of fields
  • name of fields
◆ UpdateFile()
int vtkSpyPlotReader::UpdateFile ( vtkInformation *  request,
◆ AddGhostLevelArray()
void vtkSpyPlotReader::AddGhostLevelArray ( int  numLevels)
◆ AddBlockIdArray()
int vtkSpyPlotReader::AddBlockIdArray ( vtkCompositeDataSet *  cds)
◆ AddAttributes()
int vtkSpyPlotReader::AddAttributes ( vtkNonOverlappingAMR *  hbds)
◆ AddActiveBlockArray()
int vtkSpyPlotReader::AddActiveBlockArray ( vtkCellData *  cd,
vtkIdType  nCells,
◆ SetGlobalLevels()
void vtkSpyPlotReader::SetGlobalLevels ( vtkCompositeDataSet *  cds)
◆ UpdateTimeStep() [1/2]
int vtkSpyPlotReader::UpdateTimeStep ( vtkInformation *  requestInfo,
vtkInformationVector *  outputInfo,
vtkCompositeDataSet *  hb
◆ UpdateTimeStep() [2/2]
int vtkSpyPlotReader::UpdateTimeStep ( double  time,
int  piece = -1,
int  numPieces = 1,
int  ghostLevels = 0,
const int  extents[6] = nullptr
inlineoverrideprotectedvirtual
Definition at line 335 of file vtkSpyPlotReader.h.
◆ MergeVectors() [1/3]
void vtkSpyPlotReader::MergeVectors ( vtkDataSetAttributes *  da)
◆ MergeVectors() [2/3]
int vtkSpyPlotReader::MergeVectors ( vtkDataSetAttributes *  da,
vtkDataArray *  a1,
vtkDataArray *  a2
◆ MergeVectors() [3/3]
vtkDataArray *  a1,
vtkDataArray *  a2,
vtkDataArray *  a3
◆ ComputeDerivedVars()
int vtkSpyPlotReader::ComputeDerivedVars ( vtkCellData *  data,
vtkSpyPlotUniReader *  reader,
const int &  blockID
◆ GetCellDataArraySelection()
virtual vtkDataArraySelection* vtkSpyPlotReader::GetCellDataArraySelection ( )
protectedvirtual
◆ vtkSpyPlotReaderMap
friend class vtkSpyPlotReaderMap
friend
Definition at line 357 of file vtkSpyPlotReader.h.
◆ CellDataArraySelection
vtkDataArraySelection* vtkSpyPlotReader::CellDataArraySelection
Definition at line 274 of file vtkSpyPlotReader.h.
◆ FileName
char* vtkSpyPlotReader::FileName
Definition at line 314 of file vtkSpyPlotReader.h.
◆ TimeStep
int vtkSpyPlotReader::TimeStep
Definition at line 316 of file vtkSpyPlotReader.h.
◆ TimeStepRange
int vtkSpyPlotReader::TimeStepRange[2]
Definition at line 317 of file vtkSpyPlotReader.h.
◆ CurrentTimeStep
int vtkSpyPlotReader::CurrentTimeStep
Definition at line 318 of file vtkSpyPlotReader.h.
◆ IsAMR
int vtkSpyPlotReader::IsAMR
Definition at line 320 of file vtkSpyPlotReader.h.
◆ GlobalController
vtkMultiProcessController* vtkSpyPlotReader::GlobalController
Definition at line 324 of file vtkSpyPlotReader.h.
int vtkSpyPlotReader::ComputeDerivedVariables
Definition at line 348 of file vtkSpyPlotReader.h.
◆ Map
vtkSpyPlotReaderMap* vtkSpyPlotReader::Map
Definition at line 362 of file vtkSpyPlotReader.h.
◆ DistributeFiles
int vtkSpyPlotReader::DistributeFiles
Definition at line 364 of file vtkSpyPlotReader.h.
◆ Bounds
vtkBoundingBox* vtkSpyPlotReader::Bounds
Definition at line 366 of file vtkSpyPlotReader.h.
◆ BoxSize
int vtkSpyPlotReader::BoxSize[3]
Definition at line 367 of file vtkSpyPlotReader.h.
◆ MinLevel
int vtkSpyPlotReader::MinLevel
Definition at line 368 of file vtkSpyPlotReader.h.
◆ MinLevelSpacing
double vtkSpyPlotReader::MinLevelSpacing[3]
Definition at line 369 of file vtkSpyPlotReader.h.
int vtkSpyPlotReader::GenerateLevelArray
Definition at line 371 of file vtkSpyPlotReader.h.
int vtkSpyPlotReader::GenerateBlockIdArray
Definition at line 372 of file vtkSpyPlotReader.h.
int vtkSpyPlotReader::GenerateActiveBlockArray
Definition at line 373 of file vtkSpyPlotReader.h.
int vtkSpyPlotReader::GenerateTracerArray
Definition at line 374 of file vtkSpyPlotReader.h.
◆ GenerateMarkers
int vtkSpyPlotReader::GenerateMarkers
Definition at line 375 of file vtkSpyPlotReader.h.
int vtkSpyPlotReader::DownConvertVolumeFraction
Definition at line 377 of file vtkSpyPlotReader.h.
◆ TimeRequestedFromPipeline
bool vtkSpyPlotReader::TimeRequestedFromPipeline
Definition at line 379 of file vtkSpyPlotReader.h.
int vtkSpyPlotReader::MergeXYZComponents
Definition at line 381 of file vtkSpyPlotReader.h.
◆ FileNameChanged
bool vtkSpyPlotReader::FileNameChanged
Definition at line 384 of file vtkSpyPlotReader.h.
