vtkPVServerInformation Class Reference
Gets features of the server. More...
#include <vtkPVServerInformation.h>
Inheritance diagram for vtkPVServerInformation:
Collaboration diagram for vtkPVServerInformation:
typedef vtkPVInformation Superclass
- Public Types inherited from vtkPVInformation
virtual bool GetIsInTileDisplay ()
 Returns true if server is in tile-display mode. More...
virtual bool GetIsInCave ()
 Returns true if server is in CAVE mode. More...
void DeepCopy (vtkPVServerInformation *info)
void CopyFromObject (vtkObject *) override
 Transfer information about a single object into this object. More...
void AddInformation (vtkPVInformation *) override
 Merge another information object. More...
virtual void SetNVPipeSupport (bool)
 if the server supports compressing images via NVPipe More...
virtual bool GetNVPipeSupport ()
virtual int * GetTileDimensions ()
 When in tile display mode, returns the tile dimensions. More...
virtual void GetTileDimensions (int &, int &)
virtual void GetTileDimensions (int [2])
virtual bool IsMPIInitialized () const
 Return whether MPI is initialized or not. More...
virtual void SetRemoteRendering (int)
 This flag indicates whether the server can render remotely. More...
virtual int GetRemoteRendering ()
void CopyToStream (vtkClientServerStream *) override
 Manage a serialized version of the information. More...
void CopyFromStream (const vtkClientServerStream *) override
virtual void SetUseIceT (int)
 Returns 1 if IceT is available. More...
virtual int GetUseIceT ()
virtual void SetTimeout (int)
 Get/Set the time after which the server timesout. More...
virtual int GetTimeout ()
const std::string & GetTimeoutCommand () const
 Get the timeout command used by the server to retrieve remaining time. More...
virtual int GetTimeoutCommandInterval ()
 Get the time interval in seconds between consecutive calls of TimeoutCommand. More...
virtual int GetNumberOfProcesses ()
 Get the number of processes. More...
virtual int GetMultiClientsEnable ()
 Return true if the server allow server client to connect to itself. More...
virtual int GetClientId ()
 Get the id that correspond to the current client. More...
virtual void SetIdTypeSize (int)
 Set/Get vtkIdType size, which can be 32 or 64. More...
virtual int GetIdTypeSize ()
virtual std::string GetSMPBackendName ()
 Get the SMP Tools backend name of the server. More...
virtual int GetSMPMaxNumberOfThreads ()
 Get the max number of threads of the server. More...
virtual int GetAcceleratedFiltersOverrideAvailable ()
 Return true if VTK-m accelerated filters override is enabled in this build. More...
- Public Member Functions inherited from vtkPVInformation
virtual void CopyParametersToStream (vtkMultiProcessStream &)
 Serialize/Deserialize the parameters that control how/what information is gathered. More...
virtual void CopyParametersFromStream (vtkMultiProcessStream &)
virtual int GetRootOnly ()
 Set/get whether to gather information only from the root. More...
static vtkPVServerInformation * New ()
static vtkPVServerInformation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVInformation
static vtkPVInformation * SafeDownCast (vtkObject *o)
 vtkPVServerInformation ()
 ~vtkPVServerInformation () override
- Protected Member Functions inherited from vtkPVInformation
 vtkPVInformation ()
 ~vtkPVInformation () override
virtual void SetRootOnly (int)
 vtkPVInformation (const vtkPVInformation &)=delete
void operator= (const vtkPVInformation &)=delete
int NumberOfProcesses
bool MPIInitialized
int OGVSupport = 1
int AVISupport = 0
bool NVPipeSupport = false
int RemoteRendering = 1
int Timeout = 0
std::string TimeoutCommand
int TimeoutCommandInterval = 60
int UseIceT
int MultiClientsEnable = 0
int ClientId = 0
int IdTypeSize = 0
bool IsInTileDisplay = false
bool IsInCave = false
int TileDimensions [2] = { 0, 0 }
std::string SMPBackendName
int SMPMaxNumberOfThreads
bool AcceleratedFiltersOverrideAvailable
- Protected Attributes inherited from vtkPVInformation
int RootOnly
This objects is used by the client to get the features supported by the server. At the moment, server information is only on the root.
Definition at line 22 of file vtkPVServerInformation.h.
Definition at line 26 of file vtkPVServerInformation.h.
◆ vtkPVServerInformation()
vtkPVServerInformation::vtkPVServerInformation ( )
◆ ~vtkPVServerInformation()
vtkPVServerInformation::~vtkPVServerInformation ( )
static vtkPVServerInformation* vtkPVServerInformation::New ( )
virtual const char* vtkPVServerInformation::GetClassName ( )
Reimplemented from vtkPVInformation.
static int vtkPVServerInformation::IsTypeOf ( const char *  type)
virtual int vtkPVServerInformation::IsA ( const char *  type)
static vtkPVServerInformation* vtkPVServerInformation::SafeDownCast ( vtkObject *  o)
void vtkPVServerInformation::PrintSelf ( ostream &  os,
◆ SetRemoteRendering()
virtual void vtkPVServerInformation::SetRemoteRendering ( int  )
If it is off, all rendering has to be on the client. This is only off when the user starts the server with the –disable-composite command line option.
◆ GetRemoteRendering()
virtual int vtkPVServerInformation::GetRemoteRendering ( )
◆ GetIsInTileDisplay()
virtual bool vtkPVServerInformation::GetIsInTileDisplay ( )
◆ GetIsInCave()
virtual bool vtkPVServerInformation::GetIsInCave ( )
◆ DeepCopy()
void vtkPVServerInformation::DeepCopy ( vtkPVServerInformation *  info)
◆ CopyFromObject()
void vtkPVServerInformation::CopyFromObject ( vtkObject *  )
◆ AddInformation()
void vtkPVServerInformation::AddInformation ( vtkPVInformation *  )
◆ CopyToStream()
void vtkPVServerInformation::CopyToStream ( vtkClientServerStream *  )
Implements vtkPVInformation.
◆ CopyFromStream()
void vtkPVServerInformation::CopyFromStream ( const vtkClientServerStream *  )
◆ SetUseIceT()
virtual void vtkPVServerInformation::SetUseIceT ( int  )
◆ GetUseIceT()
virtual int vtkPVServerInformation::GetUseIceT ( )
◆ SetNVPipeSupport()
virtual void vtkPVServerInformation::SetNVPipeSupport ( bool  )
◆ GetNVPipeSupport()
virtual bool vtkPVServerInformation::GetNVPipeSupport ( )
◆ SetTimeout()
virtual void vtkPVServerInformation::SetTimeout ( int  )
◆ GetTimeout()
virtual int vtkPVServerInformation::GetTimeout ( )
◆ GetTimeoutCommand()
const std::string& vtkPVServerInformation::GetTimeoutCommand ( ) const
inline
Definition at line 98 of file vtkPVServerInformation.h.
◆ GetTimeoutCommandInterval()
virtual int vtkPVServerInformation::GetTimeoutCommandInterval ( )
Defaults to 60.
◆ GetTileDimensions() [1/3]
virtual int* vtkPVServerInformation::GetTileDimensions ( )
◆ GetTileDimensions() [2/3]
virtual void vtkPVServerInformation::GetTileDimensions ( int &  ,
int &
◆ GetTileDimensions() [3/3]
virtual void vtkPVServerInformation::GetTileDimensions ( int  [2])
◆ GetNumberOfProcesses()
virtual int vtkPVServerInformation::GetNumberOfProcesses ( )
◆ IsMPIInitialized()
virtual bool vtkPVServerInformation::IsMPIInitialized ( ) const
◆ GetMultiClientsEnable()
virtual int vtkPVServerInformation::GetMultiClientsEnable ( )
◆ GetClientId()
virtual int vtkPVServerInformation::GetClientId ( )
◆ SetIdTypeSize()
virtual void vtkPVServerInformation::SetIdTypeSize ( int  )
◆ GetIdTypeSize()
virtual int vtkPVServerInformation::GetIdTypeSize ( )
◆ GetSMPBackendName()
virtual std::string vtkPVServerInformation::GetSMPBackendName ( )
◆ GetSMPMaxNumberOfThreads()
virtual int vtkPVServerInformation::GetSMPMaxNumberOfThreads ( )
◆ GetAcceleratedFiltersOverrideAvailable()
virtual int vtkPVServerInformation::GetAcceleratedFiltersOverrideAvailable ( )
◆ NumberOfProcesses
int vtkPVServerInformation::NumberOfProcesses
Definition at line 173 of file vtkPVServerInformation.h.
◆ MPIInitialized
bool vtkPVServerInformation::MPIInitialized
Definition at line 174 of file vtkPVServerInformation.h.
◆ OGVSupport
int vtkPVServerInformation::OGVSupport = 1
Definition at line 175 of file vtkPVServerInformation.h.
◆ AVISupport
int vtkPVServerInformation::AVISupport = 0
Definition at line 176 of file vtkPVServerInformation.h.
◆ NVPipeSupport
bool vtkPVServerInformation::NVPipeSupport = false
Definition at line 177 of file vtkPVServerInformation.h.
◆ RemoteRendering
int vtkPVServerInformation::RemoteRendering = 1
Definition at line 178 of file vtkPVServerInformation.h.
◆ Timeout
int vtkPVServerInformation::Timeout = 0
Definition at line 179 of file vtkPVServerInformation.h.
◆ TimeoutCommand
std::string vtkPVServerInformation::TimeoutCommand
Definition at line 180 of file vtkPVServerInformation.h.
◆ TimeoutCommandInterval
int vtkPVServerInformation::TimeoutCommandInterval = 60
Definition at line 181 of file vtkPVServerInformation.h.
◆ UseIceT
int vtkPVServerInformation::UseIceT
Definition at line 182 of file vtkPVServerInformation.h.
◆ MultiClientsEnable
int vtkPVServerInformation::MultiClientsEnable = 0
Definition at line 183 of file vtkPVServerInformation.h.
◆ ClientId
int vtkPVServerInformation::ClientId = 0
Definition at line 184 of file vtkPVServerInformation.h.
◆ IdTypeSize
int vtkPVServerInformation::IdTypeSize = 0
Definition at line 185 of file vtkPVServerInformation.h.
◆ IsInTileDisplay
bool vtkPVServerInformation::IsInTileDisplay = false
Definition at line 186 of file vtkPVServerInformation.h.
◆ IsInCave
bool vtkPVServerInformation::IsInCave = false
Definition at line 187 of file vtkPVServerInformation.h.
◆ TileDimensions
int vtkPVServerInformation::TileDimensions[2] = { 0, 0 }
Definition at line 188 of file vtkPVServerInformation.h.
◆ SMPBackendName
std::string vtkPVServerInformation::SMPBackendName
Definition at line 189 of file vtkPVServerInformation.h.
◆ SMPMaxNumberOfThreads
int vtkPVServerInformation::SMPMaxNumberOfThreads
Definition at line 190 of file vtkPVServerInformation.h.
◆ AcceleratedFiltersOverrideAvailable
bool vtkPVServerInformation::AcceleratedFiltersOverrideAvailable
Definition at line 191 of file vtkPVServerInformation.h.
