| virtual void | SetPassCellArrays (bool) |
| | Shallow copy the input cell data arrays to the output. More...
| virtual void | PassCellArraysOn () |
| virtual void | PassCellArraysOff () |
| virtual bool | GetPassCellArrays () |
| virtual void | SetPassPointArrays (bool) |
| | Shallow copy the input point data arrays to the output Off by default. More...
| virtual void | PassPointArraysOn () |
| virtual void | PassPointArraysOff () |
| virtual bool | GetPassPointArrays () |
| virtual void | SetPassFieldArrays (bool) |
| | Set whether to pass the field-data arrays from the Input i.e. More...
| virtual void | PassFieldArraysOn () |
| virtual void | PassFieldArraysOff () |
| virtual bool | GetPassFieldArrays () |
| virtual void | SetTolerance (double) |
| | Set the tolerance used to compute whether a point in the source is in a cell of the input. More...
| virtual double | GetTolerance () |
| virtual void | SetComputeTolerance (bool) |
| | Set whether to use the Tolerance field or precompute the tolerance. More...
| virtual void | ComputeToleranceOn () |
| virtual void | ComputeToleranceOff () |
| virtual bool | GetComputeTolerance () |
| virtual void | SetPassPartialArrays (bool) |
| | When dealing with composite datasets, partial arrays are common i.e. More...
| virtual bool | GetPassPartialArrays () |
| virtual void | PassPartialArraysOn () |
| virtual void | PassPartialArraysOff () |
| virtual int | GetSamplingPattern () |
| | Setter and getter for SamplingPattern (values to be taken from the enumeration vtkProbeLineFilter::SamplingPattern). More...
| virtual void | SetSamplingPattern (int) |
| virtual int | GetLineResolution () |
| | Setter and getter for LineResolution. More...
| virtual void | SetLineResolution (int) |
| virtual double * | GetPoint1 () |
| | Get/Set the begin and end points for the line to probe against. More...
| virtual void | GetPoint1 (double &, double &, double &) |
| virtual void | GetPoint1 (double [3]) |
| virtual void | SetPoint1 (double, double, double) |
| virtual void | SetPoint1 (double [3]) |
| virtual double * | GetPoint2 () |
| virtual void | GetPoint2 (double &, double &, double &) |
| virtual void | GetPoint2 (double [3]) |
| virtual void | SetPoint2 (double, double, double) |
| virtual void | SetPoint2 (double [3]) |
| vtkPolyDataAlgorithm * | NewInstance () const |
| vtkPolyData * | GetPolyDataInput (int port) |
| vtkPolyData * | GetOutput () |
| vtkPolyData * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVProbeLineFilter () |
| | ~vtkPVProbeLineFilter () override=default |
| int | FillInputPortInformation (int, vtkInformation *) override |
| | vtkPolyDataAlgorithm () |
| | ~vtkPolyDataAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
