Public Types | Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Protected Attributes | List of all members
vtkPVMetaSliceDataSet Class Reference
Meta class for slice filter that will allow the user to switch between a regular cutter filter or an extract cell by region filter. More...
#include <vtkPVMetaSliceDataSet.h>
Inheritance diagram for vtkPVMetaSliceDataSet:
Collaboration diagram for vtkPVMetaSliceDataSet:
typedef vtkPVDataSetAlgorithmSelectorFilter Superclass
- Public Types inherited from vtkPVDataSetAlgorithmSelectorFilter
enum  DesiredOutputPrecision
void PreserveInputCells (int keepCellAsIs)
 Enable or disable the Extract Cells By Regions. More...
vtkAlgorithm * SetActiveFilter (int index) override
 Override it so we can change the output type of the filter. More...
void SetImplicitFunction (vtkImplicitFunction *func)
void SetDataSetCutFunction (vtkImplicitFunction *func)
 Sets the cut function for vtkDataSet inputs. More...
void SetHyperTreeGridCutFunction (vtkImplicitFunction *func)
 Sets the cut function for vtkHyperTreeGrid inputs. More...
void SetCutFunction (vtkImplicitFunction *func)
 Expose method from vtkPVCutter. More...
void SetNumberOfContours (int nbContours)
void SetValue (int index, double value)
void SetGenerateTriangles (int status)
void SetDual (bool dual)
 Method used for vtkHyperTreeGrid. More...
int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
void SetLocator (vtkIncrementalPointLocator *locator)
 Set / get a spatial locator. More...
vtkIncrementalPointLocator * GetLocator ()
- Public Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
int RegisterFilter (vtkAlgorithm *filter)
 Register a new filter that can be used underneath in the requestData call. More...
void UnRegisterFilter (int index)
 UnRegister an existing filter that was previously registered. More...
void ClearFilters ()
 Remove all the registered filters. More...
int GetNumberOfFilters ()
 Return the current number of registered filters. More...
vtkAlgorithm * GetFilter (int index)
 Return the filter that lies at the given index of the filters registration queue. More...
vtkAlgorithm * GetActiveFilter ()
 Return the current active filter if any otherwise return nullptr. More...
vtkMTimeType GetMTime () override
 Override GetMTime because we delegate to other filters to do the real work. More...
int ProcessRequest (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) override
 Forward those methods to the underneath filters. More...
virtual int ProcessRequest (vtkInformation *request, vtkCollection *inInfo, vtkInformationVector *outInfo)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVMetaSliceDataSet * SafeDownCast (vtkObject *o)
static vtkPVMetaSliceDataSet * New ()
- Static Public Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
static vtkPVDataSetAlgorithmSelectorFilter * SafeDownCast (vtkObject *o)
static vtkPVDataSetAlgorithmSelectorFilter * New ()
static vtkAlgorithm * New ()
static const unsigned METASLICE_DATASET = 0
static const unsigned METASLICE_HYPERTREEGRID = 1
 vtkPVMetaSliceDataSet ()
 ~vtkPVMetaSliceDataSet () override
- Protected Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
 vtkPVDataSetAlgorithmSelectorFilter ()
 ~vtkPVDataSetAlgorithmSelectorFilter () override
virtual int GetOutputType ()
virtual void SetOutputType (int)
void InternalProgressCallback (vtkAlgorithm *algorithm)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkImplicitFunction * ImplicitFunctions [2]
- Protected Attributes inherited from vtkPVDataSetAlgorithmSelectorFilter
int OutputType
vtkCallbackCommand * InternalProgressObserver
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Static Protected Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
static void InternalProgressCallbackFunction (vtkObject *, unsigned long, void *clientdata, void *)
Definition at line 22 of file vtkPVMetaSliceDataSet.h.
Definition at line 26 of file vtkPVMetaSliceDataSet.h.
◆ vtkPVMetaSliceDataSet()
vtkPVMetaSliceDataSet::vtkPVMetaSliceDataSet ( )
◆ ~vtkPVMetaSliceDataSet()
vtkPVMetaSliceDataSet::~vtkPVMetaSliceDataSet ( )
virtual const char* vtkPVMetaSliceDataSet::GetClassName ( )
static int vtkPVMetaSliceDataSet::IsTypeOf ( const char *  type)
virtual int vtkPVMetaSliceDataSet::IsA ( const char *  type)
static vtkPVMetaSliceDataSet* vtkPVMetaSliceDataSet::SafeDownCast ( vtkObject *  o)
void vtkPVMetaSliceDataSet::PrintSelf ( ostream &  os,
static vtkPVMetaSliceDataSet* vtkPVMetaSliceDataSet::New ( )
◆ PreserveInputCells()
void vtkPVMetaSliceDataSet::PreserveInputCells ( int  keepCellAsIs)
◆ SetActiveFilter()
vtkAlgorithm* vtkPVMetaSliceDataSet::SetActiveFilter ( int  index)
Reimplemented from vtkPVDataSetAlgorithmSelectorFilter.
◆ SetImplicitFunction()
void vtkPVMetaSliceDataSet::SetImplicitFunction ( vtkImplicitFunction *  func)
◆ SetDataSetCutFunction()
void vtkPVMetaSliceDataSet::SetDataSetCutFunction ( vtkImplicitFunction *  func)
◆ SetHyperTreeGridCutFunction()
void vtkPVMetaSliceDataSet::SetHyperTreeGridCutFunction ( vtkImplicitFunction *  func)
◆ SetCutFunction()
void vtkPVMetaSliceDataSet::SetCutFunction ( vtkImplicitFunction *  func)
inline
Definition at line 61 of file vtkPVMetaSliceDataSet.h.
◆ SetNumberOfContours()
void vtkPVMetaSliceDataSet::SetNumberOfContours ( int  nbContours)
◆ SetValue()
void vtkPVMetaSliceDataSet::SetValue ( int  index,
double  value
◆ SetGenerateTriangles()
void vtkPVMetaSliceDataSet::SetGenerateTriangles ( int  status)
◆ SetDual()
void vtkPVMetaSliceDataSet::SetDual ( bool  dual)
◆ RequestDataObject()
int vtkPVMetaSliceDataSet::RequestDataObject ( vtkInformation *  ,
vtkInformationVector **  ,
◆ SetLocator()
void vtkPVMetaSliceDataSet::SetLocator ( vtkIncrementalPointLocator *  locator)
◆ GetLocator()
vtkIncrementalPointLocator* vtkPVMetaSliceDataSet::GetLocator ( )
◆ METASLICE_DATASET
const unsigned vtkPVMetaSliceDataSet::METASLICE_DATASET = 0
Definition at line 31 of file vtkPVMetaSliceDataSet.h.
◆ METASLICE_HYPERTREEGRID
const unsigned vtkPVMetaSliceDataSet::METASLICE_HYPERTREEGRID = 1
Definition at line 32 of file vtkPVMetaSliceDataSet.h.
◆ ImplicitFunctions
vtkImplicitFunction* vtkPVMetaSliceDataSet::ImplicitFunctions[2]
Definition at line 97 of file vtkPVMetaSliceDataSet.h.
