Public Types | Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Protected Attributes | List of all members
vtkPVMetaClipDataSet Class Reference
Meta class for clip filter that will allow the user to switch between a regular clip filter or an extract cell by region filter. More...
#include <vtkPVMetaClipDataSet.h>
Inheritance diagram for vtkPVMetaClipDataSet:
Collaboration diagram for vtkPVMetaClipDataSet:
typedef vtkPVDataSetAlgorithmSelectorFilter Superclass
- Public Types inherited from vtkPVDataSetAlgorithmSelectorFilter
enum  DesiredOutputPrecision
void PreserveInputCells (int keepCellAsIs)
 Enable or disable the Extract Cells By Regions. More...
void SetImplicitFunction (vtkImplicitFunction *func)
void SetInsideOut (int insideOut)
void SetClipFunction (vtkImplicitFunction *func)
 Expose method from vtkCutter. More...
void SetDataSetClipFunction (vtkImplicitFunction *func)
 Sets the clip function for vtkDataSet inputs. More...
void SetHyperTreeGridClipFunction (vtkImplicitFunction *func)
 Sets the clip function for vtkHyperTreeGrid inputs. More...
void SetValue (double value)
 Expose method from vtkClip. More...
void SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, const char *name) override
void SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, int fieldAttributeType) override
void SetInputArrayToProcess (int idx, vtkInformation *info) override
void SetInputArrayToProcess (int idx, int port, int connection, const char *fieldName, const char *fieldType) override
void SetUseValueAsOffset (int)
int ProcessRequest (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) override
 Add validation for active filter so that the vtkExtractGeometry won't be used without ImplicifFuntion being set. More...
int ProcessRequest (vtkInformation *request, vtkCollection *inInfo, vtkInformationVector *outInfo) override
 Forward those methods to the underneath filters. More...
int RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
virtual void SetExactBoxClip (bool)
 For clipping a box we will only get an approximate box from the vtkPVBox implicit function which can give undesired results. More...
virtual bool GetExactBoxClip ()
virtual void ExactBoxClipOn ()
virtual void ExactBoxClipOff ()
- Public Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
int RegisterFilter (vtkAlgorithm *filter)
 Register a new filter that can be used underneath in the requestData call. More...
void UnRegisterFilter (int index)
 UnRegister an existing filter that was previously registered. More...
void ClearFilters ()
 Remove all the registered filters. More...
int GetNumberOfFilters ()
 Return the current number of registered filters. More...
vtkAlgorithm * GetFilter (int index)
 Return the filter that lies at the given index of the filters registration queue. More...
vtkAlgorithm * GetActiveFilter ()
 Return the current active filter if any otherwise return nullptr. More...
virtual vtkAlgorithm * SetActiveFilter (int index)
 Set the active filter based on the given index of the filters registration queue. More...
vtkMTimeType GetMTime () override
 Override GetMTime because we delegate to other filters to do the real work. More...
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVMetaClipDataSet * SafeDownCast (vtkObject *o)
static vtkPVMetaClipDataSet * New ()
- Static Public Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
static vtkPVDataSetAlgorithmSelectorFilter * SafeDownCast (vtkObject *o)
static vtkPVDataSetAlgorithmSelectorFilter * New ()
static vtkAlgorithm * New ()
static const unsigned METACLIP_DATASET = 0
static const unsigned METACLIP_HYPERTREEGRID = 1
 vtkPVMetaClipDataSet ()
 ~vtkPVMetaClipDataSet () override
bool SwitchFilterForCrinkle ()
- Protected Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
 vtkPVDataSetAlgorithmSelectorFilter ()
 ~vtkPVDataSetAlgorithmSelectorFilter () override
virtual int GetOutputType ()
virtual void SetOutputType (int)
void InternalProgressCallback (vtkAlgorithm *algorithm)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkImplicitFunction * ImplicitFunctions [2]
- Protected Attributes inherited from vtkPVDataSetAlgorithmSelectorFilter
int OutputType
vtkCallbackCommand * InternalProgressObserver
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Static Protected Member Functions inherited from vtkPVDataSetAlgorithmSelectorFilter
static void InternalProgressCallbackFunction (vtkObject *, unsigned long, void *clientdata, void *)
Definition at line 18 of file vtkPVMetaClipDataSet.h.
Definition at line 22 of file vtkPVMetaClipDataSet.h.
◆ vtkPVMetaClipDataSet()
vtkPVMetaClipDataSet::vtkPVMetaClipDataSet ( )
◆ ~vtkPVMetaClipDataSet()
vtkPVMetaClipDataSet::~vtkPVMetaClipDataSet ( )
virtual const char* vtkPVMetaClipDataSet::GetClassName ( )
static int vtkPVMetaClipDataSet::IsTypeOf ( const char *  type)
virtual int vtkPVMetaClipDataSet::IsA ( const char *  type)
static vtkPVMetaClipDataSet* vtkPVMetaClipDataSet::SafeDownCast ( vtkObject *  o)
void vtkPVMetaClipDataSet::PrintSelf ( ostream &  os,
static vtkPVMetaClipDataSet* vtkPVMetaClipDataSet::New ( )
◆ PreserveInputCells()
void vtkPVMetaClipDataSet::PreserveInputCells ( int  keepCellAsIs)
◆ SetImplicitFunction()
void vtkPVMetaClipDataSet::SetImplicitFunction ( vtkImplicitFunction *  func)
◆ SetInsideOut()
void vtkPVMetaClipDataSet::SetInsideOut ( int  insideOut)
◆ SetClipFunction()
void vtkPVMetaClipDataSet::SetClipFunction ( vtkImplicitFunction *  func)
inline
Definition at line 44 of file vtkPVMetaClipDataSet.h.
◆ SetDataSetClipFunction()
void vtkPVMetaClipDataSet::SetDataSetClipFunction ( vtkImplicitFunction *  func)
◆ SetHyperTreeGridClipFunction()
void vtkPVMetaClipDataSet::SetHyperTreeGridClipFunction ( vtkImplicitFunction *  func)
◆ SetValue()
void vtkPVMetaClipDataSet::SetValue ( double  value)
◆ SetInputArrayToProcess() [1/4]
void vtkPVMetaClipDataSet::SetInputArrayToProcess ( int  idx,
int  port,
int  connection,
const char *  name
◆ SetInputArrayToProcess() [2/4]
int  port,
int  connection,
◆ SetInputArrayToProcess() [3/4]
vtkInformation *  info
◆ SetInputArrayToProcess() [4/4]
int  port,
int  connection,
const char *  fieldName,
const char *  fieldType
◆ SetExactBoxClip()
virtual void vtkPVMetaClipDataSet::SetExactBoxClip ( bool  )
In order to get the exact box geometry output we need to perform 6 plane clips which is very expensive. The default is to not use the exact option. Additionally, the exact box clip must have inside out enabled.
◆ GetExactBoxClip()
virtual bool vtkPVMetaClipDataSet::GetExactBoxClip ( )
◆ ExactBoxClipOn()
virtual void vtkPVMetaClipDataSet::ExactBoxClipOn ( )
◆ ExactBoxClipOff()
virtual void vtkPVMetaClipDataSet::ExactBoxClipOff ( )
◆ SetUseValueAsOffset()
void vtkPVMetaClipDataSet::SetUseValueAsOffset ( int  )
◆ ProcessRequest() [1/2]
int vtkPVMetaClipDataSet::ProcessRequest ( vtkInformation *  request,
vtkInformationVector **  inInfo,
vtkInformationVector *  outInfo
Reimplemented from vtkPVDataSetAlgorithmSelectorFilter.
◆ ProcessRequest() [2/2]
vtkCollection *  inInfo,
◆ RequestDataObject()
int vtkPVMetaClipDataSet::RequestDataObject ( vtkInformation *  request,
◆ SwitchFilterForCrinkle()
bool vtkPVMetaClipDataSet::SwitchFilterForCrinkle ( )
◆ METACLIP_DATASET
const unsigned vtkPVMetaClipDataSet::METACLIP_DATASET = 0
Definition at line 27 of file vtkPVMetaClipDataSet.h.
◆ METACLIP_HYPERTREEGRID
const unsigned vtkPVMetaClipDataSet::METACLIP_HYPERTREEGRID = 1
Definition at line 28 of file vtkPVMetaClipDataSet.h.
◆ ImplicitFunctions
vtkImplicitFunction* vtkPVMetaClipDataSet::ImplicitFunctions[2]
Definition at line 110 of file vtkPVMetaClipDataSet.h.
