Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
vtkPGenericIOReader Class Reference
Creates a vtkUnstructuredGrid instance from a GenericIO file. More...
#include <vtkPGenericIOReader.h>
Inheritance diagram for vtkPGenericIOReader:
Collaboration diagram for vtkPGenericIOReader:
enum  IOType { IOTYPEMPI, IOTYPEPOSIX }
enum  BlockAssignment { ROUND_ROBIN, RCB }
typedef vtkUnstructuredGridAlgorithm Superclass
- Public Types inherited from vtkUnstructuredGridAlgorithm
enum  DesiredOutputPrecision
int GetNumberOfPointArrays ()
 Returns the number of arrays in the file, i.e., the number of columns. More...
const char * GetPointArrayName (int i)
 Returns the name of the ith array. More...
int GetPointArrayStatus (const char *name)
 Returns the status of the array corresponding to the given name. More...
void SetPointArrayStatus (const char *name, int status)
 Sets the status of the array named. More...
vtkIdType GetRequestedHaloId (vtkIdType i)
 Gets the ith requested halo id. More...
vtkIdType GetNumberOfRequestedHaloIds ()
 Gets the number of requested halo ids. More...
void SetNumberOfRequestedHaloIds (vtkIdType numIds)
 Sets the number of requested halo ids. More...
void AddRequestedHaloId (vtkIdType haloId)
 Adds the given halo id to the list of halo ids to request. More...
void ClearRequestedHaloIds ()
 Clears the list of requested halo ids. More...
void SetRequestedHaloId (vtkIdType i, vtkIdType haloId)
 Sets the ith requested halo id to the given haloId. More...
 Specify the name of the cosmology particle binary file to read. More...
virtual char * GetFileName ()
virtual void SetXAxisVariableName (const char *)
 Set/Get the variable name to be used as the x-axis for plotting particles. More...
virtual char * GetXAxisVariableName ()
virtual void SetYAxisVariableName (const char *)
virtual char * GetYAxisVariableName ()
virtual void SetZAxisVariableName (const char *)
virtual char * GetZAxisVariableName ()
virtual void SetGenericIOType (int)
 Set/Get the underlying IO method the reader will employ, i.e., MPI or POSIX. More...
virtual int GetGenericIOType ()
virtual void SetBlockAssignment (int)
 Set/Get the underlying block-assignment strategy to use, i.e., ROUND_ROBIN, or RCB. More...
virtual int GetBlockAssignment ()
virtual void SetRankInQuery (int)
 Set/Get the RankInQuery. More...
virtual int GetRankInQuery ()
virtual void SetQueryRankNeighbors (int)
 Set/Get whether the reader should read/render only the data of the user-supplied rank, via SetRankInQuery(),. More...
virtual int GetQueryRankNeighbors ()
virtual void SetAppendBlockCoordinates (bool)
 Set/Get whether the reader should append the coordinates of the block each point was read from as a point data array. More...
virtual void AppendBlockCoordinatesOn ()
virtual void AppendBlockCoordinatesOff ()
virtual bool GetAppendBlockCoordinates ()
virtual vtkStringArray * GetArrayList ()
 Returns the list of arrays used to select the variables to be used for the x,y and z axis. More...
virtual vtkDataArraySelection * GetPointDataArraySelection ()
 Get the data array selection tables used to configure which data arrays are loaded by the reader. More...
virtual void SetController (vtkMultiProcessController *)
 Set/Get a multiprocess-controller for reading in parallel. More...
virtual void SetHaloIdVariableName (const char *)
 Gets/Sets the variable name for the halo id of the particle. More...
virtual char * GetHaloIdVariableName ()
- Public Member Functions inherited from vtkUnstructuredGridAlgorithm
vtkUnstructuredGridAlgorithm * NewInstance () const
vtkDataObject * GetInput ()
vtkUnstructuredGrid * GetUnstructuredGridInput (int port)
vtkUnstructuredGrid * GetOutput ()
vtkUnstructuredGrid * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPGenericIOReader * New ()
static vtkPGenericIOReader * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkUnstructuredGridAlgorithm
static vtkUnstructuredGridAlgorithm * New ()
static vtkUnstructuredGridAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPGenericIOReader ()
virtual ~vtkPGenericIOReader ()
int RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
void LoadMetaData ()
 Loads the GenericIO metadata from the file. More...
bool ReaderParametersChanged ()
 This method checks if the internal reader parameters have changed. More...
gio::GenericIOReader * GetInternalReader ()
 Returns the internal reader instance according to IOType. More...
void GetPointFromRawData (int xType, void *xBuffer, int yType, void *yBuffer, int zType, void *zBuffer, vtkIdType idx, double pnt[3])
 Return the point from the raw data. More...
void LoadRawVariableData (std::string varName)
 Loads the variable with the given name. More...
void LoadRawData ()
 Loads the Raw data. More...
void LoadCoordinates (vtkUnstructuredGrid *grid, std::set< vtkIdType > &pointsInSelectedHalos)
 Loads the particle coordinates. More...
void LoadData (vtkUnstructuredGrid *grid, const std::set< vtkIdType > &pointsInSelectedHalos)
 Loads the particle data arrays. More...
void FindRankNeighbors ()
 Finds the neighbors of the user-supplied rank. More...
- Protected Member Functions inherited from vtkUnstructuredGridAlgorithm
 vtkUnstructuredGridAlgorithm ()
 ~vtkUnstructuredGridAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
static void SelectionModifiedCallback (vtkObject *caller, unsigned long eid, void *clientdata, void *calldata)
 Call-back registered with the SelectionObserver. More...
char * XAxisVariableName
char * YAxisVariableName
char * ZAxisVariableName
char * HaloIdVariableName
char * FileName
int GenericIOType
int BlockAssignment
int QueryRankNeighbors
int RankInQuery
bool BuildMetaData
bool AppendBlockCoordinates
vtkStringArray * ArrayList
vtkIdList * HaloList
vtkDataArraySelection * PointDataArraySelection
vtkCallbackCommand * SelectionObserver
gio::GenericIOReader * Reader
vtkGenericIOMetaData * MetaData
int RequestInfoCounter
int RequestDataCounter
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Definition at line 38 of file vtkPGenericIOReader.h.
Definition at line 54 of file vtkPGenericIOReader.h.
◆ IOType
Enumerator
IOTYPEMPI
IOTYPEPOSIX
Definition at line 41 of file vtkPGenericIOReader.h.
◆ BlockAssignment
Enumerator
ROUND_ROBIN
RCB
Definition at line 47 of file vtkPGenericIOReader.h.
◆ vtkPGenericIOReader()
vtkPGenericIOReader::vtkPGenericIOReader ( )
◆ ~vtkPGenericIOReader()
virtual vtkPGenericIOReader::~vtkPGenericIOReader ( )
protectedvirtual
static vtkPGenericIOReader* vtkPGenericIOReader::New ( )
virtual const char* vtkPGenericIOReader::GetClassName ( )
static int vtkPGenericIOReader::IsTypeOf ( const char *  type)
virtual int vtkPGenericIOReader::IsA ( const char *  type)
Reimplemented from vtkUnstructuredGridAlgorithm.
static vtkPGenericIOReader* vtkPGenericIOReader::SafeDownCast ( vtkObject *  o)
void vtkPGenericIOReader::PrintSelf ( ostream &  os,
◆ SetFileName()
virtual void vtkPGenericIOReader::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkPGenericIOReader::GetFileName ( )
◆ SetXAxisVariableName()
virtual void vtkPGenericIOReader::SetXAxisVariableName ( const char *  )
◆ GetXAxisVariableName()
virtual char* vtkPGenericIOReader::GetXAxisVariableName ( )
◆ SetYAxisVariableName()
virtual void vtkPGenericIOReader::SetYAxisVariableName ( const char *  )
◆ GetYAxisVariableName()
virtual char* vtkPGenericIOReader::GetYAxisVariableName ( )
◆ SetZAxisVariableName()
virtual void vtkPGenericIOReader::SetZAxisVariableName ( const char *  )
◆ GetZAxisVariableName()
virtual char* vtkPGenericIOReader::GetZAxisVariableName ( )
◆ SetGenericIOType()
virtual void vtkPGenericIOReader::SetGenericIOType ( int  )
◆ GetGenericIOType()
virtual int vtkPGenericIOReader::GetGenericIOType ( )
◆ SetBlockAssignment()
virtual void vtkPGenericIOReader::SetBlockAssignment ( int  )
◆ GetBlockAssignment()
virtual int vtkPGenericIOReader::GetBlockAssignment ( )
◆ SetRankInQuery()
virtual void vtkPGenericIOReader::SetRankInQuery ( int  )
Used in combination with SetQueryRankNeighbors(1) tells the reader to render only the data of the RankInQuery and its neighbors.
◆ GetRankInQuery()
virtual int vtkPGenericIOReader::GetRankInQuery ( )
◆ SetQueryRankNeighbors()
virtual void vtkPGenericIOReader::SetQueryRankNeighbors ( int  )
◆ GetQueryRankNeighbors()
virtual int vtkPGenericIOReader::GetQueryRankNeighbors ( )
◆ SetAppendBlockCoordinates()
virtual void vtkPGenericIOReader::SetAppendBlockCoordinates ( bool  )
Defaults to false (Off).
◆ AppendBlockCoordinatesOn()
virtual void vtkPGenericIOReader::AppendBlockCoordinatesOn ( )
◆ AppendBlockCoordinatesOff()
virtual void vtkPGenericIOReader::AppendBlockCoordinatesOff ( )
◆ GetAppendBlockCoordinates()
virtual bool vtkPGenericIOReader::GetAppendBlockCoordinates ( )
◆ GetArrayList()
virtual vtkStringArray* vtkPGenericIOReader::GetArrayList ( )
◆ GetPointDataArraySelection()
virtual vtkDataArraySelection* vtkPGenericIOReader::GetPointDataArraySelection ( )
◆ SetController()
virtual void vtkPGenericIOReader::SetController ( vtkMultiProcessController *  )
By default this parameter is set to nullptr by the constructor.
◆ GetController()
virtual vtkMultiProcessController* vtkPGenericIOReader::GetController ( )
◆ GetNumberOfPointArrays()
int vtkPGenericIOReader::GetNumberOfPointArrays ( )
◆ GetPointArrayName()
const char* vtkPGenericIOReader::GetPointArrayName ( int  i)
◆ GetPointArrayStatus()
int vtkPGenericIOReader::GetPointArrayStatus ( const char *  name)
◆ SetPointArrayStatus()
void vtkPGenericIOReader::SetPointArrayStatus ( const char *  name,
int  status
If the status is 1, the array will be read in on the resulting dataset.
◆ SetHaloIdVariableName()
virtual void vtkPGenericIOReader::SetHaloIdVariableName ( const char *  )
This is used by the requested halo selector to select only the points in the desired halos.
◆ GetHaloIdVariableName()
virtual char* vtkPGenericIOReader::GetHaloIdVariableName ( )
◆ GetRequestedHaloId()
vtkIdType vtkPGenericIOReader::GetRequestedHaloId ( vtkIdType  i)
If the number of requested halo ids is greater than 0, only points with those halo ids will be read in. Otherwise all points will be read in.
◆ GetNumberOfRequestedHaloIds()
vtkIdType vtkPGenericIOReader::GetNumberOfRequestedHaloIds ( )
◆ SetNumberOfRequestedHaloIds()
void vtkPGenericIOReader::SetNumberOfRequestedHaloIds ( vtkIdType  numIds)
Use SetRequestedHaloId() to se the ids after this is called If the number of requested halo ids is greater than 0, only points with those halo ids will be read in. Otherwise all points will be read in.
◆ AddRequestedHaloId()
void vtkPGenericIOReader::AddRequestedHaloId ( vtkIdType  haloId)
◆ ClearRequestedHaloIds()
void vtkPGenericIOReader::ClearRequestedHaloIds ( )
◆ SetRequestedHaloId()
void vtkPGenericIOReader::SetRequestedHaloId ( vtkIdType  i,
vtkIdType  haloId
◆ RequestInformation()
int vtkPGenericIOReader::RequestInformation ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ RequestData()
int vtkPGenericIOReader::RequestData ( vtkInformation *  ,
◆ LoadMetaData()
void vtkPGenericIOReader::LoadMetaData ( )
◆ ReaderParametersChanged()
bool vtkPGenericIOReader::ReaderParametersChanged ( )
Namely, if the I/O method or filename have changed, the method returns true.
◆ GetInternalReader()
gio::GenericIOReader* vtkPGenericIOReader::GetInternalReader ( )
◆ GetPointFromRawData()
void vtkPGenericIOReader::GetPointFromRawData ( int  xType,
void *  xBuffer,
int  yType,
void *  yBuffer,
int  zType,
void *  zBuffer,
vtkIdType  idx,
double  pnt[3]
◆ LoadRawVariableData()
void vtkPGenericIOReader::LoadRawVariableData ( std::string  varName)
◆ LoadRawData()
void vtkPGenericIOReader::LoadRawData ( )
Loads the Raw data.
◆ LoadCoordinates()
void vtkPGenericIOReader::LoadCoordinates ( vtkUnstructuredGrid *  grid,
std::set< vtkIdType > &  pointsInSelectedHalos
◆ LoadData()
void vtkPGenericIOReader::LoadData ( vtkUnstructuredGrid *  grid,
const std::set< vtkIdType > &  pointsInSelectedHalos
◆ FindRankNeighbors()
void vtkPGenericIOReader::FindRankNeighbors ( )
◆ SelectionModifiedCallback()
static void vtkPGenericIOReader::SelectionModifiedCallback ( vtkObject *  caller,
unsigned long  eid,
void *  clientdata,
void *  calldata
staticprotected
◆ XAxisVariableName
char* vtkPGenericIOReader::XAxisVariableName
Definition at line 302 of file vtkPGenericIOReader.h.
◆ YAxisVariableName
char* vtkPGenericIOReader::YAxisVariableName
Definition at line 303 of file vtkPGenericIOReader.h.
◆ ZAxisVariableName
char* vtkPGenericIOReader::ZAxisVariableName
Definition at line 304 of file vtkPGenericIOReader.h.
◆ HaloIdVariableName
char* vtkPGenericIOReader::HaloIdVariableName
Definition at line 305 of file vtkPGenericIOReader.h.
◆ FileName
char* vtkPGenericIOReader::FileName
Definition at line 307 of file vtkPGenericIOReader.h.
◆ GenericIOType
int vtkPGenericIOReader::GenericIOType
Definition at line 308 of file vtkPGenericIOReader.h.
◆ BlockAssignment
Definition at line 309 of file vtkPGenericIOReader.h.
◆ QueryRankNeighbors
int vtkPGenericIOReader::QueryRankNeighbors
Definition at line 311 of file vtkPGenericIOReader.h.
◆ RankInQuery
int vtkPGenericIOReader::RankInQuery
Definition at line 312 of file vtkPGenericIOReader.h.
◆ BuildMetaData
bool vtkPGenericIOReader::BuildMetaData
Definition at line 314 of file vtkPGenericIOReader.h.
bool vtkPGenericIOReader::AppendBlockCoordinates
Definition at line 315 of file vtkPGenericIOReader.h.
◆ Controller
vtkMultiProcessController* vtkPGenericIOReader::Controller
Definition at line 317 of file vtkPGenericIOReader.h.
◆ ArrayList
vtkStringArray* vtkPGenericIOReader::ArrayList
Definition at line 319 of file vtkPGenericIOReader.h.
◆ HaloList
vtkIdList* vtkPGenericIOReader::HaloList
Definition at line 320 of file vtkPGenericIOReader.h.
◆ PointDataArraySelection
vtkDataArraySelection* vtkPGenericIOReader::PointDataArraySelection
Definition at line 321 of file vtkPGenericIOReader.h.
◆ SelectionObserver
vtkCallbackCommand* vtkPGenericIOReader::SelectionObserver
Definition at line 322 of file vtkPGenericIOReader.h.
◆ Reader
gio::GenericIOReader* vtkPGenericIOReader::Reader
Definition at line 324 of file vtkPGenericIOReader.h.
◆ MetaData
vtkGenericIOMetaData* vtkPGenericIOReader::MetaData
Definition at line 325 of file vtkPGenericIOReader.h.
◆ RequestInfoCounter
int vtkPGenericIOReader::RequestInfoCounter
Definition at line 327 of file vtkPGenericIOReader.h.
◆ RequestDataCounter
int vtkPGenericIOReader::RequestDataCounter
Definition at line 328 of file vtkPGenericIOReader.h.
