vtkPANLSubhaloFinder Class Reference
This filter takes the output of the HACC halo finder and runs the subhalo finder on a user-specified list of halos. More...
#include <vtkPANLSubhaloFinder.h>
Inheritance diagram for vtkPANLSubhaloFinder:
Collaboration diagram for vtkPANLSubhaloFinder:
enum  { ALL_HALOS = 0, HALOS_LARGER_THAN_THRESHOLD = 1, ONLY_SELECTED_HALOS = 2 }
enum  DesiredOutputPrecision
void PrintSelf (ostream &os, vtkIndent indent)
vtkIdType GetHaloToProcess (vtkIdType idx)
 Gets the halo to process at the given index This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
void AddHaloToProcess (vtkIdType haloId)
 Adds a halo to the list of halos that will have the subhalo finder run on them This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
void SetHaloToProcess (vtkIdType idx, vtkIdType haloId)
 Sets the halo id to process at the given index in the list This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
void SetNumberOfHalosToProcess (vtkIdType num)
 Sets the number of halos to process This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
vtkIdType GetNumberOfHalosToProcess ()
 Gets the number of halos to process This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
void ClearHalosToProcess ()
 Clears the list of halos that will have the subhalo finder run on them This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
virtual void SetMode (int)
 Sets/Gets the mode of the subhalo finding filter. More...
virtual int GetMode ()
virtual void SetSizeThreshold (vtkIdType)
 Sets/Gets the size threshold which is the minimum number of particles in the halos that will have the subhalo finder run on them in HALOS_LARGER_THAN_THRESHOLD mode. More...
virtual vtkIdType GetSizeThreshold ()
virtual void SetRL (double)
 Gets/Sets RL, the physical coordinate box size Default: 256.0. More...
virtual double GetRL ()
virtual void SetDeadSize (double)
 Gets/Sets the size of the ghost particle region around each process's particles to exchange when creating ghost particles. More...
virtual double GetDeadSize ()
virtual void SetParticleMass (float)
 Gets/Sets the particle mass. More...
virtual float GetParticleMass ()
virtual void SetBB (double)
 Gets/Sets distance threshold for particles to be considered in the same halo. More...
virtual double GetBB ()
virtual void SetAlphaFactor (double)
 Gets/Sets alpha factor. More...
virtual double GetAlphaFactor ()
virtual void SetBetaFactor (double)
 Gets/Sets beta factor. More...
virtual double GetBetaFactor ()
virtual void SetMinCandidateSize (int)
 Gets/Sets the minimum size of a subhalo candidate Default: 200. More...
virtual int GetMinCandidateSize ()
virtual void SetNumSPHNeighbors (int)
 Gets/Sets NumSPHNeighbors Default: 64. More...
virtual int GetNumSPHNeighbors ()
virtual void SetNumNeighbors (int)
 Gets/Sets the number of neighbors that are examined by the subhalo finder to determine local clumps near the each particle Default: 20. More...
virtual int GetNumNeighbors ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPANLSubhaloFinder * New ()
static vtkAlgorithm * New ()
 vtkPANLSubhaloFinder ()
virtual ~vtkPANLSubhaloFinder ()
int FillInputPortInformation (int port, vtkInformation *info)
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
virtual int RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
double RL
double DeadSize
double BB
double ParticleMass
double AlphaFactor
double BetaFactor
int MinCandidateSize
int NumSPHNeighbors
int NumNeighbors
int Mode
vtkIdType SizeThreshold
vtkNew< vtkIdList > HalosToProcess
vtkInternals * Internal
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
The input should be a vtkUnstructuredGrid with the data arrays vx, vy, vz, id and fof_halo_tag. AddHaloToProcess should be used to select which halos to find subhalos of.
The first output is a vtkUnstructuredGrid similar to the input but with the data array subhalo_tag appended to indicate which subhalo a point lies in. The value will be -1 for points in no halo.
The second output is a vtkUnstructuredGrid with one point per subhalo and data arrays for summary information such as average velocity, mass, and center of mass.
Definition at line 34 of file vtkPANLSubhaloFinder.h.
◆ anonymous enum
anonymous enum
Enumerator
ALL_HALOS
ONLY_SELECTED_HALOS
Definition at line 42 of file vtkPANLSubhaloFinder.h.
◆ vtkPANLSubhaloFinder()
vtkPANLSubhaloFinder::vtkPANLSubhaloFinder ( )
◆ ~vtkPANLSubhaloFinder()
virtual vtkPANLSubhaloFinder::~vtkPANLSubhaloFinder ( )
protectedvirtual
static vtkPANLSubhaloFinder* vtkPANLSubhaloFinder::New ( )
void vtkPANLSubhaloFinder::PrintSelf ( ostream &  os,
◆ SetMode()
virtual void vtkPANLSubhaloFinder::SetMode ( int  )
It should be one of the values ALL_HALOS - find subhalos of all halos (default) HALOS_LARGER_THAN_THRESHOLD - finds subhalos of all halos with more than SizeThreshold values (sizeThreshold is a settable parameter) ONLY_SELECTED_HALOS - finds subhalos of only the halos in the HalosToProcess list
◆ GetMode()
virtual int vtkPANLSubhaloFinder::GetMode ( )
◆ SetSizeThreshold()
virtual void vtkPANLSubhaloFinder::SetSizeThreshold ( vtkIdType  )
Defaults to 1000.
◆ GetSizeThreshold()
virtual vtkIdType vtkPANLSubhaloFinder::GetSizeThreshold ( )
Defaults to 1000.
◆ GetHaloToProcess()
vtkIdType vtkPANLSubhaloFinder::GetHaloToProcess ( vtkIdType  idx)
◆ AddHaloToProcess()
void vtkPANLSubhaloFinder::AddHaloToProcess ( vtkIdType  haloId)
◆ SetHaloToProcess()
void vtkPANLSubhaloFinder::SetHaloToProcess ( vtkIdType  idx,
vtkIdType  haloId
◆ SetNumberOfHalosToProcess()
void vtkPANLSubhaloFinder::SetNumberOfHalosToProcess ( vtkIdType  num)
◆ GetNumberOfHalosToProcess()
vtkIdType vtkPANLSubhaloFinder::GetNumberOfHalosToProcess ( )
◆ ClearHalosToProcess()
void vtkPANLSubhaloFinder::ClearHalosToProcess ( )
◆ SetRL()
virtual void vtkPANLSubhaloFinder::SetRL ( double  )
◆ GetRL()
virtual double vtkPANLSubhaloFinder::GetRL ( )
◆ SetDeadSize()
virtual void vtkPANLSubhaloFinder::SetDeadSize ( double  )
Default: 8.0
◆ GetDeadSize()
virtual double vtkPANLSubhaloFinder::GetDeadSize ( )
Default: 8.0
◆ SetParticleMass()
virtual void vtkPANLSubhaloFinder::SetParticleMass ( float  )
For input datasets that do not have mass information the mass of each particle defaults to this value. Default: 1.307087181e+09
◆ GetParticleMass()
virtual float vtkPANLSubhaloFinder::GetParticleMass ( )
◆ SetBB()
virtual void vtkPANLSubhaloFinder::SetBB ( double  )
This is measured in grid units on a NP x NP x NP grid. Default: 0.1679999998
◆ GetBB()
virtual double vtkPANLSubhaloFinder::GetBB ( )
◆ SetAlphaFactor()
virtual void vtkPANLSubhaloFinder::SetAlphaFactor ( double  )
This controls how aggressively small subhalos are grown. Alpha factor of 1.0 is the least aggressive Default: 1.0
◆ GetAlphaFactor()
virtual double vtkPANLSubhaloFinder::GetAlphaFactor ( )
◆ SetBetaFactor()
virtual void vtkPANLSubhaloFinder::SetBetaFactor ( double  )
This controls how saddle points between subhalos are treated. Larger values allow identification of smaller scale structures such as tails. Default: 0.0
◆ GetBetaFactor()
virtual double vtkPANLSubhaloFinder::GetBetaFactor ( )
◆ SetMinCandidateSize()
virtual void vtkPANLSubhaloFinder::SetMinCandidateSize ( int  )
◆ GetMinCandidateSize()
virtual int vtkPANLSubhaloFinder::GetMinCandidateSize ( )
◆ SetNumSPHNeighbors()
virtual void vtkPANLSubhaloFinder::SetNumSPHNeighbors ( int  )
◆ GetNumSPHNeighbors()
virtual int vtkPANLSubhaloFinder::GetNumSPHNeighbors ( )
◆ SetNumNeighbors()
virtual void vtkPANLSubhaloFinder::SetNumNeighbors ( int  )
◆ GetNumNeighbors()
virtual int vtkPANLSubhaloFinder::GetNumNeighbors ( )
◆ FillInputPortInformation()
int vtkPANLSubhaloFinder::FillInputPortInformation ( int  port,
vtkInformation *  info
protectedvirtual
◆ RequestInformation()
virtual int vtkPANLSubhaloFinder::RequestInformation ( vtkInformation *  ,
vtkInformationVector **  ,
protectedvirtual
◆ RequestData()
virtual int vtkPANLSubhaloFinder::RequestData ( vtkInformation *  ,
protectedvirtual
◆ RL
double vtkPANLSubhaloFinder::RL
Definition at line 199 of file vtkPANLSubhaloFinder.h.
◆ DeadSize
double vtkPANLSubhaloFinder::DeadSize
Definition at line 200 of file vtkPANLSubhaloFinder.h.
◆ BB
double vtkPANLSubhaloFinder::BB
Definition at line 201 of file vtkPANLSubhaloFinder.h.
◆ ParticleMass
double vtkPANLSubhaloFinder::ParticleMass
Definition at line 202 of file vtkPANLSubhaloFinder.h.
◆ AlphaFactor
double vtkPANLSubhaloFinder::AlphaFactor
Definition at line 203 of file vtkPANLSubhaloFinder.h.
◆ BetaFactor
double vtkPANLSubhaloFinder::BetaFactor
Definition at line 204 of file vtkPANLSubhaloFinder.h.
◆ MinCandidateSize
int vtkPANLSubhaloFinder::MinCandidateSize
Definition at line 205 of file vtkPANLSubhaloFinder.h.
◆ NumSPHNeighbors
int vtkPANLSubhaloFinder::NumSPHNeighbors
Definition at line 206 of file vtkPANLSubhaloFinder.h.
◆ NumNeighbors
int vtkPANLSubhaloFinder::NumNeighbors
Definition at line 207 of file vtkPANLSubhaloFinder.h.
◆ Mode
int vtkPANLSubhaloFinder::Mode
Definition at line 209 of file vtkPANLSubhaloFinder.h.
◆ SizeThreshold
vtkIdType vtkPANLSubhaloFinder::SizeThreshold
Definition at line 210 of file vtkPANLSubhaloFinder.h.
◆ HalosToProcess
vtkNew<vtkIdList> vtkPANLSubhaloFinder::HalosToProcess
Definition at line 212 of file vtkPANLSubhaloFinder.h.
◆ Controller
vtkMultiProcessController* vtkPANLSubhaloFinder::Controller
Definition at line 213 of file vtkPANLSubhaloFinder.h.
◆ Internal
vtkInternals* vtkPANLSubhaloFinder::Internal
Definition at line 215 of file vtkPANLSubhaloFinder.h.
