Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | List of all members
vtkInitializationHelper Class Reference
help class for python modules More...
#include <vtkInitializationHelper.h>
Inheritance diagram for vtkInitializationHelper:
Collaboration diagram for vtkInitializationHelper:
static vtkInitializationHelper * SafeDownCast (vtkObject *o)
static bool Initialize (int argc, char **argv, int processType, vtkCLIOptions *options=nullptr, bool enableStandardArgs=true)
 Initializes ParaView engine. More...
static bool Initialize (vtkStringList *argv, int processType)
 Overload primary intended for Python wrapping. More...
static bool Initialize (const char *executable, int type)
 An overload that does not take argc/argv for convenience. More...
static bool InitializeProcessModule (int argc, char **argv, int type)
 Initialize the vtkProcessModule used in ParaView. More...
static bool InitializeGlobalOptions (int argc, char **argv, int processType, vtkCLIOptions *options=nullptr, bool enableStandardArgs=true)
 Initialize only the global options (see vtkCLIOptions) of ParaView engine but do not check for options that cause early exit of the program. More...
static bool InitializeOtherOptions (int argc, char **argv, int processType, vtkCLIOptions *options=nullptr, bool enableStandardArgs=true)
 Initialize all options of ParaView engine but the global options, then check for options that cause early exit of the program. More...
static bool InitializeOptions (int argc, char **argv, int processType, vtkCLIOptions *options=nullptr, bool enableStandardArgs=true)
 Initialize the process module and options of ParaView engine. More...
static bool InitializeSettings (int type, bool defaultCoreConfig)
 Initialize the setting by reading the settings file, unless coreConfig DisableRegistry is set to true. More...
static bool InitializeOthers ()
 Initialize everything that is not initialized by specific methods, see Initialize method for more info. More...
static bool InitializeMiscellaneous (int type)
 Initialize everything that needs to be initialized in the paraview engine after the options. More...
static void InitializePythonVirtualEnvironment ()
 Initialize Python virtual environment from –venv command-line argument if any was provided. More...
static void Finalize ()
 Finalizes the server manager. More...
static int GetExitCode ()
 Returns the exit code after Initialize. More...
static std::string GetUserSettingsDirectory ()
 Get directory for user settings file. More...
static std::string GetUserSettingsFilePath ()
 Get file path for the user settings file. More...
static void StandaloneInitialize ()
 Initialization for standalone executables linking against a PV library. More...
static void StandaloneFinalize ()
static void SetLoadSettingsFilesDuringInitialization (bool)
 During initialization, vtkInitializationHelper reads "settings" files for configuring vtkSMSettings. More...
static bool GetLoadSettingsFilesDuringInitialization ()
static void SetOrganizationName (const std::string &organizationName)
 Sets the organization producing this application. More...
static const std::string & GetOrganizationName ()
static void SetApplicationName (const std::string &appName)
 Sets the name of the application. More...
static const std::string & GetApplicationName ()
 vtkInitializationHelper ()=default
 ~vtkInitializationHelper () override=default
static void LoadSettings ()
 Load user and site settings. More...
This class is used by the python modules when they are loaded from python (as opposed to pvpython). It simply initializes the server manager so that it can be used.
Definition at line 28 of file vtkInitializationHelper.h.
Definition at line 31 of file vtkInitializationHelper.h.
◆ vtkInitializationHelper()
vtkInitializationHelper::vtkInitializationHelper ( )
protecteddefault
◆ ~vtkInitializationHelper()
vtkInitializationHelper::~vtkInitializationHelper ( )
overrideprotecteddefault
virtual const char* vtkInitializationHelper::GetClassName ( )
static int vtkInitializationHelper::IsTypeOf ( const char *  type)
virtual int vtkInitializationHelper::IsA ( const char *  type)
static vtkInitializationHelper* vtkInitializationHelper::SafeDownCast ( vtkObject *  o)
void vtkInitializationHelper::PrintSelf ( ostream &  os,
◆ Initialize() [1/3]
static bool vtkInitializationHelper::Initialize ( int  argc,
char **  argv,
int  processType,
vtkCLIOptions *  options = nullptr,
bool  enableStandardArgs = true
Returns true on success, false otherwise. When false, use GetExitCode to obtain the exit code. Note, for requests like --help, --version etc, this method returns false with exit-code set to 0.
If vtkCLIOptions is nullptr, then this method internally creates and uses an internal vtkCLIOptions instance. In that case, extra / unknown arguments are simply ignored.
Internally calls, in this order:
  • InitializeProcessModule
  • InitializeGlobalOptions
  • InitializeSettings
  • InitializeOtherOptions
  • InitializeOthers
◆ Initialize() [2/3]
static bool vtkInitializationHelper::Initialize ( vtkStringList *  argv,
int  processType
◆ Initialize() [3/3]
static bool vtkInitializationHelper::Initialize ( const char *  executable,
int  type
◆ InitializeProcessModule()
static bool vtkInitializationHelper::InitializeProcessModule ( int  argc,
char **  argv,
int  type
This method should be called before any other initialization method Unless that method calls it.
This method should be called only once
This method is used by Initialize but can be used when separating options initialization from the rest of the initialization.
◆ InitializeGlobalOptions()
static bool vtkInitializationHelper::InitializeGlobalOptions ( int  argc,
char **  argv,
int  processType,
If options is nullptr, then this method internally creates and uses an internal vtkCLIOptions instance. In that case, extra / unknown arguments are simply ignored.
This method is used by Initialize but can be used when separating options initialization from the rest of the initialization, in combination with InitializeOtherOptions.
◆ InitializeOtherOptions()
static bool vtkInitializationHelper::InitializeOtherOptions ( int  argc,
char **  argv,
int  processType,
Returns true on success, false otherwise. When false, use GetExitCode to obtain the exit code. Note, for options that cause early exit of the program like --help, --version etc, this method returns false with exit-code set to 0.
This method is used by Initialize but can be used when separating options initialization from the rest of the initialization, in combination with InitializeGlobalOptions.
◆ InitializeOptions()
static bool vtkInitializationHelper::InitializeOptions ( int  argc,
char **  argv,
int  processType,
This method call InitializeProcessModule, then initialize all options.
◆ InitializeSettings()
static bool vtkInitializationHelper::InitializeSettings ( int  type,
Assume that InitializeProcessModule has been called.
If defaultCoreConfig is set to true, this will use the setting to set default values on the vtkRemotingCoreConfiguration
This method always returns true.
◆ InitializeOthers()
static bool vtkInitializationHelper::InitializeOthers ( )
Assume that InitializeProcessModule has been called. Returns true on success, false otherwise.
◆ InitializeMiscellaneous()
static bool vtkInitializationHelper::InitializeMiscellaneous ( int  type)
◆ InitializePythonVirtualEnvironment()
static void vtkInitializationHelper::InitializePythonVirtualEnvironment ( )
Make sure that the vtkPythonInterpreter has been initialized before calling this function.
◆ Finalize()
static void vtkInitializationHelper::Finalize ( )
Do not use the server manager after calling this.
◆ GetExitCode()
static int vtkInitializationHelper::GetExitCode ( )
inlinestatic
Definition at line 182 of file vtkInitializationHelper.h.
◆ StandaloneInitialize()
static void vtkInitializationHelper::StandaloneInitialize ( )
This is needed to insure that linker does not remove object factories' auto init during static linking. It also cleans up after protobuf.
◆ StandaloneFinalize()
static void vtkInitializationHelper::StandaloneFinalize ( )
◆ SetLoadSettingsFilesDuringInitialization()
static void vtkInitializationHelper::SetLoadSettingsFilesDuringInitialization ( bool  )
To disable this processing of the settings file for an application (e.g. in Catalyst), turn this off. On by default.
◆ GetLoadSettingsFilesDuringInitialization()
static bool vtkInitializationHelper::GetLoadSettingsFilesDuringInitialization ( )
◆ SetOrganizationName()
static void vtkInitializationHelper::SetOrganizationName ( const std::string &  organizationName)
This is "ParaView" by default, but can be different for branded applications.
◆ GetOrganizationName()
static const std::string& vtkInitializationHelper::GetOrganizationName ( )
◆ SetApplicationName()
static void vtkInitializationHelper::SetApplicationName ( const std::string &  appName)
◆ GetApplicationName()
static const std::string& vtkInitializationHelper::GetApplicationName ( )
◆ GetUserSettingsDirectory()
static std::string vtkInitializationHelper::GetUserSettingsDirectory ( )
The last character is always the file path separator appropriate for the system.
◆ GetUserSettingsFilePath()
static std::string vtkInitializationHelper::GetUserSettingsFilePath ( )
◆ LoadSettings()
static void vtkInitializationHelper::LoadSettings ( )
staticprotected
